01 WJ 4.0 overheating problem! - JeepForum.com
post #1 of 3 Old 07-07-2013, 07:19 PM Thread Starter
Brandon3216
Sooooo here's the scoop. My jeep doesn't overheat while running, it only does when I shut it off then turn it back on within 5-10 minutes. I've placed my fan relay and it does kick on right around 210, but when my engine is off the fan stops regardless of the temperature. I feel like the fan should stay on for 5ish minutes after shuttin off since engines get hotter before they cool back down? Also the radiator has been flushed and a new thermostat has also been installed.
Any suggestions or help would be greatly appreciated!
Brandon3216 is offline
post #2 of 3 Old 07-07-2013, 07:54 PM
rcwj04
how hot does it get?
You forget that most members here don't own a crystal ball to tell you exactly what your problem is, specially with bad pictures that don't say/show much of anything... -Jacko84
Just a 19 year old kid with a Jeep, and broke because of it, and loving every moment.
2004 WJ Laredo 4.0 116k
2" BDS coils & Bilstein 5100's | Addco rear swaybar with energy bushings |
K&N FIPK | glasspack | plasti-dipped badges | 17" moabs | HID's, 245/65/17 Cooper Discover AT3 | Rola rack | Fawkes stand alone shackle tabs | Bed lined interior (what a pain that was)
rcwj04 is offline
post #3 of 3 Old 07-07-2013, 07:54 PM
jeepenallday
did you replace the one under the passenger head light that on goes out all the time, also check water pump and thermostat
jeepenallday is offline
