Windshield washer fluid stopped working - JeepForum.com
post #1 of 9 Old 01-09-2014, 09:35 PM Thread Starter
MonteJeep
2012 WK
Hey all...anyone have this problem...
I have a 2012 GC and the windshield washer fluid does not work. I brought it for service and the service manager said it was frozen and they needed to put in new fluid. After picking it up, it worked a bit (but much weaker) and then stopped again. I think its the washer pump/motor. Anyone else have this issue?
2012 Grand Cherokee Limited - True Blue/Light Frost Interior - V6 Pentastar
MonteJeep is offline
post #2 of 9 Old 01-10-2014, 10:02 AM
howardusa
It's probably frozen again. How cold is it there? Whoevever serviced it probably put in summer fluid. I had this happen to mine this year when I forgot to put in winter fluid. The first time it thawed out I ran it until I got rid of the summer fluid. Put in some Prestone -35F fluid and the problem disappeared.
HT
howardusa is offline
post #3 of 9 Old 01-10-2014, 10:11 AM
2kg4u
2014 WK
I predict it will begin working this weekend.
Roy
2014 Overland, 3.6 L
Fumoto Qwikvalve, Ionic CXV running boards, Michelin X-Ice Xi2 snow tires
2kg4u is offline
post #4 of 9 Old 01-10-2014, 11:20 AM
Carange334
Mine stopped working due the the fluid being frozen... After about 20 minutes of driving it defrosed and started working.
Carange334 is offline
post #5 of 9 Old 01-10-2014, 11:37 AM
zr2s10
2012 WK
Yeah, almost definitely frozen fluid. I always switch mine to a "de-icer" type asap. Rain-x brand seems to be the most widely available around here. I'm even going to put some in a squirt bottle, to help clean my rear camera without wiping (scratching) the lens.
zr2s10 is offline
post #6 of 9 Old 01-10-2014, 11:38 AM
Bullheadbud
2014 WK
What I've always done when in below freezing climate is add a pint of isoprophyl alchohol to the the window washer fluid in the tank. Never had a problem with system freezing since. Make sure tank is almost full so when you add the alchohol it brings up to full level.
Bullheadbud is offline
post #7 of 9 Old 01-11-2014, 07:55 AM
spinxt
Check the nozzles under the hood. Mine stopped working or working with very weak pressure. I looked at the nozzles and one of them was cracked at the "t-fitting" and the other one was completely broken. I attribute that to me whacking the hood to try to crack ice off after a recent ice stein recently. Check yours..even a little crack would bleed off the pressure created by the pump.
spinxt is offline
post #8 of 9 Old 01-12-2014, 04:48 PM
trooper1968
2011 WK
I have the exact same problem, the nozzles on both sides have become brittle and cracked, off the dealership to the new ones.
/cl
trooper1968 is offline
post #9 of 9 Old 01-16-2014, 07:37 PM Thread Starter
MonteJeep
2012 WK
Thanks all. Turns out the tube connecting the nozzles to the water supply was loose.
