00 WJ stall plus weirdness - JeepForum.com
post #1 of 12 Old 07-21-2014, 06:13 PM Thread Starter
kfcforlife
My wife's 00 WJ( 4.0, 178xxx miles) is being a jerk and I need your sage like wisdom.
It started a month or so ago, at highway speeds when it hits a seam in the the road there's a split second where it feels like the fuel is cutting out and then it's fine, two weeks ago in stop and go traffic, she came to a stop and stalled, no dash lights, no check engine light, no radio, just dead.
She hit the key and it started right back up, it's done this twice since.
Last Friday, it died in stop and go traffic again, this time it didn't start right back up, instead this happened (I wasn't there, these are my wife's words) "I hit the key and it wouldn't turn over and it sounded like there was someone punching the passenger side rear of the car really fast"
The. It started right back up.
I've changed the fuel filter, pulled on every electrical connection under the hood, searched for vacuum leaks etc.
I'm thinking there's an angry little man running around under my wife's car being a jerk.
Do you have a better idea?
"don't piss on your motorcycle, it will rust"-- jesus H.
BLUE JEEP CLUB MEMBER 88
00 XJ 30X9.5 BF Goodrich A/T's K&N Dynamax homebrew rear bumper & swing out 3" rusty's aal 1" 3/4 coil spacers 55"X39" roof rack Optima
kfcforlife is offline
post #2 of 12 Old 07-21-2014, 06:16 PM
Floridabackwood
have you checked any of your differentials?
Floridabackwood is offline
post #3 of 12 Old 07-21-2014, 06:58 PM
piperdown
Sounds like an electrical connection that's gotten worse over time.
Cam position sensor is my first thought.
Got a CEL going?
piperdown is offline
post #4 of 12 Old 07-21-2014, 08:10 PM Thread Starter
kfcforlife
What's a CEL?
Please don't hit me....
post #5 of 12 Old 07-21-2014, 08:20 PM
wtf03WJ
2003 WJ
Check Engine Light
wtf03WJ is offline
post #6 of 12 Old 07-21-2014, 09:33 PM
ReclusiveXen
1997 XJ Cherokee
You could see if the fuel pump is crapping on you. Does it randomly just stall or does it stall a little after you hit a bump?
ReclusiveXen is offline
post #7 of 12 Old 07-21-2014, 11:34 PM
akoutdoors1
Sounds like an electrical connection to me too. I'm thinking it doesn't sound like a fuel problem. Fuel problems don't turn your radio off as far as I've ever heard. Differentials? You might check them for TROLLS.
akoutdoors1 is offline
post #8 of 12 Old 07-21-2014, 11:47 PM
Range07
2003 WJ
nah, the trolls only like to live in the D44a on v8s
Camshaft position sensor maybe.... but it still could be something simpler. You said you pulled on all the cables... did you remove the sheathing on the electrical cables and visually inspect them, or just check the connecting points? The cable can corrode away anywhere along the line
did you use a MOPAR fuel filter, or just whatever the local parts store had in stock? Im just wondering what else would / could sound like someones hitting the passenger rear of the vehicle... maybe a shot catalytic converter? This could be the CPS causing all sorts of weird pressures on the exhaust too I suppose, but thats never been something ive witnessed
Range07 is offline
post #9 of 12 Old 07-22-2014, 07:05 AM
asatxj
asatxj's Avatar
take a look at this thread Plenty of good intel there. On my daughters we replaced a crank position sensor and all is well. Can be a throttle position sensor as well.
Jeep Fleet Maintenance Director
'00 WJ, son's Jeep,'01 WJ mine, '04 TJ, brother's Jeep,00 WJ daughter's
Maintain your stuff so you don't have to fix your junk
ASAT= All Season All Terrain
asatxj is offline
post #10 of 12 Old 07-22-2014, 08:55 AM
ChrisHager
Administrator
ChrisHager's Avatar
Some of the symptoms make me think your Crankshaft Position Sensor is on its way out. What throws me for a loop is the noise your wife heard.
If it is the crank sensor, check out this thread: 2004 4.0 Crankshaft Position Sensor Replacement
That's probably it.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline
post #11 of 12 Old 07-22-2014, 10:09 AM Thread Starter
kfcforlife
Ok, I'll try to address some of what's been asked. No check engine light. And she told me last night that the radio stays on, everything else dies when it stalls. I use fram tough guard oil filters. Is there any way to check the CPS?
post #12 of 12 Old 07-22-2014, 05:33 PM Thread Starter
kfcforlife
Update, took it and had a code reader plugged into it.
Little orange box said "ABS Control Module"
Pretty sure that doesn't help.
