02 limited AWD noise - JeepForum.com
post #1 of 11 Old 08-29-2010, 02:33 PM Thread Starter
imdave
Hey guys, if there is already a post about this question please let me know, I tried looking but couldn't find it. I'm trying to trade my civic for my dad's Jeep but the only thing holding him back is this problem he's having with it.
My dad has an 02 Grand Cherokee Limited 4.7 full time AWD, and he's saying that there is a whining or howling as speed increases but not with the engine. At one point when he had it serviced, the dealership thought it might be the front differential. They also said that this would be common. Can anyone verify this and if so does anyone know what could cause this/fix this? Any help would be much appreciated.
imdave is offline
post #2 of 11 Old 08-29-2010, 03:42 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Abuse or lack of proper maintenance can cause a bad front differential. It could also be due to using the wrong fluid and there could be something wrong with the Varilok diff, although I don't think that would cause a howling sound. It could also be a bad wheel bearing. Whatever you find is broken, the fix is replacing the broken part. Might sound like a dumb answer, but maybe you should consider the question (what could fix a bad front differential? A new one!)
Best of luck. And I would recommend an independent shop over the dealer any day of the week. Dealer techs are all about doing warranty service on the new models and not about taking care of older out-of-warranty rigs. Their primary goal is to do the job as quickly as possible and it seems to me like they are just guessing at the problem. "It might be..." is not the answer you want from a professional tech. "It is..." is the answer you are looking for.
~Richard
billzcat1 is offline
post #3 of 11 Old 08-29-2010, 06:11 PM
sage39henry
My Wj did this when i had the NV247. Ive recently just swapped to a 242. It has nothing to do with your transfer case. The problem or noise your probably hearing if it isnt a wheel bearing is probably your pinion bearing in the front diff. Does it only do it while your foot is on the gas? Or Slowing down. Being the its "AWD" it always has a good amount of pressure on the Front DS when your foot is on the gas or when you are braking. Pinion bearing replacement is most likely something to take to a garage. Also check your CV boots for tears and what not. Good luck!
WHITE WJ LIMITED 4.7 242HD/ IRO arms w/ Rusty's 4.5in coils/Doetsch 5in Shocks/JKS Quicker Disco's/ D44a Spartan Locker/ Rigid Industries 10" light bar/ 33 12.50 15 Mickey Thompson MTZ/ V-5s
sage39henry is offline
post #4 of 11 Old 08-30-2010, 12:24 PM Thread Starter
imdave
I hope I'm conveying this correctly. He said it didn't matter if he were on the gas or not, that if he were at speed and let off it was the same.
I appreciate the replies, I know the one question was kind of dumb, if something's broke, fix it! I looked into the parts for replacing the potentially broke stuff was only going to run me about $500-600 if I were to replace it all.
imdave is offline
post #5 of 11 Old 08-30-2010, 03:35 PM
billzcat1
2003 WJ
You might also consider a used axle assembly. Granted you don't know for sure what you are going to get, but you can DIY an axle swap in an afternoon pretty easily and a lot of places offer warranties on their used parts. It's an option that is probably a bit cheaper and easier than rebuilding the whole front diff.
~Richard
post #6 of 11 Old 08-31-2010, 11:26 AM
XJH-007
XJH-007's Avatar
[QUOTE=billzcat1;10038558] Whatever you find is broken, the fix is replacing the broken part. [QUOTE]
....that's like pure GENIUS.
So, by this Steven Hawkings thought process.....If the part is NOT broken, then that's NOT what's causing the noise?
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline
post #7 of 11 Old 08-31-2010, 01:05 PM
narnwv
narnwv's Avatar
This is incorrect. If your rear wheels aren't slipping, there is ZERO torque being sent to the front axle.
~Aaron
narnwv is offline
post #8 of 11 Old 08-31-2010, 01:06 PM
narnwv
narnwv's Avatar
I would pull the front drive shaft and see if the noise continues.
~Aaron
narnwv is offline
post #9 of 11 Old 08-31-2010, 05:47 PM Thread Starter
imdave
this won't cause any problems with the... well i forget the name of it, but the equipment that builds hydraulic pressure when the rear tires begin to slip?
imdave is offline
post #10 of 11 Old 08-31-2010, 05:52 PM
sage39henry
I dont think so.. but hey what do I know So if you put it on a high lift and put it in gear only the rear wheels would spin??
post #11 of 11 Old 08-31-2010, 07:26 PM
BreadsWJ
it's the wheel hub bearing!!
It's the wheel hub bearing almost for sure.
I have an 02 Limited GC (4.7) with Quadra Drive(AWD) and I had that annoying issue for months.
I was expecting the worse like the pinion bearing or my front diff being entirely shot or even my transfer case.
But.....after much investigation, putting it on a lift and carefully pin pointing the noise......turned out to be front driver's side wheel hub bearing.
Inexpensive fix and now my GC is quiet as can be.
Trust me, bring it to a mechanic, lift it up, have the truck running and in gear until the whining noise appears and have your mechanic pinpoint it from underneath.
Good luck
BreadsWJ is offline
2002 WJ GC Limited Popping Noise rmattwill WJ Grand Cherokee Forum 3 05-28-2010 10:20 AM
limited grille jakellahan WJ Grand Cherokee Forum 6 03-16-2010 11:17 PM
limited v8's Guitarhead09 WJ Grand Cherokee Forum 2 08-07-2007 12:46 PM
99 GC limited towing ??? mike481 WJ Grand Cherokee Forum 4 08-03-2007 11:22 PM
Need advice on 01 limited v8 srad711 WJ Grand Cherokee Forum 2 12-03-2003 07:28 PM
