Widshield washer nozzle? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Widshield washer nozzle?
Save Now on Procomp Xtreme MT2 Tires !Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!
Unread 09-29-2014, 06:04 AM   #1
Jughead
2011 WK
The drivers side windshield washer nozzle which is under the hood has broken on my wife's 2011 Limited at least 4 times since we bought it new.
Now my used 2011 X broke yesterday. Same part, same side. WTF? Is this a common problem? I can't believe a little plastic part is so fragile. WTF is causing them to break?
Are they hard to remove?
Ironically I'm taking the X in for annual inspection and recall work tomorrow so I'll just have them replace.
2003 Rubicon
2011 Laredo "X" V-6
2011 Laredo Limited Hemi
1970 Corvette Stingray 454
Jughead is offline   Reply With Quote Quick reply to this message
Unread 09-29-2014, 07:35 AM   #2
Jpiwonski
2011 WK
Originally Posted by Jughead
The drivers side windshield washer nozzle which is under the hood has broken on my wife's 2011 Limited at least 4 times since we bought it new. Now my used 2011 X broke yesterday. Same part, same side. WTF? Is this a common problem? I can't believe a little plastic part is so fragile. WTF is causing them to break? Are they hard to remove? Ironically I'm taking the X in for annual inspection and recall work tomorrow so I'll just have them replace.
I believe it can be due to heat, have heard others having an issue as well. Don't believe its too tricky to fix.
Jpiwonski is offline   Reply With Quote Quick reply to this message
Unread 09-29-2014, 08:01 AM   #3
Jughead
2011 WK
Looks like to remove maybe you simply press together the 2 clips? $18.00 each???
Unread 09-29-2014, 10:56 AM   #4
LibGrandCher
2012 WK
Just did mine a few months ago under warranty.
I know a few other folks on here have had the same thing.
Will your 2011 be covered by warranty?.
I guess an $18 part would be a about $100 with taxes and labour?.
Anyway ,let us know how this turns out.
LibGrandCher is offline   Reply With Quote Quick reply to this message
Unread 09-29-2014, 12:57 PM   #5
jimb0JP
They pop out very easily...just squeeze the two tabs with a pair of pliers and push it out. One of mine broke when it was being removed to install the applique on my hood. $17 replacement cost. Other than that no issues with them breaking on my 2012.
2012 Jeep Grand Cherokee Altitude 5.7
2002 Pontiac Trans Am Firehawk
1991 Pontiac Formula Firehawk
jimb0JP is offline   Reply With Quote Quick reply to this message
Unread 10-03-2014, 07:49 PM   #6
Morax
One Life. Live it!
Morax's Avatar
2014 WK
Dealer wanted $45.00 to swap one out on my 2011 overland, told them to hand over the part, paid $20.00 and took me 7-10 minutes to change…took me longer to remove the plastic part broken in the hose then installing the part itself...
2014 Overland Tech - ECO
2011 Overland - HEMi - Sold!
Morax is offline   Reply With Quote Quick reply to this message
Unread 10-12-2014, 04:57 PM   #7
mx71
2013 WK
2013 with 25,000 and garaged. Passenger side broke and driver broke when the lined moved while replacing. Got some from O'Reailly for $18 as I didn't want to have to leave my Jeep there for a week for them to tell me they broke something else. Never again will I buy a Chrysler after all the stupid crap that's been happening.
mx71 is offline   Reply With Quote Quick reply to this message
