-   WK2 Grand Cherokee Forum (http://www.jeepforum.com/forum/f309/)
-   -   Windshield washer fluid stopped working (http://www.jeepforum.com/forum/f309/windshield-washer-fluid-stopped-working-1979290/)
MonteJeep 01-09-2014 08:35 PM
Hey all...anyone have this problem...
I have a 2012 GC and the windshield washer fluid does not work. I brought it for service and the service manager said it was frozen and they needed to put in new fluid. After picking it up, it worked a bit (but much weaker) and then stopped again. I think its the washer pump/motor. Anyone else have this issue?
howardusa 01-10-2014 09:02 AM
It's probably frozen again. How cold is it there? Whoevever serviced it probably put in summer fluid. I had this happen to mine this year when I forgot to put in winter fluid. The first time it thawed out I ran it until I got rid of the summer fluid. Put in some Prestone -35F fluid and the problem disappeared.
HT
2kg4u 01-10-2014 09:11 AM
I predict it will begin working this weekend.
Carange334 01-10-2014 10:20 AM
Mine stopped working due the the fluid being frozen... After about 20 minutes of driving it defrosed and started working.
zr2s10 01-10-2014 10:37 AM
Yeah, almost definitely frozen fluid. I always switch mine to a "de-icer" type asap. Rain-x brand seems to be the most widely available around here. I'm even going to put some in a squirt bottle, to help clean my rear camera without wiping (scratching) the lens.
Bullheadbud 01-10-2014 10:38 AM
What I've always done when in below freezing climate is add a pint of isoprophyl alchohol to the the window washer fluid in the tank. Never had a problem with system freezing since. Make sure tank is almost full so when you add the alchohol it brings up to full level.
spinxt 01-11-2014 06:55 AM
Check the nozzles under the hood. Mine stopped working or working with very weak pressure. I looked at the nozzles and one of them was cracked at the "t-fitting" and the other one was completely broken. I attribute that to me whacking the hood to try to crack ice off after a recent ice stein recently. Check yours..even a little crack would bleed off the pressure created by the pump.
trooper1968 01-12-2014 03:48 PM
I have the exact same problem, the nozzles on both sides have become brittle and cracked, off the dealership to the new ones.
/cl
MonteJeep 01-16-2014 06:37 PM
Thanks all. Turns out the tube connecting the nozzles to the water supply was loose.
The time now is 02:19 AM.
