-   WK2 Grand Cherokee Forum (http://www.jeepforum.com/forum/f309/)
-   -   WK2 Factory Side Roof Rails (http://www.jeepforum.com/forum/f309/wk2-factory-side-roof-rails-1519422/)
FatAlbert 05-06-2013 09:30 AM
Hi Everyone,
I have a 2012 Grand Cherokee that has no roof rack at all (just the plastic strips that fit in the roof rack gutter on top. I'm looking to get a Yakima roof rack soon, and want to get the style that bolts directly to the factory roof rails (as opposed to the kind that clamp on above the doors).
So, I'll need the side roof rails installed on my Jeep in order to do so. Is this all I need? Will I have any problems bolting these on myself?
http://www.jeep4x4center.com/mopar-f...79173ai-m.html
http://www.jeep4x4center.com/mopar-f...79172ai-m.html
Thanks,
Steve
txwest 05-06-2013 09:48 AM
How does it not have rails???? What trim level is it? Laredo x?
Sent from my S-III using JeepForum
shekshishekki 05-06-2013 10:28 AM
I would do some heavy research to see if yakima's cross bars can even mount to that flush rail you're planning to purchase.
I bought a set of thule cross bars and found out that the only way to mount then was to clip onto the door area and NOT the rails. I think those rails are only meant for mopar cross bars.
txwest 05-06-2013 11:37 AM
Rocky Road Outfitters has several different roof-rack options that fit onto the factory rails, once you have them installed.
http://www.rocky-road.com/wk2-roof-rack.html
FatAlbert 05-06-2013 01:45 PM
Here's a picture of what came with my (nearly) base model 2012 GC. The 'factory rails' I linked in my original post are, in fact, what i need correct? Are they easy to install myself? No drilling or anything, right?
http://i.imgur.com/xnMOnW6.jpg
WvTaco 05-06-2013 02:30 PM
larado x has roof rails and leather. :rolleyes:
base larado without e has the black rails caps. also no passive entry they even have manual seats. a 4x4 comes out right at 30k :2thumbsup:
but the rails should be bolt on. call some junk yards look for totaled 11-13 wk2s with the chrome rails.
the picture of the rails on that page look like mine. should be right. but seriously 200 bucks for those that is too much.
generic internet picture.
http://www.cargogear.com/imagelibrar...hroofrails.jpg
hum the swap may be a hard one
http://www.wk2jeeps.com/misc/2011_wk_luggage_rack.pdf
WK2's that have the black molding strips do not have the rivnuts needed to install the silver side rails. The real pain comes from having to drill out the existing threaded inserts to install the rivnuts. This has been a nightmare for the dealers attempting it. I went with the Thule setup through just for jeeps and it worked out really well. Those guys were awesome! They took the time to work through Mopar to come up with the right solution for me. I tried to go the route of replacing the black molding strips with the silver side rails and it just wasn't worth it. This Thule setup is totally the way to go. Thanks again to the just for jeeps guys. They really took the time to work with me and help me find a solution that works.
WvTaco 05-06-2013 03:04 PM
also found this
Originally Posted by tuned8e (Post 737455)
Well let me being with - moosehead - thank you again here.
Guys - I just got the factory rails mounted , I did it myself with a buddy, didn't drill anything, used factory bolts, used factory holes. Didn't even need silicone.
Let's see here.
http://i49.tinypic.com/53oe8k.jpg
http://i47.tinypic.com/9sgshg.jpg
http://i48.tinypic.com/24m7whi.jpg
http://i49.tinypic.com/10nid05.jpg
Ok so , take off your stockers with an allen wrench
http://i50.tinypic.com/dh7sed.jpg
Look at those threaded holes... wow!
http://i49.tinypic.com/2nh3sqr.jpg
Now we realize the underside of the functional rails are locked into place with these two components on each side:
http://i50.tinypic.com/4gvnb.jpg
http://i47.tinypic.com/2954w7n.jpg
With that taken into consideration, I used the stock bolts and torque'd them down on each side almost all the way, then i slid the plastic oem rail "housings" over those to lock them into place. Here is how high I had the bolts from the roof
http://i47.tinypic.com/2ecqmnn.jpg
Then, I slid the actual stainless rails into position where all the rest of the bolts lined literally right up. I torqued those down - not even too hard. They are ROCK SOLID. I repeat, Rock SOLID. I could mount a box up there with no hesitation. So each side has I believe 6 of these bolts, just remember the outter most 2 are used to position these rails then the ones on the inside go through the actual rail. You need to have them side by side to really see this.
Am I concerned about water leaking into my car? No, not at all. Not even the slightest bit. There is NO WAY water is getting beyond any of these bolts - they are all down most if not all of the way. If you are paranoid, get silicone.
Am I concerned about weight limit? NOPE. Not at all.
Conclusion: get the OEM rails and bolt them up. At least that is what worked for me. The whole thing is rock solid. Anyone near Chicago want to see this in person feel free to reach out to me. Again, Moosehead - thanks for making this happen.
Jackal01 05-06-2013 03:11 PM
Great find ^
MickinNY 05-07-2013 08:28 AM
Originally Posted by FatAlbert (Post 15395585)
Hi Everyone,
Thanks,
Steve
The Yakima towers clamp (no bolts) onto the chrome rails if/when you have them installed on your Jeep. You do need the chrome rails to do that.
I've used Yakima towers & rails in the past & stayed with them. Just go to their website & they'll show the towers/accessories for any given vehicle.
ColdCase 05-07-2013 12:01 PM
Originally Posted by Jackal01 (Post 15397176)
Great find ^
This method has been posted here in summary form too, maybe a year ago. I intended to clean the post up and save it in the write up thread... but I guess I got distracted.. :)
djalby 02-06-2014 08:11 PM
2014 jeep grand cherokee roof rails
just ordered rails. thanks for the advice.
GC2012 05-15-2015 07:47 AM
Greetings- I am interested in doing the same thing as wvtaco did--I'd like to replace my fake rails on the 2012 grand cherokee laredo with the actual style of rails so I can get a set of cross bars for a roof rack--doesn't look that difficult to do but I'm a bit squemish as yet to do it-has anyone else successfully achieved this? any further suggestions for a newbie?
thanks a bunch!!!!
ColdCase 05-15-2015 12:58 PM
Since you are not drilling and simply removing a few bolts, you can always bolt the molding back on if things go way wrong. No reason to be squemish. I've heard that some dealer body shops will do this for folks.
Forum sponsor moparonlineparts sells the rails and crossbars for less money than most other outlets, although I think folks have been picking up knock off cross bars on eBay or Amazon for less.
mcnulty6807 06-16-2015 10:30 AM
tuned8e, thanks for the write-up, and WvTaco thanks for the re-post, I followed the recommendations and it took me about 10 minutes total for both sides.
I ordered mine from www.machaikdcj.com/parts-accessories/index.htm, part numbers 55079173AJ, and 55079172AJ for about half the cost of the other websites listed in this thread.
Now it's time to get some cross bars!
rockhead261 10-26-2015 02:11 PM
First post! :wave:
Total n00b to the Jeep thing but a total geek in the forums... I joined a few hours ago to find a solution to the naked roof on the 2015 JGC Overland High Altitude, and it looks like the answer lies in this thread!
So... it's been a few months since you guys installed your "after the factory" factory rails. How have they held up? Anything you'd do different?
The time now is 12:53 PM.
