'02 JGC Sport, Air Bag Light On, why? - JeepForum.com
post #1 of 8 Old 07-15-2013, 05:23 PM Thread Starter
specia1k
Wj '02 JGC Sport, Air Bag Light On, why?
Daughters at college with '02 JGC Sport and a couple days ago the RED Air Bag light shows lit on the console and won't turn off. Our '98 JGC Laredo Air Bag light will turn on after a heavy day of rain, then turns off the next day. Apparently there's a switch/sensor behind the head lamp on the '98 that is prone to getting wet and turning on the Air Bag light, until it dries out.
Daughter did the ignition trick (on/off/on/off/on) and no codes, just DONE. Going to have her stop by an auto parts store and have them scan for codes just in case.
Thoughts on why the '04 Air Bag light has turned on?
2004 Jeep Grand Cherokee Limited 2x4 4.0L
2002 Jeep Grand Cherokee Sport 2x4 4.0L
1998 Jeep Grand Cherokee Laredo 2x4 4.0L
"Three daughters, three Jeeps"
specia1k is offline
post #2 of 8 Old 07-15-2013, 06:13 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
There is a recall for this, might be worth checking out. Could also be a clockspring issue.
~James
ezflip is offline
post #3 of 8 Old 07-15-2013, 06:34 PM
robd2003
There is a recall, and while light is lit up, air bag could possible go off. Definitely check into it quick
Jeeps:
99' XJ<->5.5" Lift; 35's; SYE; Winch; much more goodies too
02' WJ<->Rebuilt from wreck, still stock
robd2003 is offline
post #4 of 8 Old 07-16-2013, 04:43 AM Thread Starter
specia1k
How do you disable the air bag? Can a fuse be pulled temporarily? Problem with the recall is that there are no parts yet to fix the recall. I've talked with Jeep many times.
specia1k is offline
post #5 of 8 Old 07-16-2013, 04:52 AM
georged
How do you get the recall performed when Chrysler claims they are having problems getting the replacement parts???? This was SUPPOSED to be fixed by Jan this year!
georged is offline
post #6 of 8 Old 07-16-2013, 05:09 AM Thread Starter
specia1k
Does anyone know the fuse# that can be pulled to disable the air bag? She's 500 miles away at college and I'd prefer her drive around with a disabled air bag, then one with the light on that has a known recall and could deploy at any time. Thanks...
specia1k is offline
post #7 of 8 Old 07-16-2013, 08:37 AM
georged
Go to a Jeep dealer and have them pull it - they might not even charge her!
georged is offline
post #8 of 8 Old 07-16-2013, 10:43 AM
rdkendrick
2003 WJ
I doubt it will deploy. My airbag light has been coming on and going off intermittently for a year or more. The '04's should have the modified ACM, which ignore the front impact sensors, per the TSB 08-016-03.
I doubt, very much, that a dealer will pull a fuse, or disable the airbag in any way, just for the liability alone.
There was an earlier TSB, which used switches to disable the airbags, but that only went up to a 2001.
If she has cruise control problems, and/or problems with the radio buttons, it could be a bad clock-spring.
An airbag light can only be reset by a special tool.
There are places that will reset airbag lights. You create a service ticket, they send you a box and label, you send them your ACM, and they repair and reset the ACM and send it back within 24 hours. Check myairbags.com.
Sent from my iPad using Forum Runner
rdkendrick is offline
