WK2 Winch Options??? - JeepForum.com
post #1 of 8 Old 06-30-2011, 08:51 AM Thread Starter
Lakeboy106
2011 WK
Hello All,
Just bought a 2011 WK2 Overland 4X4 with 5.7L HEMI. I have a Warn M8000 winch and was wondering what options for mounting there are.
Warn, at present, has NO front under-bumper mounts for this winch other than universal. I took off the lower front fascia which exposed a vertical surface of the lower frame, near where the tow hooks would be mounted. Is this spot suitable to mount/weld the winch/universal tray? It would probably involve some plastic trimming of the fascia to mount the roller fairlead to the tray.
OR, should I go the way of mounting the winch to the hitch receiver in the rear and run the quick-disconnect cable to the battery under the passenger seat?
Which opens up a new can of worms.... When you're stuck, winch out from forward or behind?
Lakeboy106 is offline
post #2 of 8 Old 06-30-2011, 08:45 PM
kkuntz01
I'm sure there are ways to make it work if you wanted to mount it up front, though I'm not technical enough to speak to how to make that work. The only way I could picture it would be with customized brackets and having the guts enough to chop up the front bumper or waiting for ARB or another company to release a front bumper for the WK.
I suppose you could do a rear hitch mounted set up which of course does present it's own inherent challenges both for wiring or even recovery.
It is possible to perform a self recovery from the front even if your winch is in the rear. Of course it would require having a couple of tree savers and snatch blocks on hand to string the winch line up to the front of the vehicle. Not ideal, but it could get the job done.
The biggest question I'd raise is if the M8000 is enough winch for your WK. When I had my 4dr Rubicon I had a chance to pick one of those up. I asked my buddy who is the Trail Master for my club if he thought that would do for me he told to me to pass as he didn't think it was enough winch for my rig. He made the recommendation to consider a winch rated for twice the weight of my vehicle, which for me at the time meant a 9500/10000lb winch. Mind you my 4dr Rubicon weighed in probably about 500lbs less than your Overland which weighs in about 5300lbs.
Just so there is not a misunderstanding either, I'm not saying the M8000 won't work for you. I'm just saying it'll have to work much harder under load than a higher weight rated winch.
Keep us posted on what you plan on doing.
Sure my rig has seen the trail, but I wheel it like a soccer mom looking for a parking spot at Nordstroms.
kkuntz01 is offline
post #3 of 8 Old 07-03-2011, 11:28 PM
eternollie
2011 WK
i have a 10000lb mounted to a receiver bracket. Instead permanent front mount i am gonna fab a brace on the front beam with a receiver cut thru probably behind the front licence plate. this way i can go front or rear.
eternollie is offline
post #4 of 8 Old 02-17-2012, 07:25 AM
JMP8562
have you had any luck mounting it ?
89 lifted wrangler to 95 lifted cherokee to 01 GC now 07 JK 4 DOOR X WITH HIGH ROCK FRONT WINCH BUMPER APPROACH ROLLERS/WARN 9.5TI WINCH WITH UNDER THE HOOD CUT-OFF SWITCH/2.5" SS lift/1"M.O.R.E BL/33" BFG KM2 ON STOCK 17"/RIVER RAIDER ROCKER GUARDS-SLIDERS/OFF ROAD HEROS FASTBACK SOFT TOP/GIBSON DUEL EXHAUST/CUSTOM MADE TRUNK/HELLA FF300/HELLA500 W-WINDSHIELD MOUNTS/DELTA SKYBAR/CARBON FIBER DASH KIT/DUEL AND SINGLE GUAGE PODS WITH VOLT-OIL PRESSURE-OIL TEMP GUAGES/COBRA 75 CB/AND A LOT OF RECOVERY GEAR
JMP8562 is offline
post #5 of 8 Old 03-01-2012, 05:51 AM
JMP8562
JMP8562 is offline
post #6 of 8 Old 03-01-2012, 05:55 AM
fljeepleo
2011 WK
Had a m8000 on a F250. Got it out of some nasty mud holes and that truck weighed alot. If you need more Power use a tree saver and a pulley.
2011 Stone White Grand Cherokee Laredo E, ORA1, QT2, Factory Trailer Tow, 3m FX 15% Tint.
Retired Jeeps
1998 Wrangler Sahara 10inch skyjacker lift, 38x14.50 TSL
2005 Grand Cherokee Limited, 5.7, QD2
fljeepleo is offline
post #7 of 8 Old 03-01-2012, 07:31 AM
Heath
2014 JK Wrangler
Good luck pulling it uphill.
2013 JKU Rubicon
Heath is offline
post #8 of 8 Old 03-01-2012, 07:35 AM
Heath
2014 JK Wrangler
The only way that would be possible is to block off of the jeep itself which itself is not possible.
2013 JKU Rubicon
Heath is offline
Aftermarket rims - Options, Opinions? trooper1968 WK2 Grand Cherokee Forum 13 04-22-2012 08:56 AM
Any other options for key fobs? poomobile WK2 Grand Cherokee Forum 12 05-05-2011 05:32 PM
Exhaust options chrisbradley_20 WK2 Grand Cherokee Forum 19 04-01-2011 09:54 AM
Remote Starter & 2-way options? boldd WK2 Grand Cherokee Forum 4 01-31-2011 06:46 PM
Remote Starter & 2-way options? boldd WK2 Grand Cherokee Forum 0 01-30-2011 12:11 PM
