WK2 Tire and Wheel Sizes - Page 19 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > WK2 Tire and Wheel Sizes
Attention seahawks fans!!! Want to save some $$$ ??!!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineCount Down to KOH Sale!
Unread 06-29-2013, 12:42 PM   #271
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Originally Posted by Sean101687 View Post
I clear 275/70r18 with no tub at all even at full turn on a non QL..just have RRO leveling kit on it..they're close but no rub at all
What about turning while flexing or going over an obstacle?
Sent from my underground lair.
2011 Billet JKUS
Jackal01 is offline   Reply With Quote Quick reply to this message
Unread 07-02-2013, 04:22 PM   #272
Redline85338
So Is anyone running big rims on the 14' with QL? Im looking into 24"s x 9.5" for the winter months here in Az. Im looking into a few that are 9.5" with a +18 offset with Backspace of 5.59".But if it was lets say -18 offset but with a 4.5" Backspacing, isn't that basically the same placing on the car, just a deeper rim? Or close too? The tire will be 285/35/24 and it is 31.89" tall. How far will it stick out of the fender? Im trying to get as flush as I can.......... Thanks peeps
Redline85338 is offline   Reply With Quote Quick reply to this message
Unread 07-22-2013, 12:58 PM   #273
WKdeuce
Originally Posted by sac01 View Post
Just upgraded to 20" SRT replicas and Nitto 275/55r20...No rubbing (without QL) but will be installing RRO leveling kit next weekend just to be sure.
Cool, I just got a hell of a deal on those wheels at the pa jeep show this past weekend. You think a 285/55-20 would fit?
2011 5.7L WK2 | 5.3L TJ work in progress
Rust in Pieces Blue
JEEP FIEND CLUB
WKdeuce is offline   Reply With Quote Quick reply to this message
Unread 07-22-2013, 01:15 PM   #274
sac01
2011 WK
I don't recommend a 285/55 r20 simply because of how tight the 275 was up front. Before installing the leveling kit I could not even get my hand inserted between the front of the wheel and the fender. I suspect that the 285s will rub constantly without a leveling kit and possibly even rub some with it.
2011 GC Laredo X - Dark Charcoal Pearl
5.7L Hemi - Off-Road Adventure I Pkg. - RRO Leveling Kit
430N Media Center & Single Pane Sunroof
sac01 is offline   Reply With Quote Quick reply to this message
Unread 07-22-2013, 02:23 PM   #275
WKdeuce
Fair enough, thanks man.
Rust in Pieces Blue
JEEP FIEND CLUB
Unread 07-22-2013, 03:59 PM   #276
MartyA
2012 WK
Not sure if you're looking for another vote (and this really belongs in the wheel and tire thread) but I tried 285/55/20 and even with the lift and spacers they just didn't fit without rubbing somewhere. The 275/55/20's with a leveling kit and no spacers fit beautifully.
MartyA is offline   Reply With Quote Quick reply to this message
Unread 07-23-2013, 07:55 PM   #277
mike__o
2012 WK
Thinking about getting some 275/65-18s on my 12 v6 overland with ql (seems to be the largest that will fit ql on stock rims?), top contender so far is the firestone destination a/t, anyone here go from stock ora2 Michelins to this tire? If so care to comment on any mpg changes, road noise, highway road handling differences and rain/snow? Would the larger size A/T give a noticeably smoother ride over destroyed pothole roads / speed bumps or make it seem sluggish on turns? Car sees mostly highway, pothole covered pavement and some 4x4 trails on road trips to CO, also plenty of snow in winter.
mike__o is offline   Reply With Quote Quick reply to this message
Unread 08-17-2013, 04:39 AM   #278
Redline85338
hey, so do you guys think a 22x9.5 will fit a 14' overland? It has a +15 offset but the back spacing is 5.84. So wouldnt the lower back spacing make up for the +15 offset? Wouldnt it be the same like if I went with a +30 offset and a 6.4" back spacing, just the +15 offset would have more of a lip, right?
Unread 08-17-2013, 03:26 PM   #279
Saltriverfolk
2013 WK
Cooper AT3 Feedback
Originally Posted by chrisbradley_20 View Post
Pulled the trigger on the cooper discoverer at3
265/65 r18 and they fit fine. Much better than the oe michelins that I barely milked 30k miles out of.
Are you still happy with the Cooper 265 65 18s?
Saltriverfolk is offline   Reply With Quote Quick reply to this message
Unread 09-18-2013, 01:17 PM   #280
Truggy
2011 JK Wrangler
Originally Posted by NewJKon37's View Post
...LT275/65R18 Nitto Terra Grapplers... I mounted them on some black chrome Diamo 39 Black Chrome Wheels.
What kind of backspacing on those rims, same as factory? I just got my 2013 GC Trailhawk and looking to change the tires as soon as this are done. Just need to know if I cna keep the same rims or do I need to get new ones.
Carolina Trail Stalkers
Your Eastern Carolina Family Oriented Off Road Group
http://www.facebook.com/#!/groups/252949984830602/
Truggy is offline   Reply With Quote Quick reply to this message
Unread 09-18-2013, 10:17 PM   #281
jam1995
2012 WK
I switched tires from the OEM 18" Michelins to 275/65/18's on my 12 GC Larado X that I had from a Navigator. I like the look and it seems to ride fine without any rubbing. I have not considered until now, the impact on the All-Wheel Drive system in the event of flat. I keep my stock spare tire. It appears the stock tire rotates 660.8 times per mile, while my new tires rotate only 628.8 times per mile. If I had a flat and replaced the flat with my spare would there be an impact to the drive system? If there is a flat should a deflate my tires to match the height of the spare or am I just over thinking this?
jam1995 is offline   Reply With Quote Quick reply to this message
Unread 09-18-2013, 10:43 PM   #282
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Not sure when the stability control or traction control would kick in, but if you have QT I there should not be any driveline issues. That is a completely open system but I wouldn't drive too far. QT II is not completely open. A few slow miles in an emergency is probably not going to hurt regardless, but don't use 4 low.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
Unread 09-19-2013, 11:09 AM   #283
jam1995
2012 WK
Thanks ColdCase. I have QT 1.
Unread 09-19-2013, 11:52 AM   #284
mfa81
2014 JGC Limited takeoff wheels on 2014 JGC Summit 5.7
Hi guys
I'm just trying to confirm something before pulling the trigger. It's my understanding that I can go down from 20" to 18" on the 2014 JGC Summit 5.7.
I've found a good deal on a 2014 JGC Limited take off wheels and I wanna buy for a set of snow tires to use on the Summit, I've heard some issues regarding offsets on different wheels but I'm assuming both Jeeps should be structurally the same and I would have no issues using the Limited wheels on the Summit.
Am I correct? Is this as simple as just put the 18" wheels and drive kinda task?
Thank you!
mfa81 is offline   Reply With Quote Quick reply to this message
Unread 09-19-2013, 12:14 PM   #285
Dave2002ti
2012 WK
It Should Work
Without any problems. I can recommend Blizzaks in 18" size for snow tires. thats what I have on my GC in the winter. Michelins for approx $50 more per tire.
Dave2002ti is offline   Reply With Quote Quick reply to this message
