Yakima Whispbar Rack - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Yakima Whispbar Rack
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW ZJ Grand Cherokee Tube DoorsGibson WK HEMI 3" Catback - 5 Day Special!
Unread 01-03-2015, 06:10 AM   #1
spinxt
Installed my Yakima Whispbar rack system last night. I'm VERY impressed. I can see why Yakima bought Whispbar. It's a great system. And true to advertising, it is QUIET! The Whispbar base rack with the ski snowboard carrier on top is more quiet than just the MOPAR base rack I had on my 2011...very impressed
spinxt is offline   Reply With Quote Quick reply to this message
Unread 01-03-2015, 06:32 AM   #2
MJS
2014 WK
Pics? Does it attach to the existing roof rail?
MJS is offline   Reply With Quote Quick reply to this message
Unread 01-03-2015, 08:32 AM   #3
spinxt
Yup, you remove the forward most and rearward most torx screws with and included wrench and install a longer "post" style screw that the rack adapts to. Superior quality and super easy install. The brushed aluminum finish looks awesome with my black GC.
Unread 01-04-2015, 01:59 PM   #4
Tweezer19
2014 WK
Interesting...I found their "fit kit" to not fit well at all and were not sealed on the inside. I ended up returning mine. It's too bad because the bars look great.
Tweezer19 is offline   Reply With Quote Quick reply to this message
Unread 01-04-2015, 04:19 PM   #5
jeepclimber
Interesting indeed. I though that there neither Yakima nor Thule is making bars for the Jeep OEM rails.
Where did you buy the Whispbar crossbars and what are the part numbers?
jeepclimber is offline   Reply With Quote Quick reply to this message
Unread 01-04-2015, 08:21 PM   #6
spinxt
Originally Posted by jeepclimber
Interesting indeed. I though that there neither Yakima nor Thule is making bars for the Jeep OEM rails. Where did you buy the Whispbar crossbars and what are the part numbers?
Just go to Yakima.com and use the "fit my vehicle" link. You can also do the same on ETrailer.com and RackAttack.com. It's pretty straight forward. I believe it was the S25 bars and the k624 fit it. Double check, not 100% sure.
Unread 01-04-2015, 08:25 PM   #7
spinxt
I had to play around with the length of the bar adjustment to get the rubber foot to sit right. Looks pretty good now.
Not sure why the insides of the feet aren't covered with plastic, however I tried removing the nut securing the bars and it's impossible, so it's not an issue in terms of rack security.
The look and performance from a noise standpoint is big win and I was willing to over look the small details.
Unread 03-19-2015, 11:01 PM   #8
TriBeer
Are the cross bars easily removable if you aren't using them?
TriBeer is offline   Reply With Quote Quick reply to this message
Unread 03-20-2015, 09:17 AM   #9
spinxt
Yup, bars can be removed with the supplied wrench (which I keep in the glove box) in less than 5 minutes.
Unread 07-21-2015, 01:24 PM   #10
Tweezer19
2014 WK
Is that the Whispbar Ski Rack in your picture?
2014 Overland Diesel w/ ORAII and Adv Tech Pkg
Unread 07-21-2015, 03:49 PM   #11
spinxt
Yes it is
Unread 07-24-2015, 11:14 AM   #12
Cuban_Overland
Attachment 1777377
Where did you get those running boards? I like them!
Cuban_Overland is offline   Reply With Quote Quick reply to this message
Unread 07-24-2015, 12:12 PM   #13
spinxt
They aren't running boards, they are MOPAR rock rails. Not worth the investment unless you plan on off roading. They are way more expensive than running boards
