WK2 Write-Ups - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > WK2 Write-Ups
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineXJ guys, clock your transfer case!Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!
Unread 02-06-2012, 06:17 PM   #1
JMP8562
WK2 Write-Ups
Hello all this has been an extreamly helpful thread for for all the DIY JEEPERS
when you do a simple mod like mounting a sunglass holder or more involved mod such as lifts - engine repairs - PLEASE share your how to and an idea of how easy / hard the job was pictures are a great help
89 lifted wrangler to 95 lifted cherokee to 01 GC now 07 JK 4 DOOR X WITH HIGH ROCK FRONT WINCH BUMPER APPROACH ROLLERS/WARN 9.5TI WINCH WITH UNDER THE HOOD CUT-OFF SWITCH/2.5" SS lift/1"M.O.R.E BL/33" BFG KM2 ON STOCK 17"/RIVER RAIDER ROCKER GUARDS-SLIDERS/OFF ROAD HEROS FASTBACK SOFT TOP/GIBSON DUEL EXHAUST/CUSTOM MADE TRUNK/HELLA FF300/HELLA500 W-WINDSHIELD MOUNTS/DELTA SKYBAR/CARBON FIBER DASH KIT/DUEL AND SINGLE GUAGE PODS WITH VOLT-OIL PRESSURE-OIL TEMP GUAGES/COBRA 75 CB/AND A LOT OF RECOVERY GEAR
JMP8562 is online now   Reply With Quote
Unread 02-14-2012, 05:11 PM   #2
JMP8562
231 VIEWS AND NO ONE MADE OR MODIFIED ANYTHING
Unread 02-14-2012, 05:16 PM   #3
l8tapex
2012 WK
Good Idea. I had made a few pics and instructional threads in a Harley Davidson F150 forum. The actual forum was stickied so members could show and share there mods.
________________________
2012Overland 4 X 4 Deep Cherry Red Crystal Pearl Coat, SRT8 Hood and Spoiler
l8tapex is offline   Reply With Quote
Unread 03-04-2012, 06:15 AM   #4
JMP8562
dvdsjk rock rail install
Thanks for sharing dvdsjk do you have any short cuts for the next person
WK2 Rock Rail Install.
http://www.jeepforum.com/forum/f309/...stall-1164159/
Unread 03-04-2012, 06:32 AM   #5
JMP8562
Accessory switch location
Thanks for sharing trooper1968
anyone else want to add .pictures are a great help
http://www.jeepforum.com/forum/f309/...ideas-1325180/
Unread 03-04-2012, 08:49 AM   #6
JMP8562
Skids on 2012 Grand Cherokee Overland - Pics
found this thought it would be good to put it here for others to add to it
thanks for sharing wxchaser
http://www.jeepforum.com/forum/f309/...-pics-1280910/
Unread 03-04-2012, 12:12 PM   #7
padgett
2012 WK
I added the Tubular Aluminum Rails (side steps) p/n 82212130 and created a page with some notes to go along with the pictogram instructions. Took about two hours to install because am slow.
Still trying to figure where to put my size 11's so it is useful.
One of these is a diesel.
We take in orphans. Notary Sojac y'all.
padgett is offline   Reply With Quote
Unread 05-09-2012, 10:25 AM   #8
JMP8562
ADJUSTING YOUR HEADLIGHTS
http://www.jeepforum.com/forum/f309/...nment-1252068/
Unread 10-14-2012, 01:30 PM   #9
xJoshxx
2011 WK
How to Add Auto Climate your Wk2!
I ordered Item # 55111916AP (2011-2013 without Heated or Ventilated Seats)
From Just for Jeeps!!
Step #1 Unbox and awe at the beauty of it.
Step #2 say good bye to manual HVAC
Step #3
Use the bottom lip of the trim and pull with 2 hands equally * mine took some force*
Almost there!!! I found it easier to start pulling and wiggling near the drivers vent!
***** Caution There are wires attached to the panel*****
Step #5 it's out!
Step #6 Requires a #15 Torx bit (at least that's what worked for me)
4x torx and the old HVAC will fall out!
Take your new Auto Hvac put it in place of the old put the screws back in.
Step #7 Trim the HVAC Harness Connector ** I used a razor blade to trim it **
Step #8 Plug your connectors back into the panels before putting the trim back in place and get it a good push to pop all the clips back in.
Step #9 Enjoy!!
Hope this helps!
Interested in Amsoil? Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 Laredo with ORA1
xJoshxx is offline   Reply With Quote
Unread 10-14-2012, 02:53 PM   #10
C0mbatChris
USAF
C0mbatChris's Avatar
2011 WK
Awesome write up!
This either needs to be a sticky or added to the "Sticky: WK2 Write-Ups"
Upgraded to 430N RHB MyGig }{ 3.6L V6 Laredo X }{ Off-Road Adventure I }{ Trail Rated }{ QTII }{ Selec-Terrain }{ OEM Skid Plate Group }{ Flex Fuel
C0mbatChris is offline   Reply With Quote
Unread 10-14-2012, 06:31 PM   #11
GreekGhost
Very interesting on the HVAC auto climate control. Are there any temperature sensors already in the WK2 that just aren't utilized?
Current: 2013 Jeep Wrangler Unlimited
Past: 2013 Jeep Grand Cherokee Laredo
1998 Jeep TJ SE
GreekGhost is offline   Reply With Quote
Unread 10-14-2012, 07:26 PM   #12
xJoshxx
2011 WK
The solar load sensor which is incorporated into the Automatic headlights.
and the I believe the Auto HVAC has it's own infrared system see the center of the dial on the auto system.
Unread 12-19-2012, 09:31 AM   #13
adgjqetuo
I'm surprised its as plug and play as that. Does the dual climate work as well or do you only gain the auto climate functionality?
Mike
13 Subaru Outback Limited - Current
04 Jeep grand Cherokee Overland - 23k ~ 71k - Sold
98 Jeep Grand Cherokee Laredo SE - 73k ~ 150k - Sold
adgjqetuo is offline   Reply With Quote
Unread 12-22-2012, 11:00 PM   #14
xJoshxx
2011 WK
Dual Climate works perfectly and auto climate does like it should.
Unread 02-25-2013, 06:48 AM   #15
JSRichar5985
DIY factory remote start
I've been looking at adding a remote start to my wife's WK2. its cost about $220 to buy the kit and the dealer quoted like $500 for the installation. I was reading the installation guide and it seems fairly simple just alot of pulling interior parts out. Has anyone attempted this job on their own? Is it difficult?
here is the installation guide:
http://site.justforjeeps.com/guide/82212137.pdf
JSRichar5985 is offline   Reply With Quote
