WK2 Tire and Wheel Sizes - Page 21 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > WK2 Tire and Wheel Sizes
NEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDRough Country Jeep Suspension Deals at Rockridge 4WD!ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO
Unread 10-04-2013, 10:29 AM   #301
1quick1
2014 WK
So I've been reading and reading trying to find the answer (I'm moving fast as there's a good deal on the tires on Craigslist I don't want to miss) and it looks like 255/75/17 will definitely fit on the 17x8.0 stock Laredo wheels. Now I'm trying to figure out if it'll just rub like crazy.
The stock tires are 245/70/17 which from my math is 9.64'' wide and 30.5'' in diameter
The Rubicon tires are 255/75/17 which is 10.04'' wide and 32'' in diameter
Since I'll use the same wheels clearing the calibers and all that won't be an issue. It seems like I should be able to fit a .4'' wider and 1.5'' taller tire but I'm guessing it'll rub on full lock.
2006 Jeep Liberty - sold
2009 Jeep Liberty Limited - sold
2012 JK Rubicon - sold
2014 Jeep Grand Cherokee Laredo (current vehicle)
32'' BFG KM's 255/75/17's on stock Laredo wheels
1quick1 is offline   Reply With Quote Quick reply to this message
Unread 10-04-2013, 03:39 PM   #302
1quick1
2014 WK
So I've been researching all day and nobody here responded so I couldn't find a clear answer. I notice A LOT of people running 275/65/18's which are the same diameter and slightly wider than the 255/75/17's. So by that logic I'm going to take a chance. I'm going to pick up the tires and I have an appointment in 3 hours to have them installed on my stock 17x8.0 Laredo wheels. I really hope they fit without rubbing.
Unread 10-04-2013, 08:42 PM   #303
1quick1
2014 WK
255/75/17 JK Rubicon wheels fit with no rub. (haven't wheeled though)
Unread 10-07-2013, 07:00 AM   #304
knaphara
2012 WK
bfg AT 265/65/18 on mb razors 8.5" 24 mm offset (with QL)
Originally Posted by ctgreen77 View Post
Black Rock Intruder 910B 18x8.5 with 265/65r18 Bridgestone AT RH-S. Pic is at ORI.
Attachment 448552
Attachment 448553
Note: Due to BS and Offset this is the biggest tire that will fit on these wheels if you have QL. I tried a Cooper AT3 and GY MTR in 275/65r18 with no luck.
Bfg 265/65/18 with mb razors is another example of successful combo with QL and no rubbing. I just love those tires and the offset is pretty good, could go with higher offset to avoid stones flying around.
Will add pictures when I have figured it out.
knaphara is offline   Reply With Quote Quick reply to this message
Unread 10-18-2013, 09:25 PM   #305
salmojoe
2013 WK
Attachment 448552
Attachment 448553
I'm looking at doing similar for my '13 GC Trailhawk - what did you buy for the TPMS? Any specific product?
salmojoe is offline   Reply With Quote Quick reply to this message
Unread 10-18-2013, 10:07 PM   #306
salmojoe
2013 WK
I looked over this thread, did a forum search - no luck:
Will 265/70R18 fit on a QL WK2? I am looking at the General Grabber AT-2 on a 18x8.5 Black Rock 910B wheel. I am also installing the Bushwacker Fender Flares, which supposedly offer 0.5" of extra room. Thanks everyone.
Unread 10-21-2013, 10:23 AM   #307
webspoke
265/70/18 is a little tall without a lift kit. With QL at normal rideheignt it will look a little squeezed. 265/65 is an easier fit, still 1" taller than stock (31.5"). If you want a chunkier look, you can go with 285/60/18 like I did, still 31.5" tall, but almost an inch wider.
2013 White V8 Limited, 285/60/18 Terra Grapplers, 25000 miles problem free
2011 Black V8 Overland, retired at 46000 miles with QL problems
webspoke is offline   Reply With Quote Quick reply to this message
Unread 10-21-2013, 10:58 PM   #308
gabbagabba
2014 WK
I did the 255 70 18 for off road and have been very happy, same width, 32" Diameter. Fits a QL GC no issues. What I like is I can now air down and not lose any ground clearance from stock non aired down (probably still higher actually. I figure I am at 12" ground clear or so in OR2
gabbagabba is offline   Reply With Quote Quick reply to this message
Unread 10-21-2013, 11:01 PM   #309
gabbagabba
2014 WK
My guess is no, too wide for the height. 255 70 18 gets you a 32"
Unread 10-21-2013, 11:26 PM   #310
webspoke
A 275/60/18 is 32.5-33" tall depending on brand. With the black rock wheels pushing the tire out 26mm more than stock, you may need to trim the front fender liner to get clearance when the wheel turns. The rear should be ok. Using wrangler wheels with 45mm offset would tuck them in tighter and help with clearance.
Unread 10-22-2013, 08:10 AM   #311
XJ2WK2
2011 WK
You sure?
XJ2WK2 is offline   Reply With Quote Quick reply to this message
Unread 10-22-2013, 08:46 AM   #312
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Originally Posted by XJ2WK2 View Post
You sure?
See post 295. There are some variance between brands, so you may want to check the specs at the tire manufacture's web site.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
Unread 10-23-2013, 04:20 PM   #313
webspoke
You sure?
Typo, I meant the size the OP referred to, 265/70/18.
Unread 11-06-2013, 09:13 AM   #314
lope2919
Need new winter wheels and tires
Just bought a 2013 Overland and need some ideas on winter wheels and tires. The choices for wheels and tires are limited. Any ideas?
lope2919 is offline   Reply With Quote Quick reply to this message
Unread 11-06-2013, 02:50 PM   #315
ColdCase
ColdCase's Avatar
2011 WK
I and many here use OEM 18 inch wheels with blizzacks with good results. I needed the best ice and snow traction I could get as we have to get out regardless of weather. Check the wheel and tire thread for more ideas http://www.jeepforum.com/forum/f309/...hread-1141422/
