WK2 Tire and Wheel Sizes - Page 17 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > WK2 Tire and Wheel Sizes
Only 2 Days left to win $3,800 Jeep Parts!Count Down to KOH Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-23-2013, 03:27 PM   #241
sac01
2011 WK
Originally Posted by gabbagabba View Post
Does anyone know if a 17" rim will fit on a '14 limited V6 ORA2, how do I find our if I have the HD brakes or should I be able to tell looking inside my 18" rims for clearance
Thx
I believe only the V8's get the HD brakes....more weight and power needs more stopping power. Not sure on the 2014 models though so I would check a couple sources to be sure.
2011 GC Laredo X - Dark Charcoal Pearl
5.7L Hemi - Off-Road Adventure I Pkg. - RRO Leveling Kit
430N Media Center & Single Pane Sunroof
sac01 is offline   Reply With Quote Quick reply to this message
Unread 05-23-2013, 04:52 PM   #242
Jackal01
Jackal01's Avatar
2011 JK Wrangler
That is the point of his post.
2011 Billet JKUS
Jackal01 is offline   Reply With Quote Quick reply to this message
Unread 05-23-2013, 07:15 PM   #243
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Thx
If your rear brake rotors are vented, you have HD brakes. If solid then std brakes. So look at the edge and if it looks like two rotors with a vented sandwich, then they are vented. I posted a drawing awhile ago, I'll see if I can dig it up.
Unless there has been a recent running change, none of the Laredos have HD brakes (vented rears), just the Limited and Overland V8s.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
Unread 05-23-2013, 07:27 PM   #244
OtisDog1
2012 WK
Sac - Jeep looks good. Throw some RRO lift photos up when you get it done if you don't mind.
Are you putting it on or having it done?
OtisDog1 is offline   Reply With Quote Quick reply to this message
Unread 05-23-2013, 09:08 PM   #245
sac01
2011 WK
Will do! I am putting it on with the help of bro-in-law who is a mechanic.
Unread 05-24-2013, 06:16 AM   #246
gabbagabba
2014 WK
Thank you, I will check it out. I have a limited so prob a no go. I also looked yesterday and the clearance to the inside of the current 18's is pretty tight?
I appreciate the help!!
gabbagabba is offline   Reply With Quote Quick reply to this message
Unread 05-28-2013, 08:55 AM   #247
gabbagabba
2014 WK
biggest tire on QL WK2?
Has there been any conclusions about the biggest tires you can put on a QL WK2.
I have read through the thread and also inspected at diff heights on mine
I see no issue with 265/65/18
I cannot do 17" wheels d/t brakes
I am considering 275/65/18 with < factory offset rim or spacer
Help plz
Unread 05-28-2013, 11:35 AM   #248
Alaska-HWY JK
I put 275/55/20 GY Silent Armor on Boss 335B with +25 offset instead of the +54 offset of the OEM rims on my wife's Overland last May. It's just scrubs the felt going lock to lock, no one drives like that unless they're drifting so I think it's OK. We havnt had any issues in a year. It has QL. The odometer is out 4%, not a big deal. A 275/65/18 of the same brand will be .2" taller.
Alaska-HWY JK is offline   Reply With Quote Quick reply to this message
Unread 05-29-2013, 08:52 AM   #249
WKdeuce
Originally Posted by Jackal01 View Post
aaeeeehhhhhh............Not so much, IMHO.
Traded those.
Got a set of the other Saharah 18s.
with MTRs on them!
Looking for a nice graphite/gunmetal paint for them. Don't want silver. Don't want black.
2011 5.7L WK2 | 5.3L TJ work in progress
Rust in Pieces Blue
JEEP FIEND CLUB
WKdeuce is offline   Reply With Quote Quick reply to this message
Unread 05-29-2013, 09:55 AM   #250
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Nicely done!! Looking forward to seeing them painted.
2011 Billet JKUS
Unread 05-30-2013, 08:10 AM   #251
WKdeuce
decided to see if I like the fitment before I paint them...
18x7.5 et44.45
275/65-18 MTR.
Rust in Pieces Blue
JEEP FIEND CLUB
Unread 05-30-2013, 09:32 AM   #252
gabbagabba
2014 WK
18x7.5 et44.45
275/65-18 MTR.
Do you have QL?
How is your clearance?
Unread 05-30-2013, 09:56 AM   #253
WKdeuce
Do you have QL?
Nope. Early build 2011 Overland that didn't have QL.
It hasn't rubbed on anything that I've heard.
Rust in Pieces Blue
JEEP FIEND CLUB
Unread 06-02-2013, 04:42 AM   #254
Redline85338
24's on the wk2 overland
Hey Guys, Ok so I am thinking of getting a set of 24's for the fall-spring season. I live in Az and we only use the 4x4 during the summer season for the boat and jet skis and ill use the factory wheels for that. I see some people have put 24's on the srt8's but wanted to know if it will fit our 14' overland? So for the one's out there that know if they will fit with the Qudra-Lift suspension please let me know your thoughts. I do not care to hear from you guys that think its still or ugly or rough ride or etc. Its my 50k Jeep and i will do as I please. I just would like to hear from the people that know about the suspension and the fitment. I was thinking 255-275 and 30-40 series. Here is a picture of kind of the direction I am thinking...... thanks for the help guys
Last edited by Jackal01; 06-02-2013 at 10:32 AM.. Reason: You asked a wheel and tire size question...your thread moved to the thread dedicated to wheel and tire sizes.
Redline85338 is offline   Reply With Quote Quick reply to this message
Unread 06-05-2013, 07:52 AM   #255
sac01
2011 WK
Updated pics
Sharing some update pics of my setup with 275/55r20's with RRO Leveling Kit installed. Gives needed clearance up front where tires would slightly rub on some big dips in the highway...it did fine over abrumpt bumps but those dips in the highway at speed would cause the outer edge of right tire to barely nip the felt liner just inside the black fender trim. All is well now...
