WK2 Tire and Wheel Sizes - Page 14 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > WK2 Tire and Wheel Sizes
Savvy FOX IFP 4" Lift Shocks in StockOnly 2 Days left to win $3,800 Jeep Parts!Rough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 04-10-2013, 08:40 PM   #196
illflo
2012 WK
Help!
I've been through the search function and both wheel and tire threads and have found numerous mentions of speedo inaccuracy after moving to bigger tires. I can't seem to find anybody who has a solid answer to whether or not anybody can recalibrate speedos to accommodate larger tires without using a tuner. Am I missing something obvious or is the only way to recalibrate the speedo to go out and buy a tuner?
'12 V6 WK2 Laredo X
illflo is offline   Reply With Quote Quick reply to this message
Unread 04-10-2013, 08:51 PM   #197
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Originally Posted by illflo View Post
Help!
Dealer can reprogram the computer. I did last year although I have no way to really tell if they did.
Sent from my underground lair.
2011 Billet JKUS
Jackal01 is offline   Reply With Quote Quick reply to this message
Unread 04-11-2013, 08:49 AM   #198
illflo
2012 WK
Jackal,
Thanks! Wasn't sure if I had missed something. The best way to double check would be to use a dash-mounted GPS. Most will display your speed using the time it takes you to travel a certain distance based on your GPS coordinates, so it's not biased by wheel size. Set your cruise to 60, give the GPS a minute to catch up, and see if it reflects that you're traveling 60 mph. You want to stay at speed as long as possible to insure the GPS gets a good signal and read (They normally update every second or so). It's a quick and easy way to make sure your speedo is accurate. If you don't own a GPS see if you can borrow somebody's. 70 or 80 would be a better speed to use (because speedo inaccuracies will be exaggerated at higher speeds) but some folks don't have roads on which they can drive that fast.
'12 V6 WK2 Laredo X
Unread 04-11-2013, 10:33 AM   #199
kkreit01
If they are 17", no. I've read only 18"+ will fit. Those look like 17s?
kkreit01 is offline   Reply With Quote Quick reply to this message
Unread 04-11-2013, 11:17 AM   #200
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Jackal,
I did that the day I did it. I even downloaded a couple speedo/GPS apps along with my GPS AND even drove by one of the automated speedo signs by LE on the side of the road. All the readings were 1 or 2 off the Jeep speedo.
2011 Billet JKUS
Unread 04-11-2013, 01:25 PM   #201
Alaska-HWY JK
This is the first I've read where any dealer can reprogram for differant sized tires on a GC.
Alaska-HWY JK is offline   Reply With Quote Quick reply to this message
Unread 04-11-2013, 09:05 PM   #202
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
That must have bee a recent change to their software. The tire factor menu item used to not even be presented for the WK2, as they wouldn't need to change it anyway (all the OEMs have the same tire diameter regardless of wheel size). Other chrysler vehicles can be programed by picking a tire factor from a menu, but the only factors presented to the tech are those for OEM sizes. Nothing aftermarket. On my 2006 RAM I just got used to adjusting 5%.
Running oversize tires on the WK2 is not an approved Jeep mod or an offered accessory.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
Unread 04-12-2013, 10:37 AM   #203
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Although I do not trust the dealership with much when I asked them to reprogram the computer for my larger tires they said they could and did. Now, post larger tires and before the reprogram my speedo displayed speeds very rapidly ie: traveling 40 mph the EVIC would "flicker" 40-41-39 etc very quickly. After the reprogram the the EVIC/speedo worked as normal. Not sure what was really performed since the invoice only said "customer requested reprogram of computer for larger tires" and charged me $60. I think they did however I cannot know that 100% since I cannot see the computer specs obviously. And this was a year ago I did this.
2011 Billet JKUS
Unread 04-12-2013, 12:33 PM   #204
jacko15
2014 WK
Did you try checking your speed against a GPS?
Hers: 2008 Jeep Compass Sport
Mine: 2014 Jeep Grand Cherokee Overland V/6 ORA II
Michelin LTX M/S 2's
jacko15 is offline   Reply With Quote Quick reply to this message
Unread 04-12-2013, 01:03 PM   #205
Jackal01
Jackal01's Avatar
2011 JK Wrangler
yes.
http://www.jeepforum.com/forum/f309/...l#post15280893
2011 Billet JKUS
Unread 04-12-2013, 04:45 PM   #206
jacko15
2014 WK
Sorry, I missed that.
Unread 04-12-2013, 06:59 PM   #207
Jackal01
Jackal01's Avatar
2011 JK Wrangler
No problem dude.
2011 Billet JKUS
Unread 04-15-2013, 04:39 PM   #208
silve
2013 WK
Fuel Boost Wheels; which will fit? if any...
Anyone know which, if any of these wheels will fit our wk2's the best? wheel is fuel boost. just have a stock laredo with regular suspension. hope someone can help me out!
http://www.4wheelparts.com/Wheels/Wh...Style_PQ=Boost
silve is offline   Reply With Quote Quick reply to this message
Unread 04-15-2013, 04:40 PM   #209
silve
2013 WK
to be more clear, which offset and backspacing combo would fit our wk2's, if any
Unread 04-15-2013, 06:30 PM   #210
Jackal01
Jackal01's Avatar
2011 JK Wrangler
There are tire and wheel threads. Moved.
2011 Billet JKUS
