WK2 Tire and Wheel Sizes - Page 13 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > WK2 Tire and Wheel Sizes
Savvy Billet LED Tail LightsRough Country Jeep Suspension Deals at Rockridge 4WD!Alloy usa heavy duty ball joint kits
Unread 03-11-2013, 10:08 PM   #181
vaduro
Wk ProComps
Cant answer all of your questions but I was looking at the same set to beat on and have my 20's powder coated to keep it classy.
I had an online chat with a rep and he confirmed that these fit a stock Laredo WK2. They have 2 steel types to choose form and don't ship until mid April
vaduro is offline   Reply With Quote Quick reply to this message
Unread 03-13-2013, 09:11 PM   #182
shmoods
2014 WK
I spoke to my dealer today, and they told me on 2014s they have to program tire and wheel size into the computer or it throws all kinds if computer errors. Anyone heard of this? They said they won't know if the 14 will allow bigger tires on the new computer? Seems strange to me, so how would it react with lifts etc.
2014 Grand Cherokee Summit
shmoods is offline   Reply With Quote Quick reply to this message
Unread 03-14-2013, 12:49 PM   #183
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
2014s could be different but, unlike several other chrysler vehicles, all WK2 model OEM tires have the same diameter. Because there are no factory options, there has been no way to set a different tire size, doesn't show up in the test equipment menu. Tire factors on other chrysler vehicles could be adjusted, but since 2006 or so, only to a factory offered or factory approved tire size. Some tuners can set tire factors, however.
In other words, the factory says you should run only OEM sizes, so they don't bother giving the tech a set size feature.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
Unread 03-15-2013, 05:35 PM   #184
brn2skifst
2012 WK
I really like the KMC XD801's. I have searched the forum and can't find a similarly spec'd wheel being used. They are 18x9 5" backspacing 0 offset. I was planning on a 275/60 or a 265/65 with a mild tread pattern because Most of my off-road is sand. Any thoughts? Thanks in advance
brn2skifst is offline   Reply With Quote Quick reply to this message
Unread 03-15-2013, 07:07 PM   #185
ColdCase
ColdCase's Avatar
2011 WK
Those 0 offset wheels will push the tires out 2 1/4 inches from OEM. You could have some fender clearance issues.
Unread 03-15-2013, 07:50 PM   #186
brn2skifst
2012 WK
Whats the backspacing on the stock 18's or 20x8's? 5.7" or so?
Unread 03-15-2013, 08:33 PM   #187
ColdCase
ColdCase's Avatar
2011 WK
The sticky below has most of the wheel specs. OEMs have +56 offset, 6 1/4 in backspacing... think front wheel drive vehicles.
http://www.jeepforum.com/forum/f309/...pedia-1372403/
Unread 03-16-2013, 06:40 AM   #188
brn2skifst
2012 WK
Wow! Thanks Cold Case. Your knowledge of the WK2 is much appreciated and definately keeps the WK2 thread moving!
Unread 03-18-2013, 10:18 AM   #189
shmoods
2014 WK
I assume these wheels would work with stock tires, but would they fit on an Overland with the Srt8 Tires?
http://www.ebay.com/itm/170904678352...84.m1423.l2649
Unread 03-22-2013, 12:29 PM   #190
OverlandSummitt
I have ordered a set of wheels and I am unsure if they will fit considering all the reasearch I have done, as far as fender clearance, offset, and caliper clearance.
2011 Jeep GC Overland Summit Hemi, with Quadra-Lift
Wheel setup: Fuel Hostage Chrome, 18x9, 20ET, 5.8" backspace
Tire setup: Nitto Terra Grappler, 275/65/18
Does any one have any input or experience with a simular setup? Im specifically concerned about the low offset and clearing the Hemi calipers. The wheels are on back order so they are not available for a test fit.
OverlandSummitt is offline   Reply With Quote Quick reply to this message
Unread 03-27-2013, 10:01 AM   #191
OverlandSummitt
To answer my own question, yes they fit. Kinda.
Here are my notes for anyone thinking of an aggressive offset and a 32" tire with QL:
Park mode: No touching, but don't think about turning your wheel or you may rip off the front bumper. Would not reccomend driving at this height.
Normal: Tires kiss the inner fender felt shroud and front bumper at full tilt. I removed excess fendershroud and secured the rest with screws and washers to keep it against the body. No longer have issues at any speed and turning. I have pics if anyone is interested.
Offroad height 1 and 2: No issues
Unread 03-27-2013, 10:35 PM   #192
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Duh!!
2011 Billet JKUS
Jackal01 is offline   Reply With Quote Quick reply to this message
Unread 04-08-2013, 11:33 PM   #193
shekshishekki
2013 WK
Just to confirm...i have a 2013 overland with oem 20" wheels.
Will a 275/55R20 fit without rubbing anything at all the QL heights?
What about a 275/60R20?
shekshishekki is offline   Reply With Quote Quick reply to this message
Unread 04-10-2013, 03:02 AM   #194
Tulsazj
Will these wheels fit over WK2 hemi brakes??
http://www.boldride.com/ride/2013/je...cept#gallery/2
I love the look and stance of this concept for the 14' Trailhawk and these are the wheels that came on the new 13' Rubis, will these wheels fit my hemi wk2 Altitude Edition? i've checked out the wheel sticky but found nobody that has ran these wheels yet, thanks for the input and help guys.
Tulsazj is offline   Reply With Quote Quick reply to this message
Unread 04-10-2013, 10:28 AM   #195
OverlandSummitt
275/55/20 should work. That is a 31.9" tire. I have a 32.1" tire on my QL Hemi. Please see post #185 for details on this size.
I really doubt 275/60/20 will fit as that is a 33" tire.
