WK2 Factory Side Roof Rails - JeepForum.com
post #1 of 33 Old 05-06-2013, 10:30 AM Thread Starter
FatAlbert
Hi Everyone,
I have a 2012 Grand Cherokee that has no roof rack at all (just the plastic strips that fit in the roof rack gutter on top. I'm looking to get a Yakima roof rack soon, and want to get the style that bolts directly to the factory roof rails (as opposed to the kind that clamp on above the doors).
So, I'll need the side roof rails installed on my Jeep in order to do so. Is this all I need? Will I have any problems bolting these on myself?
http://www.jeep4x4center.com/mopar-f...79173ai-m.html
http://www.jeep4x4center.com/mopar-f...79172ai-m.html
Thanks,
Steve
2012 WK2 :: V6
FatAlbert is offline
post #2 of 33 Old 05-06-2013, 10:48 AM
txwest
2012 WK
How does it not have rails???? What trim level is it? Laredo x?
Sent from my S-III using JeepForum
Current:
'12 GC Overland 4x4 HEMI ORII QL Towing Red/Saddle
Past Jeeps:
'80 CJ-7 I6 4x4 Std
'86 Comanchee I4 4x4 Std
'99 WJ Laredo 4.0 4x4 AWD
txwest is offline
post #3 of 33 Old 05-06-2013, 11:28 AM
shekshishekki
2013 WK
I would do some heavy research to see if yakima's cross bars can even mount to that flush rail you're planning to purchase.
I bought a set of thule cross bars and found out that the only way to mount then was to clip onto the door area and NOT the rails. I think those rails are only meant for mopar cross bars.
shekshishekki is offline
post #4 of 33 Old 05-06-2013, 12:37 PM
txwest
2012 WK
Rocky Road Outfitters has several different roof-rack options that fit onto the factory rails, once you have them installed.
http://www.rocky-road.com/wk2-roof-rack.html
Current:
Past Jeeps:
'80 CJ-7 I6 4x4 Std
txwest is offline
post #5 of 33 Old 05-06-2013, 02:45 PM Thread Starter
FatAlbert
Here's a picture of what came with my (nearly) base model 2012 GC. The 'factory rails' I linked in my original post are, in fact, what i need correct? Are they easy to install myself? No drilling or anything, right?
2012 WK2 :: V6
post #6 of 33 Old 05-06-2013, 03:30 PM
WvTaco
2011 WK
larado x has roof rails and leather.
base larado without e has the black rails caps. also no passive entry they even have manual seats. a 4x4 comes out right at 30k
but the rails should be bolt on. call some junk yards look for totaled 11-13 wk2s with the chrome rails.
the picture of the rails on that page look like mine. should be right. but seriously 200 bucks for those that is too much.
generic internet picture.
hum the swap may be a hard one
http://www.wk2jeeps.com/misc/2011_wk_luggage_rack.pdf
WK2's that have the black molding strips do not have the rivnuts needed to install the silver side rails. The real pain comes from having to drill out the existing threaded inserts to install the rivnuts. This has been a nightmare for the dealers attempting it. I went with the Thule setup through just for jeeps and it worked out really well. Those guys were awesome! They took the time to work through Mopar to come up with the right solution for me. I tried to go the route of replacing the black molding strips with the silver side rails and it just wasn't worth it. This Thule setup is totally the way to go. Thanks again to the just for jeeps guys. They really took the time to work with me and help me find a solution that works.
WvTaco is offline
post #7 of 33 Old 05-06-2013, 04:04 PM
WvTaco
2011 WK
also found this
Originally Posted by tuned8e View Post
Well let me being with - moosehead - thank you again here.
Guys - I just got the factory rails mounted , I did it myself with a buddy, didn't drill anything, used factory bolts, used factory holes. Didn't even need silicone.
Let's see here.
Ok so , take off your stockers with an allen wrench
Look at those threaded holes... wow!
Now we realize the underside of the functional rails are locked into place with these two components on each side:
With that taken into consideration, I used the stock bolts and torque'd them down on each side almost all the way, then i slid the plastic oem rail "housings" over those to lock them into place. Here is how high I had the bolts from the roof
Then, I slid the actual stainless rails into position where all the rest of the bolts lined literally right up. I torqued those down - not even too hard. They are ROCK SOLID. I repeat, Rock SOLID. I could mount a box up there with no hesitation. So each side has I believe 6 of these bolts, just remember the outter most 2 are used to position these rails then the ones on the inside go through the actual rail. You need to have them side by side to really see this.
Am I concerned about water leaking into my car? No, not at all. Not even the slightest bit. There is NO WAY water is getting beyond any of these bolts - they are all down most if not all of the way. If you are paranoid, get silicone.
Am I concerned about weight limit? NOPE. Not at all.
Conclusion: get the OEM rails and bolt them up. At least that is what worked for me. The whole thing is rock solid. Anyone near Chicago want to see this in person feel free to reach out to me. Again, Moosehead - thanks for making this happen.
WvTaco is offline
post #8 of 33 Old 05-06-2013, 04:11 PM
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Great find ^
2011 Billet JKUS
Jackal01 is offline
post #9 of 33 Old 05-07-2013, 09:28 AM
MickinNY
2013 WK
Originally Posted by FatAlbert View Post
Hi Everyone,
Thanks,
Steve
The Yakima towers clamp (no bolts) onto the chrome rails if/when you have them installed on your Jeep. You do need the chrome rails to do that.
I've used Yakima towers & rails in the past & stayed with them. Just go to their website & they'll show the towers/accessories for any given vehicle.
MickinNY is offline
post #10 of 33 Old 05-07-2013, 01:01 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Originally Posted by Jackal01 View Post
Great find ^
This method has been posted here in summary form too, maybe a year ago. I intended to clean the post up and save it in the write up thread... but I guess I got distracted..
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #11 of 33 Old 02-06-2014, 09:11 PM
djalby
2014 jeep grand cherokee roof rails
just ordered rails. thanks for the advice.
djalby is offline
post #12 of 33 Old 05-15-2015, 08:47 AM
GC2012
Greetings- I am interested in doing the same thing as wvtaco did--I'd like to replace my fake rails on the 2012 grand cherokee laredo with the actual style of rails so I can get a set of cross bars for a roof rack--doesn't look that difficult to do but I'm a bit squemish as yet to do it-has anyone else successfully achieved this? any further suggestions for a newbie?
thanks a bunch!!!!
GC2012 is offline
post #13 of 33 Old 05-15-2015, 01:58 PM
ColdCase
ColdCase's Avatar
2011 WK
Since you are not drilling and simply removing a few bolts, you can always bolt the molding back on if things go way wrong. No reason to be squemish. I've heard that some dealer body shops will do this for folks.
Forum sponsor moparonlineparts sells the rails and crossbars for less money than most other outlets, although I think folks have been picking up knock off cross bars on eBay or Amazon for less.
post #14 of 33 Old 06-16-2015, 11:30 AM
mcnulty6807
2012 WK
tuned8e, thanks for the write-up, and WvTaco thanks for the re-post, I followed the recommendations and it took me about 10 minutes total for both sides.
I ordered mine from www.machaikdcj.com/parts-accessories/index.htm, part numbers 55079173AJ, and 55079172AJ for about half the cost of the other websites listed in this thread.
Now it's time to get some cross bars!
mcnulty6807 is offline
post #15 of 33 Old 10-26-2015, 03:11 PM
rockhead261
2015 WK
First post!
Total n00b to the Jeep thing but a total geek in the forums... I joined a few hours ago to find a solution to the naked roof on the 2015 JGC Overland High Altitude, and it looks like the answer lies in this thread!
So... it's been a few months since you guys installed your "after the factory" factory rails. How have they held up? Anything you'd do different?
rockhead261 is offline
