WK2 Tire and Wheel Sizes - Page 9 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > WK2 Tire and Wheel Sizes
Only 2 Days left to win $3,800 Jeep Parts!Count Down to KOH Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 07-24-2012, 02:34 PM   #121
djrobdecker
2011 WK
Hey guys - I have the base Laredo RWD (no QL). I don't really know much about wheels/tires, but what I do know is - I want them WIDER. I like the way the rear tires look on the BMW X5 & am interested in copying that look. I think they're staggered though. So, my question is: what would be the widest tires I can fit onto some 18 x 9s? I'm thinking I might be able to squeeze 305/55/18 in the front & maybe something even wider in the back. All of my driving is on the pavement, so no off-roading needs here at all.... Thoughts?
djrobdecker is offline   Reply With Quote Quick reply to this message
Unread 07-27-2012, 02:36 AM   #122
haroman311
thanks idaho!
haroman311 is offline   Reply With Quote Quick reply to this message
Unread 08-05-2012, 01:42 PM   #123
TheSiltSurfer
2012 WK
20"s wrapped in 33"s it's possible with removal of lower air dam and 1.5" spidertrax wheel spacers, Non QL naturally & RRO lift
Infinite Patience Produces Immediate Results
TheSiltSurfer is offline   Reply With Quote Quick reply to this message
Unread 08-06-2012, 06:12 PM   #124
Alaska-HWY JK
Did you drill out the wheel spacers? My JK ones wouldn't work because the GC has larger studs. I talked to Spidertrax and they didn't make them for the new GC yet.
Alaska-HWY JK is online now   Reply With Quote Quick reply to this message
Unread 08-06-2012, 10:50 PM   #125
TheSiltSurfer
2012 WK
Yes simple use of a drill press, the hubs are exactly the same so just widen the stud holes and they fit snug & perfect, also have to change your lugs on the outside to wk.
Unread 08-07-2012, 09:20 AM   #126
CJ7Sooner
2011 WK
Did you use the stock lug nuts to secure the spacer to the hub, or the spacer to the wheel?
I'm asking because I took the stock rubicon wheels/tires off my JK the other day and put it on my WK2. Those 32s and wheels look bad on the WK2! The rubi wheel doesn't have the same backspacing and doesn't have the inside clearance for the WK2 brakes without spacers though.
How do you like your RRO Lift? Did you go straight to the 33s? I'm wondering if I'll have any rub at full articulation with 32's and spacers.
CJ7Sooner is offline   Reply With Quote Quick reply to this message
Unread 08-07-2012, 09:53 AM   #127
TheSiltSurfer
2012 WK
Use wk2 size acorn nuts to secure spacer and just got lugs for WK left wk2 ones out. The lift isnt much to complain about, two spacers some bolts lol I also have the RRO UCAS which seemed to provide more droop. Not sure how much you will rub with those jk wheels, but with 33's it kisses the top of my rear fenders on articulation. I shaved my pinch welds so they no longer rub up front anyone.
Unread 08-07-2012, 05:28 PM   #128
ctgreen77
2011 WK
New Shoes
Black Rock Intruder 910B 18x8.5 with 265/65r18 Bridgestone AT RH-S. Pic is at ORI.
Note: Due to BS and Offset this is the biggest tire that will fit on these wheels if you have QL. I tried a Cooper AT3 and GY MTR in 275/65r18 with no luck.
"I love America, but I love Texas more!" ---Ted Nugent---
ctgreen77 is offline   Reply With Quote Quick reply to this message
Unread 08-19-2012, 04:05 PM   #129
ktwillis
2012 WK
255/75/17 off Wrangler Rubicon with RRO Level Kit. Wheels bolted right up but you need a 1/8 to 1/4 spacer in the front because the wheel just kisses the caliper if you break hard in a tight turn.
ktwillis is offline   Reply With Quote Quick reply to this message
Unread 08-19-2012, 07:35 PM   #130
1slo_CR
2011 WK
Originally Posted by ferntr33 View Post
Anyone know the smallest wheel size you can fit? i miss my 15" rock crawlers. Im sure caliper clearance is the issue. But has anyone put a 16 or 17 on?
I am curious of this too.
ANYBODY????
'11 WK2 Laredo X Blackberrry Pearl on Nitto S/T II's 285/45/22
'89 MJ rcsb 2wd 4.0 auto, rust free!
1slo_CR is offline   Reply With Quote Quick reply to this message
Unread 08-19-2012, 07:58 PM   #131
Jackal01
Jackal01's Avatar
2011 JK Wrangler
ANYBODY????
I already answered your question...
Originally Posted by Jackal01 View Post
Base Laredo comes with 17s
2011 Billet JKUS
Jackal01 is offline   Reply With Quote Quick reply to this message
Unread 08-20-2012, 12:12 PM   #132
1slo_CR
2011 WK
Yes, i read that. I should have specified 16" or smaller..
Unread 08-20-2012, 12:29 PM   #133
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Gotcha. I assume the calipers would be in the way. I imagine if someone did do smaller than 17s that it would have been posted already.
2011 Billet JKUS
Unread 08-20-2012, 03:51 PM   #134
1slo_CR
2011 WK
Ok thanks for the heads up. Ill look for a set of 16s and give them a fit up look.
Unread 08-28-2012, 09:04 AM   #135
ktwillis
2012 WK
I change my wheel and tire combo. Factory 18s powder coated matte black with 265/60/18 Cooper AT3 all terrains.
