00 WJ Heat issues - JeepForum.com
post #1 of 3 Old 11-08-2013, 11:26 AM Thread Starter
gomb
00 WJ Heat issues
So it finally got cold enough here that I turned the heat on full blast. There really isnt any heat at full fan speed. If I turn the fan speed down, then I get some heat. 2000 GC limited, 4.7 Quadra, AZC.
The PO had the green coolant put in at some point, so I need to get that cleaned out. Here's what I am thinking. Take the beast in and get a good flush, pressure test, thermostat change, and the proper coolant put in. I am also going to get an oil change since I have only had the Jeep 2 months and god knows when the PO had that done last. Anything I am missing or other stuff that I should check?
gomb is offline
post #2 of 3 Old 11-08-2013, 12:35 PM
Jrboarder27
Could be clogged so a good flush might help you out. the heater core might need to be flashed separately.
Sent from my Galaxy S4 using JeepForum
Jrboarder27 is offline
post #3 of 3 Old 11-08-2013, 10:50 PM Thread Starter
gomb
Turns out its an AZC door issue. Heat is better after the flush, but only on thedriver side. The diag gives me a code 56. Gonna have to research that now.
gomb is offline
