WK2 Tire and Wheel Sizes - Page 10 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > WK2 Tire and Wheel Sizes
Suspension, Wheel and Tire Time at KrawlOff-Road.comZone Offroad - Jeep Forum PromotionRough Country Lift Kits and Parts!
Unread 08-29-2012, 06:21 PM   #136
jgc4ever
2012 WK
ktwillis,
I like the look of your Jeep. I was think of doing the same with the chrome removed but with 20" Overland Summit Bright Polished Wheels. Wish someone had pictures of that.
jgc4ever is offline   Reply With Quote Quick reply to this message
Unread 08-30-2012, 01:48 PM   #137
Havok
Hey Gents looking for some advice/input/help. I've been exhausting multiple forums in search of what tire/size size to go with. After much deliberation I went with
Terra Grapplers 275/65r18 (stock Laredo rims). They look great, but to my dismay they are rubbing in the left rear fender well, so much in fact it wore a hole through
the rear of the fender well. This was done with a full load (4 passengers) not even on the trail, so this makes me think that once I DO go on the trail; i'm screwed. So whats
my best option here? will a RR 2.5 lift resolve this? Spacers (if so how much)? I've tried to find the answer to this but i'm coming up short and my fender wells are paying the price.
Thanks for the help guys.
My Jeep: 2012 WK2 Laredo X, 3.6L, No Spacers, No Lift, Stock 18's.
Last edited by Jackal01; 08-30-2012 at 02:30 PM.. Reason: Edited for censor bypass.
Havok is offline   Reply With Quote Quick reply to this message
Unread 08-30-2012, 03:19 PM   #138
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Is it rubbing the pinch weld, or elsewhere?
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now   Reply With Quote Quick reply to this message
Unread 08-30-2012, 04:40 PM   #139
Havok
The only place I see it rubbing is the rear of the back left wheel well. Also forgot to mention, I've got a non-quadra lift wk2.
Unread 09-04-2012, 03:36 PM   #140
hur1ey02
2011 WK
^weird. I've towed heavy boats, fully loaded with people and gear and never rubbed with the same set up.
Current - 2011 WK2 Laredo X (Inferno Red)
2013 Scion FR-S (Raven Black)
Past - 2008 JK Unlimited Sahara (Black)
2004 TJ RME (Flame Red)
hur1ey02 is offline   Reply With Quote Quick reply to this message
Unread 09-08-2012, 08:38 PM   #141
atinari
Originally Posted by ktwillis View Post
255/75/17 off Wrangler Rubicon with RRO Level Kit. Wheels bolted right up but you need a 1/8 to 1/4 spacer in the front because the wheel just kisses the caliper if you break hard in a tight turn.
Hey, I am going to be running the same set up. Is there anything i might need to know? thanks
atinari is offline   Reply With Quote Quick reply to this message
Unread 09-17-2012, 05:30 PM   #142
SNAFU3613
Hey everyone long time lurker first time poster. Got new shoes for the GC 4WD QuadraTrac II with BFG Rugged Terrain 265/70/R17's on stock wheels (stock tires were 245/70/R17). They fit fine with no lift no rub. Drove with full travel and no issues.
2012 Jeep Grand Cherokee Laredo (WK2) 4WD, V-6, Tow Package, BFG Rugged Terrains 265/70/R17
2003 Jeep Wrangler (TJ) 4.0 I-6 BFG All Terrain TA KO 33 x 12.5, K & N FIPK, Optima, 3 inch lift
SNAFU3613 is offline   Reply With Quote Quick reply to this message
Unread 09-17-2012, 08:22 PM   #143
TheSiltSurfer
2012 WK
Awesome! I have the same but in 33" haven't seen anyone else on here with em yet, they are actually quiet compared to other all terrains like BFG Baja champs
Infinite Patience Produces Immediate Results
TheSiltSurfer is offline   Reply With Quote Quick reply to this message
Unread 09-19-2012, 09:44 AM   #144
HoustonRider
it would be sweet if I could get a set of these on my Summit. I need these tires (or similar) on an 18" rim for special times
2012 JGC Overland Summit 4x4 Hemi
2013 Wrangler 4x4 Auto - Dozer
HoustonRider is offline   Reply With Quote Quick reply to this message
Unread 09-29-2012, 12:48 PM   #145
sprbwlstlrs
Can anyone tell.me before I pull the trigger very soon if I will have a problem. I ha e the level kit. I'm getting 17x8.5 tko's with 18 offset. This will put it put to the fenders. I want to get 265/70/17 instead of 265/65/17. Will that extra half inch between tire and fender cause me any potential problems with the fender if I hit a big bump or go off-road. . May be a dumb question bit I'm worried about that.
sprbwlstlrs is offline   Reply With Quote Quick reply to this message
Unread 11-18-2012, 08:43 PM   #146
NorCalArctic
2012 WK
Just got a 12 WK2 4x4 Laredo with 20" polished aluminum wheels, noticed that GY Silent Armors come in 275/55/20 = 31.9". Any of you try these yet for your 20's. Had silent armors on previous WJ and they are great for snow/rain/daily driver tire. My other option is to sale the 20s and get some 17" or 18" Laredo wheels. I want more side wall for a safety concern, not a fan of low profile tires but this was the only choice I had when getting Nav/Uconnect options.
NorCalArctic is offline   Reply With Quote Quick reply to this message
Unread 11-19-2012, 04:19 PM   #147
Alaska-HWY JK
Running 275/55/20 GY Silent Armor on my wifes Overland.
Alaska-HWY JK is offline   Reply With Quote Quick reply to this message
Unread 11-24-2012, 02:43 PM   #148
BigNunz6
2015 WK
Can you please post pics ...Thanks
If you like it, buy it!!!!
BigNunz6 is offline   Reply With Quote Quick reply to this message
Unread 11-24-2012, 03:04 PM   #149
Alaska-HWY JK
Unread 11-26-2012, 10:00 PM   #150
NorCalArctic
2012 WK
Your WK looks great Alaska-HWY JK, you have a slightly wider stance with those less backspaced wheels. I am a bit concerned with the UCA bolt hitting the larger tires with OEM 20s but it looks as others have done this already without issues. I checked at the dealership for smaller wheels and found that they cost a lot more then I thought. Thinking of just running the 20s with the 275/55/20 GYSAs for now. Have any of you tried the RRO level kit with this set up, over the top strut plates can cause problems if not engineered right from what I have learned with the KK?
