WK2 Tire and Wheel Sizes - Page 30 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > WK2 Tire and Wheel Sizes
Only 2 Days left to win $3,800 Jeep Parts!Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineAttention seahawks fans!!! Want to save some $$$ ??!!
Unread 01-30-2014, 06:34 PM   #436
jacko15
2014 WK
Same diameter tire whether it's a 20" or 18" wheel. Nothing needs reprogrammed. I ordered the ORA II package mainly to get the 18's on my Overland that comes stock with 20's. I think it's a good choice to go with the 18's. Others will probably disagree, but to each his own.
Hers: 2008 Jeep Compass Sport
Mine: 2014 Jeep Grand Cherokee Overland V/6 ORA II
Michelin LTX M/S 2's
jacko15 is offline   Reply With Quote Quick reply to this message
Unread 01-30-2014, 10:55 PM   #437
OutbackGC
Greetings, first post here but over the last week I have read all the wheel and tyre threads both here and on other forums and my head is spinning so I do apologise if I ask something that has already been covered.
Basically I took my '14 Overland off the track last weekend on the stock 20" Kumhos, scuffed up my rims and shredded a side wall. Always intended to upgrade to 18" rims and AT's but this has fast tracked things a bit.
Firstly I am in Australia which makes my choices a bit limited.
I think I am going to go for these rims:
http://www.4x4wheelco.com.au/index.php/atx-series/ledge
So it now comes down to tyre choice.
My local tyre shop has recommended the Wrangler AT Adventure 265/60R18s (this is the only profile *for this tyre* available for 18's in Australia)
The look like they will do the job well but they dont look as aggressive as I would like (this upgrade is going to cost me over $3k and thats just for the set of 4 so if I can achieve an aesthetic improvement as well as a practical one it would be nice).
From what I have read 265/65R18 will fit with the QL no dramas but the spinning has confused me, are there other sizes that will fit?
Those with the 265/65R18, do they fit in your spare wheel spot, if they dont is it purely a height issue, ie could we get a 245 with the same OD that would fit?
Again apologies if I am covering old ground but any help will be appreciated.
*oh, and with the spare wheel spot, has anyone considered carrying around a deflated spare with a compressor, if so what sizes fit?*
OutbackGC is offline   Reply With Quote Quick reply to this message
Unread 01-31-2014, 06:59 PM   #438
MuSh
Originally Posted by danbrew View Post
Well, sure. Now I know that.
They are so close in outside diameter that there is no need to recalibrate. They are different different though.... 20" wheels make 690 revolutions per mile. The 18" wheels do 691 turns per mile
MuSh is offline   Reply With Quote Quick reply to this message
Unread 02-03-2014, 02:59 PM   #439
2kg4u
2014 WK
My GC came with 20's, and I just put 18's (snow tires) on it last weekend. With the 20's, at 65 MPH the speed reading on the NAV matched the speedometer reading. With the 18's, it still matches at 65 MPH. There is a slight difference in diameter, but not enough to make a noticeable difference.
Roy
2014 Overland, 3.6 L
Fumoto Qwikvalve, Ionic CXV running boards, Michelin X-Ice Xi2 snow tires
2kg4u is offline   Reply With Quote Quick reply to this message
Unread 02-03-2014, 03:25 PM   #440
Aquaforest
What wheels did you go with?
Aquaforest is offline   Reply With Quote Quick reply to this message
Unread 02-04-2014, 01:58 PM   #441
2kg4u
2014 WK
Nothing special. I bought 4 used aftermarket wheels off Ebay for $400 total from a tire and wheel shop about 40 minutes from my house. Saved shipping costs by picking them up. The bolt patter (5 x 127mm), width (8.5") and center bore (71.5mm) were all spot on, but the offset was 36 mm versus the stock 56.4 mm. They stick out 0.8" more than stock, which is no problem. Here is the link:
http://www.ebay.com/itm/131085086914...#ht_543wt_1106
Roy
Unread 02-04-2014, 02:41 PM   #442
Michaelinmech
Help with tires for a 2014 Overland
Hello -
It's my first day here and my first post.
I'll cut to the chase with the help/advice I am seeking. Thanks in advance.
Basic Facts - my 2014 Grand Cherokee Overland has original equipment wheels in 20"x8" size. Original equipment tires are Goodyear Fortera 265-50/20.
Those oe tires have size specs of 10.9" section width, 8.3" tread width and 30.5" diameter.
I am purchasing some 20x9 wheels for summertime use. In coupling those with some highway tires, I would like to upsize to a 275-50x20 size. I would like to put a wider tread width on the road. My vehicle is pure stock.
One choice, a Pirelli, has specs of 11.4" section width, 10.7" tread width and 31.1" diameter.
Another choice, a Bridgestone, has specs of 11" section width, 9.6" tread width and 32" diameter.
Can anyone with experience or expertise please advise me if I can successfully upsize to either of the 2 tires listed above without any rubbing, interference or adversely effecting vehicle electronics due to diameter change?
Thanks again kindly - Michael
Michaelinmech is offline   Reply With Quote Quick reply to this message
Unread 02-04-2014, 02:56 PM   #443
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Originally Posted by Michaelinmech View Post
Hello -
We have dedicated threads to wheels and tires for a reason.
We also have rules and guidelines for a reason. You need to read that thread before you post. Searching is a valuable tool here that will benefit you.
Good luck and welcome.
2011 Billet JKUS
Jackal01 is offline   Reply With Quote Quick reply to this message
Unread 02-04-2014, 04:33 PM   #444
MichiganState88
2011 WK
Are you happy with the 36mm offset? Earlier in this tread I was beating my head against the wall trying to figure out what kind of offset I wanted, figuring that I wanted the tire to be close to flushing out with the top of the fender and came up with a +/- 30mm offset. I am about to order some MBTKOs black with a 25mm (only offset offered) and think that this will be close enough. Are you noticing that you are throwing too much mud/stones into your paint?
Bright White 2011 GC Overland QL Hemi, MBTKO, 265/65R18 BFG KOs, Sliders, OEM Skids, Volant, Corsa
MichiganState88 is offline   Reply With Quote Quick reply to this message
Unread 02-04-2014, 06:13 PM   #445
MichiganState88
2011 WK
Originally Posted by matthewbunton View Post
I have 255/70/r17 on mine. They are on JK 17s. I had to grind on the calipers a little bit to make the front two fit. I think I have the HD claipers on mine, but with a little bit of Plastic dip they look great. What do you all think?
How's this plasti-dip holding up? It looks great here, I am planning to do similar when the weather breaks to mine.
Unread 02-05-2014, 08:21 AM   #446
2kg4u
2014 WK
So far I am okay with the 36 mm offset. One thing that helps is I installed mud flaps a couple of weeks ago. All other things being equal a 25 mm offset will only stick out 0.4" more each side versus a 36 mm offset, and only 1.2" more each side versus the stock 56 mm offset.
Here is a very helpful site for comparing various options of wheel/tire combinations that I used quite a bit in making my decisions:
http://www.rimsntires.com/specspro.jsp
Roy
Unread 02-17-2014, 09:14 PM   #447
STL-9
2014 WK
Hi... New to the forum, and a bit out of my element, so please be don't be frustrated by my ignorance... I honestly don't even know if I'm posting correctly (new to forums as well). Got a 2014 Laredo that I'm wanting to upgrade a bit. Looking to get 20 Inch AR890 wheels (black), and some sort of 275/55/20 All-season tire. I'm not looking to go off road (bad experiences in my youth), I'm just wanting to "upgrade" the look. I currently have the stock 17 inch wheels on the vehicle. I'd basically like to go as large in tire size as I can before I have to lift the vehicle and before I would start to experience "rub". I don't mind going a bit wider, but nothing drastic. If the tires stick out a little (less than an inch), I'm good with it. Thanks in advance for the help.
STL-9 is offline   Reply With Quote Quick reply to this message
Unread 02-17-2014, 09:56 PM   #448
MichiganState88
2011 WK
All the information that you need is in this thread, go to the beginning and start reading. I ended up with the MBTKO wheels in black with 25mm offset and 265/65R18 BFG AT KO. Great all season tire that looks moderately as aggressive as a WK2 does, not a lot of road noise compared to others, good mileage life, good in the snow and mud even if you don't plan to offroad much. Very happy with the 25mm offset, basically flushes out with top of fender. If you get 0 offset you may stick out about an inch. A lot of guys here also like the Nitro Terra Grapplers.
The 265/65R18 gives 31.5 OD, others have fit 32s under with no rubbing reported. Don't forget that larger OD will lower acceleration (can put shifting into odd power bands especially with V6) and raise top end which will leave your speedo off a few mph. IMO going real large also makes the fender clearance look smaller. The last couple points AND offset is the reason I paid more for the 265/65 instead of the 32s. VERY IMPORTANT - with offsets it puts the wheel further from the hub and creates a longer reach when turning fully. This can make a 32 with standard offset fit while a 0 offset MAY rub somewhere. Also if you go with a larger than suggested tire and it sits outside of your fender the risk is that under full articulation if your tire exceeds your articulation limits you can crush your fender.
In my 05wk I experienced about all of this, 0 offset and 31s I had a little rubbing with fresh rubber a couple of times offroading I got my rear tire to touch my fender at full articulation, no damage because it barely touched but I didn't want to repeat it with the new ride.
I got my set-up of 4 delivered to my door from discount tire direct mounted, balanced, gorilla spline lug kit (black), TPMS ($55/tire) and discounted tire warranty for $2k even. Very happy and good price assuming you can handle a jack and install yourself. I will get pictures up eventually but don't have good ones yet.
Unread 02-17-2014, 10:03 PM   #449
MichiganState88
2011 WK
I do have an added question for the rest that know more than I: I have never flattened a BFG KO, KM2 or cooper M&S - with that as my experience I didn't want to pay another $500 for a 5th wheel to sit in my spare well for a life of unused laziness. My new tires are 31.5 OD and the spare I assume is 30.5 to match stock tires. If I DO end up with a flat, will driving 20 miles with one tire that much smaller shred my gears? I know that it isn't a good idea with AWD but is it bad enough that I should never put on my spare even if it is to go 20 miles to a tire shop? What did everyone else do?
Unread 02-18-2014, 12:10 AM   #450
STL-9
2014 WK
First of all, thanks for the the thought that went into this reply. Huge help, and just the guidance I was looking for. I have read through almost all of the pages, but as an amateur, it was a little overwhelming. Thanks for summing it up for me. It feels like 265/65/18 is probably the way for me to go.
