WK2 MY2012 How to identify if it has Quadra-Drive II and electronic LSD? - JeepForum.com
post #1 of 7 Old 01-25-2012, 05:41 PM Thread Starter
Aussiejeep641
2012 WK
Wk WK2 MY2012 How to identify if it has Quadra-Drive II and electronic LSD?
I m new to Jeep. Previously I have had two early Range Rovers.
I ordered a new Grand Cherokee Laredo in July 2011 and it has finally arrived at my Authorised Chrysler dealer for delivery after 5 months wait. It is a CRD 3.0 liter turbo diesel (not yet available in USA, if I undersand correctly). It has the updated 5/6 speed transmission fitted to MY2012.
I ordered Quadra-Lift air suspension and the "Off Road Adventure II " pack comprising fuel tank, transfer case, underbelly and front suspension skid plates; Quadra-Drive II 4WD system, rear electronic LSD, 3.45 axle ratio, 265/60 R18 tyres on 18x8 inch wheels.
MY PROBLEM:
I have refused to accept delivery because the skid pans had not been fitted, to the apparent surprise of the salesman and service manager ( or were they surprised that I bothered to look before I drove off?) I then also asked them to verify that the the Quadra-Drive II and electronic LSD had been fitted. This they could not do, saying that there was nothing on the car to indicate the particular build components - yes, this is a Chrysler Jeep dealership! I recovered my check, they still have the car and I am awaiting further response from them.
MY QUESTION:
How do I identify the transmission and differential fitted to the car?
If they offer a retro-fit does this portend future problems with the transmission including traction control etc?
At this stage I don't trust their competence to handle the issue.
Please advise.
Aussiejeep641 is offline
post #2 of 7 Old 01-25-2012, 05:55 PM
jgc4ever
2012 WK
EVIC (display by the spedometer) will say Quadra Drive II.
I HIGHLY doubt a dealer could retrofit to add QDII/ELSD to one that doesn't have it. If that's the case, look elsewhere, or re-order to get it.
jgc4ever is offline
post #3 of 7 Old 01-25-2012, 07:00 PM
Trailguide
2012 WK
Ask the dealership for the build sheet, if you get those down under. This may lead to the mystery of why no skid plates installed. They should have been installed by the factory as you know. At least ask to see the paperwork for your order. Or call Jeep with your VIN and ask what you should have. Good Luck.
Trailguide is offline
post #4 of 7 Old 01-25-2012, 08:18 PM
Nonaspirin
2012 WK
My build-sheet says quadra trak II but my evic says quadra drive II. I will take a picture of my rear diff and post it for you
I do think I have quadra drive II because I bought an overland with off road 2.
Nonaspirin is offline
post #5 of 7 Old 01-26-2012, 05:36 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
The ELSD will have what looks like an electric motor hanging off the driver's side of the rear diff. The EVIC should indicated quadra drive when started up.
Build sheet will say quadra trak II regardless as that transfer case is used in quadra drive Jeeps. You should find the ELSD listed somewhere on the build sheet. The window sticker should have quadra drive as an option.
To retrofit ELSD they would have to replace the entire rear end and add a control module, some wiring. They could add the skid plates easy enough. Are you also suppose to get front tow hooks?
ColdCase is online now
post #6 of 7 Old 01-27-2012, 12:35 AM Thread Starter
Aussiejeep641
2012 WK
Thanks to all. Most helpful.
Dealer has offered deposit money back or new order and some compensation which I accepted (May 2012 delivery). Problem caused by dealer mistake when placing order (off road pack omitted). Car did not have front recovery hooks and these are not offered on MY 2012 in Australia, according to dealer. I have asked dealer to retrofit these as part-compensation for inconvenience, which he is looking at.
post #7 of 7 Old 01-27-2012, 04:32 AM
peckmv
Coldcase, i went through a similar issue with my JGC. Nowhere on the window sticker did it say Quadra-drive II. The only place it was noted was on the EVIC at startup and the build sheet. I was ready to refuse it until I saw the option on the build sheet. The dealer was surprised that it wasn't on the window sticker and couldn't understand why Jeep didn't note it better.
peckmv is offline
Is the 2011 Quadra Drive 2 a 3 wheel or 4 wheel drive system? MRK WK2 Grand Cherokee Forum 45 11-03-2015 12:22 PM
Limited now available with ELSD and Quadra drive boltfan WK2 Grand Cherokee Forum 10 11-03-2011 03:02 PM
Does the WKII have quadra-drive? diver110 WK2 Grand Cherokee Forum 20 06-20-2011 08:55 AM
2011 Quadra-Drive II vs Quadra-Track II in 2011 WK MMACrypt WK2 Grand Cherokee Forum 13 02-09-2011 11:37 AM
2011 Quadra-Drive II Question vonk WK2 Grand Cherokee Forum 10 10-14-2010 04:45 PM
