'01 Laredo Custom Sub Box? - JeepForum.com
post #1 of 11 Old 02-09-2011, 02:26 PM Thread Starter
DominicRicci
Anyone know of a good custom Subwoofer Box for a 2001 Jeep Grand Cherokee Laredo?
I have a JL 10W3v3 and a JL 500/1v2
If you have one or a link to one or even a link to building plans I would GREATLY appreciate it. Thanks guys!
-dom
DominicRicci is offline
post #2 of 11 Old 02-09-2011, 09:45 PM
towerdude
1980 CJ7
There is a search tab towards the top of the page. Try searching WJ stereo build, wj sub box, ext... there are hundreds of posts and stereo builds for your jeep
1980 CJ-7 Named "Wanna Bet?" - 4" RC Lift, 36" Swamper TSL's, 4.2L, and lots of character
2004 WJ Limited - "Total Eclipse" - 4" RC Lift, 265/70/17 Cooper ST's, 4.7L, Huge stereo, Roof Rack, Smittybilt 98281 XRC 8 Comp Series Black Winch with Synthetic Rope and Aluminum Fairlead mounted on reciever plate.
towerdude is offline
post #3 of 11 Old 02-10-2011, 07:50 AM
Sunshine92
Design and build your own using the manufacturers recommended specs. It'll be really easy if you decide on a sealed enclosure, but ported isn't much harder. There are plenty of online calculators to help you with the ported design. Do a little reading on bcae1.com about enclosures. The RE enclosure calculator is a good tool for simple slot port enclosures, but make sure you double check all the calculations from that program by hand because it's known to be a little off at times. If you have the tools to build your own but can't figure out the design from the info here, PM me and I'll give you a little more specific help.
Sunshine92 is offline
post #4 of 11 Old 02-10-2011, 01:20 PM
kfxnando
well self have JLs, just the W6s
yes ported boxes work, however self am not a fan and much prefer sealed boxes!!
self would suggest a small box, and would also advise to go for the 12inch instead of the 10inch!!
go for small boxes, would suggest about a 20litre for the 10 and around 25litre for the 12inch if that change could be made!!
good luck
kfxnando is offline
post #5 of 11 Old 07-07-2011, 02:12 PM
KGC
kfxnando, why do you prefer the sealed box over the ported? Looking at doing this same thing and am trying to get a nice sounding box to fit tucked away and still sound nice.
2002 Grand Cherokee 4.0 Steel Blue
4" IRO lift, 17" Fuel Hostage wheels wrapped in 265/70/17 Goodyear Wrangler Duratracs
KGC is offline
post #6 of 11 Old 07-07-2011, 02:25 PM
twinsdaddy
Really its a matter of preference and what you are looking to accomplish. Sealed takes less space and generally produces a flatter, more balanced frequency range. A properly built and tuned ported enclosure wins in my opinion every time. Build it right and tune it low and you will get deeper lows with more output. All of this greatly hinges on the selection of sub you are using as well. Some do better sealed than ported and vice-versa
twinsdaddy is offline
post #7 of 11 Old 07-07-2011, 03:19 PM
narnwv
narnwv's Avatar
if you listen to mainly rap, and want muddy sounding bass that just hits hard, then go ported.
if you listen to rock, metal, etc.. go for the sealed enclosure, as the sound will be tighter and cleaner.
~Aaron
narnwv is offline
post #8 of 11 Old 07-08-2011, 12:05 AM
kfxnando
well some of my answer have already been posted
so will just add some
sealed boxes keep dust and other rubbish that ends up inside the boxes out
then my biggest reason
sealed boxes are way more forgiving, when it comes to speaker abuse
we go out, get carried away and keep cracking up the volume, distortion happens before the human hear can recognize it, and distortion is not good for speaker.
When overpowered sealed boxes stop the cones from flapping and self destruction
and to methane tighter sound of the sealed box sounds best, others may differ
enjoy
http://s538.photobucket.com/user/kfxnando/library/?sort=3&page=1
kfxnando is offline
post #9 of 11 Old 07-08-2011, 06:30 AM
twinsdaddy
Not to flame, but this is the common myth with everyone who cant design an enclosure. Part of this statement is true such as if you just want to build a square with a hole, chuck a sub in it and go, then sealed is going to sound better.
There is a reason that nearly every high-end home audio sub manufacturer uses ported enclosures. They have gotten a bad rap because people tend to think all ported enclosures will sound the same or dont do their homework before throwing a sub in a box.
I will gaurantee that a properly tuned enclosure will sound just as clean and again (preference) more pleasing to the ear with not just rap, but rock and country as well.
post #10 of 11 Old 07-08-2011, 11:28 PM
KGC
Thanks a lot!! you have been really helpful. I'm going to have to look into building a nice ported box, only issue now is trying to get it to sit tucked away and look good lol
KGC is offline
post #11 of 11 Old 07-30-2011, 05:04 PM
JeepWJ26
Here's mine. I am in the process of finishing the second box. They sit tucked back and molded to the wheel wells and other parts of the Jeep. Got the idea from Towerdude. Check out his thread (just type stereo build, you should find it.)
As for sealed or ported, its up to you. If you have never built a box before, I would think sealed because you wont have to worry about all the thought that goes into porting a box. If Im right, porting a box has a lot to do with the size of the sub, the air flow, and other variables that should be taken into consideration.
Heres a picture. Ive still got to hide the wiring and mount the amp in the spare tirer carrier. Once I clean everything up, it should look better. I am also going to build smaller boxes for either 2-way speakers or 3-ways, I cant decide. Those speakers are going to sit on the little shelf you can see on the box.
2002 Jeep Grand Cherokee Laredo >> "Johnny Cash Jeep." -- 2.5" Old Man Emu coil spring lift -- Rancho 5000 series shocks -- Custom subwoofer set-up
“Johnny Cash Jeep” Build > http://www.jeepforum.com/forum/f22/jeepwj26-build-johnny-cash-build-1210835/
JeepWJ26 is offline
01 JGC Laredo OverHeating jj401 WJ Grand Cherokee Forum 0 12-21-2010 10:40 PM
Does my laredo have? heretolearn WJ Grand Cherokee Forum 5 12-15-2010 04:31 PM
99 WJ Laredo (Ideas?) Sauceyj WJ Grand Cherokee Forum 11 10-13-2010 06:34 PM
Electroluminescent Gauges in My Laredo? ChiefNWA WJ Grand Cherokee Forum 21 10-03-2010 08:27 AM
New 2001 GC LAREDO SHOmuchFUN WJ Grand Cherokee Forum 1 04-05-2004 08:32 PM
