WK2 Tire and Wheel Sizes - Page 26 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > WK2 Tire and Wheel Sizes
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 01-09-2014, 11:11 PM   #376
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Nitrogen fill seems to have lost its popularity, don't know many that still use it on the street. When I had nitrogen (my local tire filled for fee if you bought tires there) I noticed much less pressure changes with temperature changes, i.e I never had to add air in the winter.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
Unread 01-11-2014, 03:19 PM   #377
Medpilot
2014 WK
Originally Posted by goonbash View Post
Are you guys who are swapping to larger sized tires sticking with nitrogen fill? I assume it is more consistent for pressures when it comes to the tpms system .
Thanks
^^^ What they said.
Nitrogen has its uses. We use it in our aircraft tires, but that's only because they are subject to extreme temperature changes and the nitrogen is void of any moisture. As you already know, nitrogen does not expand and contract the same way that oxygen does to temperature changes. The thing to keep in mind is that our atmosphere is made up of 78% nitrogen, so your tires already have 78% nitrogen in them.
I'd take a nitrogen fill if it was free, but I wouldn't pay extra for it. The benefits definitely do not out weigh the costs.
Medpilot is offline   Reply With Quote Quick reply to this message
Unread 01-12-2014, 07:34 PM   #378
OleRoknRola1976
2011 WK
Hi all I am a fresh new member having just finished my profile seconds ago, My first question is can anyone recommend a knoby tire for on and off-road that will fit my stock 20's.... Details are as followed 2011 Grand Cherokee Limited any help would be greatly appreciated....
I can't pretend a stranger is a long awaited friend but I'm willing to give'em all at least one chance...
OleRoknRola1976 is offline   Reply With Quote Quick reply to this message
Unread 01-13-2014, 05:25 PM   #379
13ovsummit
2013 WK
^^^ Welcome! You might take a look at this thread, toward the last, where they discuss Nitto Grapplers for 20" wheels in the snow - with pics ..:
http://www.jeepforum.com/forum/f309/...aster-1954938/
13ovsummit is offline   Reply With Quote Quick reply to this message
Unread 01-14-2014, 06:01 PM   #380
mcwushu
2012 WK
Attachment 998097
With RRO 2.5" Lift
20x9 +25 Offset - American Eagle 50 Series
295/55/R20 - Nitto Trail Grapplers
mcwushu is offline   Reply With Quote Quick reply to this message
Unread 01-16-2014, 01:20 PM   #381
goonbash
Just an FYI. The 275/65r18 Duratracs are a VERY tight fit on my 2014, but do NOT rub. They are such a tight fit that the tire guy called me out in the shop and said 'i think they will rub'. He was more concerned with the passenger rear tire which was very close to the fender liner on the inside toward the front. We got under the jeep and could see a small gap everywhere so we kept going. No rub at all, but it was such a tight fit that it fooled the tire guy for a minute.
goonbash is offline   Reply With Quote Quick reply to this message
Unread 01-16-2014, 02:04 PM   #382
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Have you tried full turns, going over bumps, etc to check for rubbing?
2011 Billet JKUS
Jackal01 is offline   Reply With Quote Quick reply to this message
Unread 01-16-2014, 02:10 PM   #383
Aquaforest
How come so many are going for the 275/65/18 as opposed to a 265/65/18. Wouldn't the 265 give you a little be more piece of mind.
Aquaforest is offline   Reply With Quote Quick reply to this message
Unread 01-16-2014, 02:25 PM   #384
goonbash
Yup. No rubs at all. Speedbumps, full lock turns, all QL heights. if there are no rubs there are no rubs, trying them in the real world on my vehicle gives the best kind of peace of mind instead of wondering if I paid a lot for bigger all-terrains without getting all I could because I needed an uneccessary margin of error that kept me from getting the biggest contact patch I could for mountain weather and terrain.
Seatbelts on toilets might give people peace of mind too, others don't need them.
Unread 01-16-2014, 04:00 PM   #385
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Awesome. So that size works without any issues.
2011 Billet JKUS
Unread 01-16-2014, 05:17 PM   #386
goonbash
Correct, on my 2014 diesel. The closest tire to fender liner proximity I can find is on the inside front of the right rear tire, but still no rub, I can squeeze a finger into the tightest spot.
Unread 01-16-2014, 05:44 PM   #387
Aquaforest
Well that's good to hear that there are no rubs, since I'd rather go with the 275 size as well. I just want to see more off road real-world experience with this size.
Unread 01-16-2014, 05:58 PM   #388
goonbash
Well if you have quadralift it is highly unlikely that any off road situation you can theorize about will bounce or bury the tire further into the fender well than entry/ exit mode does.
Unread 01-16-2014, 06:08 PM   #389
goonbash
Street manners are better than I thought they would be too. A little noisier than stock but not much, at least not over the diesel which is pretty quiet for a Diesel engine.
Unread 01-16-2014, 06:12 PM   #390
Aquaforest
No QL. I realize you have that, so reason I'm being cautious.
