-   WK2 Grand Cherokee Forum (http://www.jeepforum.com/forum/f309/)
-   -   WK2 wheel specs? (http://www.jeepforum.com/forum/f309/wk2-wheel-specs-1168746/)
Bzwth 02-15-2011 08:39 PM
WK2 wheel specs?
Does anyone know where I can get the specs for the stock wheels (18" and 20") offered on the new WK2's? Back spacing, offset, etc.
boldd 02-15-2011 09:35 PM
This is all I know of: http://www.wk2jeeps.com/2011/2011_wk...tions_June.pdf
LuckRider 02-15-2011 09:42 PM
That doesn't have any numbers for the rims. That is a great site though. When I get some time and ambition, I will put together a huge thread with lots of stock information and guides for everything I can find. I have lots of work this semester though.
webspoke 02-15-2011 10:22 PM
Offset is +56mm and backspace around 6.7" for both the 18x8 and 20x8 wheels.
wahoo 02-18-2011 09:36 AM
Does anyone know what the bolt pattern is on the 18 X 8 wheels? Is it 5 X 5?
webspoke 02-18-2011 09:38 AM
Yes, 5x5.
LuckRider 02-18-2011 09:39 AM
There is a WK2 that I could swear I saw in this section with JK Moabs on it. Those Rims just look sexy on the WK2. If I can find a set of takeoffs for about the cost of tires when my mom needs new ones I will have her get those.
CTO1 02-18-2011 09:52 AM
I'm about 99% certain JK Moabs will require at least half an inch of (front?) spacing to clear the brake calipers. I know for certain that this is the case on a WK and I believe it to be true for a WK2 as well. It would be great if there were a set of Moabs that could fit without having to use spacers, because I agree that they look sexy :thumbsup:
LuckRider 02-18-2011 10:48 AM
Even still, that is what, $120 for spacers?
CTO1 02-18-2011 12:53 PM
Double that for two pairs. I wouldn't want non-bolt-on spacers and I don't know if there are any bolt-on spacers out there that are under 1.25". With that size a 265 or 275 width tire will be sticking out beyond the fender, which I personally wouldn't want on my WK2. It might also not be possible to fully turn the wheels by moving them out that much. I saw the same pictures you did but I would want to see it in action or see detailed photos of the front tires at full lock to see what kind of clearance it has. If I were to go with 17" wheels I would choose the stock WK2 ones or the AEV WK Pintlers.
LuckRider 02-18-2011 07:09 PM
To be honest, I would love them to stick out a tad. You can get RC spacers for $60 and they are 6061T6 IIRC. I can't see how having them stick out would interfere with full turning radius, only when the wheel is tucked too far in.
2011Hemi 02-18-2011 09:24 PM
Having them positioned out further does have a negative affect. The further away the wheel centerline is from the pivot point (balljoints) increases the distance the wheel moves forward or backward during turning.
LuckRider 02-18-2011 10:13 PM
But I still don't see how that causes an issue with making steering wider. Many vehicles have much less backspacing. My only concern would be if it rubbed.
The time now is 09:39 PM.
