WK2 wheel specs? - JeepForum.com
post #1 of 13 Old 02-15-2011, 08:39 PM Thread Starter
Bzwth
2008 WK
WK2 wheel specs?
Does anyone know where I can get the specs for the stock wheels (18" and 20") offered on the new WK2's? Back spacing, offset, etc.
Bzwth is offline
post #2 of 13 Old 02-15-2011, 09:35 PM
boldd
This is all I know of: http://www.wk2jeeps.com/2011/2011_wk...tions_June.pdf
boldd is offline
post #3 of 13 Old 02-15-2011, 09:42 PM
LuckRider
LuckRider's Avatar
That doesn't have any numbers for the rims. That is a great site though. When I get some time and ambition, I will put together a huge thread with lots of stock information and guides for everything I can find. I have lots of work this semester though.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #4 of 13 Old 02-15-2011, 10:22 PM
webspoke
Offset is +56mm and backspace around 6.7" for both the 18x8 and 20x8 wheels.
webspoke is offline
post #5 of 13 Old 02-18-2011, 09:36 AM
wahoo
2011 WK
Does anyone know what the bolt pattern is on the 18 X 8 wheels? Is it 5 X 5?
wahoo is offline
post #6 of 13 Old 02-18-2011, 09:38 AM
webspoke
Yes, 5x5.
webspoke is offline
post #7 of 13 Old 02-18-2011, 09:39 AM
LuckRider
LuckRider's Avatar
There is a WK2 that I could swear I saw in this section with JK Moabs on it. Those Rims just look sexy on the WK2. If I can find a set of takeoffs for about the cost of tires when my mom needs new ones I will have her get those.
Support Our Troops!
JFI Member #7:
post #8 of 13 Old 02-18-2011, 09:52 AM
CTO1
2011 WK
I'm about 99% certain JK Moabs will require at least half an inch of (front?) spacing to clear the brake calipers. I know for certain that this is the case on a WK and I believe it to be true for a WK2 as well. It would be great if there were a set of Moabs that could fit without having to use spacers, because I agree that they look sexy
CTO1 is offline
post #9 of 13 Old 02-18-2011, 10:48 AM
LuckRider
LuckRider's Avatar
Even still, that is what, $120 for spacers?
Support Our Troops!
JFI Member #7:
post #10 of 13 Old 02-18-2011, 12:53 PM
CTO1
2011 WK
Double that for two pairs. I wouldn't want non-bolt-on spacers and I don't know if there are any bolt-on spacers out there that are under 1.25". With that size a 265 or 275 width tire will be sticking out beyond the fender, which I personally wouldn't want on my WK2. It might also not be possible to fully turn the wheels by moving them out that much. I saw the same pictures you did but I would want to see it in action or see detailed photos of the front tires at full lock to see what kind of clearance it has. If I were to go with 17" wheels I would choose the stock WK2 ones or the AEV WK Pintlers.
CTO1 is offline
post #11 of 13 Old 02-18-2011, 07:09 PM
LuckRider
LuckRider's Avatar
To be honest, I would love them to stick out a tad. You can get RC spacers for $60 and they are 6061T6 IIRC. I can't see how having them stick out would interfere with full turning radius, only when the wheel is tucked too far in.
Support Our Troops!
JFI Member #7:
post #12 of 13 Old 02-18-2011, 09:24 PM
2011Hemi
2011 WK
Having them positioned out further does have a negative affect. The further away the wheel centerline is from the pivot point (balljoints) increases the distance the wheel moves forward or backward during turning.
2011Hemi is offline
post #13 of 13 Old 02-18-2011, 10:13 PM
LuckRider
LuckRider's Avatar
But I still don't see how that causes an issue with making steering wider. Many vehicles have much less backspacing. My only concern would be if it rubbed.
Support Our Troops!
JFI Member #7:
Wheel and Tire Discussions Timgco WK2 Grand Cherokee Forum 2640 Today 05:34 PM
Is the 2011 Quadra Drive 2 a 3 wheel or 4 wheel drive system? MRK WK2 Grand Cherokee Forum 45 11-03-2015 11:22 AM
Ordered my 2011 Overland tonight. Price and specs inside! JTS97Z28 WK2 Grand Cherokee Forum 8 01-04-2011 11:05 AM
Overland Wheel on Limited? ecupip WK2 Grand Cherokee Forum 12 12-26-2010 05:53 PM
What is the Wheel Bolt Pattern getoutandplay WK2 Grand Cherokee Forum 3 11-27-2010 08:18 PM
