WK2 Tire and Wheel Sizes - Page 20 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > WK2 Tire and Wheel Sizes
Only 2 Days left to win $3,800 Jeep Parts!Rough Country Jeep Suspension Deals at Rockridge 4WD!Nitro Gears now available in stock at JeepHut
Unread 09-19-2013, 12:28 PM   #286
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Originally Posted by mfa81 View Post
Hi guys
I'm just trying to confirm something before pulling the trigger. It's my understanding that I can go down from 20" to 18" on the 2014 JGC Summit 5.7.
I've found a good deal on a 2014 JGC Limited take off wheels and I wanna buy for a set of snow tires to use on the Summit, I've heard some issues regarding offsets on different wheels but I'm assuming both Jeeps should be structurally the same and I would have no issues using the Limited wheels on the Summit.
Am I correct? Is this as simple as just put the 18" wheels and drive kinda task?
Thank you!
You need to familiarize yourself with the Rules and Guidelines. We have multiples threads dedicated to wheels and tires including one solely for wheel and tire sizes.
Merged.
2011 Billet JKUS
Jackal01 is offline   Reply With Quote Quick reply to this message
Unread 09-19-2013, 12:36 PM   #287
mfa81
Originally Posted by Dave2002ti
Without any problems. I can recommend Blizzaks in 18" size for snow tires. thats what I have on my GC in the winter. Michelins for approx $50 more per tire.
thanks! yeah thinking I'm gonna get the blizzaks, found quite good reviews on them most better than the michelins and also it's cheaper! both have rebates going on right now, so good time to buy!
Originally Posted by Jackal01
You need to familiarize yourself with the Rules and Guidelines. We have multiples threads dedicated to wheels and tires including one solely for wheel and tire sizes. Merged.
my bad man, sure will be whatching out the forum to get familiar with the rules!
mfa81 is offline   Reply With Quote Quick reply to this message
Unread 09-19-2013, 01:09 PM   #288
Jackal01
Jackal01's Avatar
2011 JK Wrangler
No problem, dude. Just trying to keep everything organized. That way people don't have to hunt for hours and hours. They can search or see "hey..there is a thread on wheel sizes and I have a wheel size question". Done.
2011 Billet JKUS
Unread 09-19-2013, 02:39 PM   #289
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Hi guys
WK2 18 and 20s are interchangeable between trims. 17s typically only work on V6s with standard brakes. Stay with the OEM sized tires and there is no problem.
Many here have a similar setup, OEM overland 20s with a highway tire, OEM standard 18s with Blizzacks (or AT). Blizzacks have excellent ice and snow traction, but if you spend a lot of time on dry highways, they will wear fast.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
Unread 09-19-2013, 02:54 PM   #290
mfa81
I don't usually get much snow in the city that would last for days, so I end up driving quite a bit on dry as well during the winter. Would the X-ice Xi2 be a better option in this case? or any other tire... I was looking into those two actually...
Unread 09-19-2013, 03:17 PM   #291
ColdCase
ColdCase's Avatar
2011 WK
Any tire with a snow flake symbol would work for you, unless you deal often with ice and want the best traction you can get. If so Blizzacks are the way to go. Nokian make decent snow tires also. V-ice is decent.
Unread 09-20-2013, 10:02 AM   #292
gabbagabba
2014 WK
Originally Posted by jam1995 View Post
I switched tires from the OEM 18" Michelins to 275/65/18's on my 12 GC Larado X that I had from a Navigator. I like the look and it seems to ride fine without any rubbing. I have not considered until now, the impact on the All-Wheel Drive system in the event of flat. I keep my stock spare tire. It appears the stock tire rotates 660.8 times per mile, while my new tires rotate only 628.8 times per mile. If I had a flat and replaced the flat with my spare would there be an impact to the drive system? If there is a flat should a deflate my tires to match the height of the spare or am I just over thinking this?
deflating wont help much at all. it is not diameter but cirumference that matters to drivelive
call AAA
gabbagabba is offline   Reply With Quote Quick reply to this message
Unread 09-21-2013, 12:25 PM   #293
jeffreybehr
2013 WK
Originally Posted by gabbagabba View Post
deflating wont help much at all. it is not diameter but cirumference that matters to driveline.
And you think the tire radius does NOT directly affect circumference? The effective circumference is a direct product of the loaded radius of the tire.
Former Jeeps--'95 Cherokee and '99 Grandokee.
jeffreybehr is offline   Reply With Quote Quick reply to this message
Unread 09-21-2013, 03:01 PM   #294
ColdCase
ColdCase's Avatar
2011 WK
What he is saying is that the tire circumference is not going to change by deflating the tire, those steel belts do not shrink. The tire just goes out of round, miss shapes. The tire will have the same number revolutions per mile.
Now it does help reducing the vehicle height for those low clearance garages.
Unread 09-21-2013, 06:07 PM   #295
gabbagabba
2014 WK
Do your research and you'll see I'm right. In math class you are right, with a rubber tire I'm right, as coldcase said.
Unread 09-26-2013, 11:41 AM   #296
Dave2002ti
2012 WK
Blizzaks vs X-ice
Michelin X Ice will be $40+ a tire more than the Blizzaks. X Ice may have an advantage on dry roads.
Dave2002ti is offline   Reply With Quote Quick reply to this message
Unread 10-03-2013, 02:40 PM   #297
Nisa
2014 XJ Cherokee
Full Size Spare - Shouldn't be Driven On?
I purchase my 2014 Grand Cherokee Limited last week and have been going round with the dealer regarding the spare tire. My window sticker says "Full Size Spare Tire" is included in my purchase price. The tires on the vehicle are Michelin Latitude Tour 265/60/R18, but the spare is a 245/65/R18. I feel like a "Full Size Spare" should be the same tire as all the rest on the vehicle. I called Jeep and they said "the full size spare should only be used for emergency purposes, and is not intended for your to drive on it any farther than the nearest repair location." What?!? A full size spare shouldn't be driven on? What then makes it different from a NOT-full size spare? Any comments?
Nisa is offline   Reply With Quote Quick reply to this message
Unread 10-03-2013, 09:54 PM   #298
1quick1
2014 WK
Does anyone know if 255/75/17's (Wrangler Rubicon tires) will fit on 2014 stock Laredo wheels and would it rub?
2006 Jeep Liberty - sold
2009 Jeep Liberty Limited - sold
2012 JK Rubicon - sold
2014 Jeep Grand Cherokee Laredo (current vehicle)
32'' BFG KM's 255/75/17's on stock Laredo wheels
1quick1 is offline   Reply With Quote Quick reply to this message
Unread 10-04-2013, 09:11 AM   #299
1quick1
2014 WK
Originally Posted by 1quick1 View Post
Does anyone know if 255/75/17's (JK Wrangler Rubicon tires) will fit on 2014 stock Laredo wheels and would it rub?
I've read this entire thread and I see people using JK Rubi wheels/tires with a small backspace but the ones I saw are running a spacer lift.
So my questions are can you run the 255/75/17's on the stock Laredo 17'' wheel and if so is anything additional needed?
Second, is a spacer lift entirely necessary for JK Rubi wheels and tires?
I can pick up Rubicon tires or wheels/tires fairly cheap being in Colorado.
Unread 10-04-2013, 10:03 AM   #300
ColdCase
ColdCase's Avatar
2011 WK
When any manufacture says full sized spare now days, it just means the spare is the same diameter and load rating as the others. Its not just Jeep. Many don't have a spare, have spare donuts, or have collapsable spares. Full size is a marketing term to differentiate from those types. They've been using those terms for years, not so much on trucks where space is not an issue.
Do you have a better term?
