'02 GC Overland, AC not turn on in the cold? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > '02 GC Overland, AC not turn on in the cold?
Ruffstuff Axle Simple Swap Kit!ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-11-2014, 09:35 AM   #1
sloppytot
Good morning, all,
Looking at an '02 GC Overland to purchase. Test drove it yesterday. As I was testing everything inside of the truck, the A/C wouldn't kick on. I would turn temp knob to cold/blue, and push the A/C button, but the A/C light would come on for a second then turn off. The guy showing me the car said that he believes these models have a sensor that won't engage the AC when the outside temp is below a certain temp. It was in the high 30's F yesterday so it was cold.
Is there any truth to this or does it sound like an issue that they were hoping I would overlook?
Also, are there any things I should check that are particular to the 4.7 HO motors/trans/quadadrive system? I did the basic stuff; hard braking, hard accel, listened for ticking & knocking, oil looked clean/free of metal shavings, drove straight, clean carfax w/ exception of one open recall - #M35 ORC FILTER CIRCUIT from 01/13. I assume it hasn't been resolved since it's showing on the carfax. If there are any known issues that I should go back to check out before purchasing, please advise.
Thanks all!
sloppytot is offline   Reply With Quote Quick reply to this message
Unread 12-11-2014, 10:20 AM   #2
alfaitalia
CRD Pilot!
alfaitalia's Avatar
That is true and also AC wont come on for more than a second or so if the right selector knob is on auto and its already cool in the Jeep.
There are 10 types of people in the world......those that understand binary...and those that don't.
alfaitalia is offline   Reply With Quote Quick reply to this message
Unread 12-11-2014, 10:35 AM   #3
sloppytot
Ok, glad to hear. But is there any combination of settings that will force it to go on so I can at least confirm it's blowing cold prior to purchase?
Unread 12-11-2014, 11:31 AM   #4
86cj74.2L
86cj74.2L's Avatar
There is not enough pressure in the AC system to keep the compressor engaged for mor than a few seconds.
The pressure of 134 is temperature dependent.
86cj74.2L is online now   Reply With Quote Quick reply to this message
Unread 12-11-2014, 11:42 AM   #5
mr312712
My 04 Overland does the same thing but my A/C light stays on. But the compressor will cycle on and off which Is normal for 20 degrees. But I may be wrong but It should at least turn on.
04 WJ Overland 4.7 H.O.
mr312712 is online now   Reply With Quote Quick reply to this message
Unread 12-11-2014, 11:43 AM   #6
ChrisHager
ChrisHager's Avatar
The Ultimate WJ Grand Cherokee Buyer's Guide
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 12-11-2014, 01:47 PM   #7
99SK04GTX
The AC compressor will cycle on and off when the defroster is engaged; the heater core heats the air and the AC dries the air.
99SK04GTX is offline   Reply With Quote Quick reply to this message
