01 WJ Blower Motor Controller - JeepForum.com
post #1 of 3 Old 07-05-2013, 06:17 PM Thread Starter
Tuffjeeper
Recently, my wife and I drove to Lake Havasu to visit her family. We decided to take the newly purchased dub down because our other DD doesn't have cruise. At any rate, just outside of Searchlight, a small town between there and Vegas, I smelled a really strong electrical burning/melting smell. I pulled over and checked everything out, I couldn't find anything, so we kept driving. Nothing else happened, so I thought nothing of it.
Today on the way home from work, in a matter of 10-15 minutes the hvac intermittently quit working about 5-6 different times. The I jumped on the interweb to see if there was a common issue concerning this.. I went to pull the blower motor controller, I can get the blower motor connecter undone, but not the opposing end.
From what I can tell, this means that the connector must have melted which will not allow me to disconnect it.
Is that a safe assumption?
If so, I assume I can just cut the wires just behind the connector and hard wire them to the controller?
Originally Posted by plrbear View Post
Destroyed it somehow..... It went wobble wobble wobble boom
Tuffjeeper is offline
post #2 of 3 Old 07-05-2013, 08:44 PM
Marksikern
We may have had the same problem. I have a 99 and I had stopped for construction and turned the truck off to save gas. Then it didn't want to start. Got off to the side, popped the hood and saw what I thought were 2 wires on fire by the firewall. Turned out to be vacuum hoses that control the diverter valve for the HVAC and the cruise control. The ground wire to the firewall was responsible. Replaced that. If this is the problem your HVAC should still work but it will only blow air through the defrost vents as this is the default for the diverter door when you lose vacuum. If your vacuum line is ok at the firewall then it might be at the switch. To get to this you have to take off the under dash panels on both the driver and passenger sides of the interior. It has nothing to do with the blower motor, all it does is blow air. You might also check the AC clutch. Sometimes these go bad and causes intermittent operation of the AC and defrost. Good luck.
Marksikern is offline
post #3 of 3 Old 07-05-2013, 10:25 PM
rdkendrick
2003 WJ
You can just remove the connector out of the picture and solder to the resistor, or you can buy the kit with the larger gauge wires, it doesn't cost very much. It's what I did, after my blower motor quit working, intermittently. I had to keep hitting the box below the glove box, with my cane, to make it work again. This got old, so I stopped by Chrysler on one of my drives around, for work, and bought the kit for $17 or so. Later that night, I cut the old connector off, put heat-shrink on the wires, soldered the wires and heated the heat-shrink tubing in place to solve this problem. No problem for to years, now (knock wood.)
Sent from my iPad using Forum Runner
rdkendrick is offline
