where are the oil trans and power steering coolers? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > where are the oil trans and power steering coolers?
RIGID LED Light Blowout Sale - All Sizes, All Series, all Magnaflow SS Cat Back Exhaust System, Street, High ClearanJeep Long Arm Upgrade Kits on SALE for as low as $649.95 S
Unread 02-15-2015, 11:08 AM   #1
2k2wranglerx
I have a red puddle on the floor of the garage. I can't tell if it's trans or power steering. The top driver side of the condensor is wet. And the leak is definitely on the drivers side. But I can't pinpoint where.
Power steering was low 6 weeks ago but it's still good after I filled it and I'm still getting puddles.
Is the trans cooler in the rad? When I look up rads it lists no for oil cooler.
What's the small cooler down low? Power steering?
Thanks guys
93 yj. 355 chevy, heads, cam, intake, etc. 35's, bumpers, winch, lights, and a killer stereo.
2k2wranglerx is offline   Reply With Quote Quick reply to this message
Unread 02-15-2015, 12:36 PM   #2
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
No cooler in the rad. Attached to the front of the radiator is the combination AC condenser/transmission fluid cooler (1). The top part is the transmission cooler part. The smaller cooler (5) is the power steering cooler.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now   Reply With Quote Quick reply to this message
Unread 02-15-2015, 01:26 PM   #3
2k2wranglerx
Wow. So it is the trans cooler leaking. Bummer.
Thanks man. I've never seen an ac condensor combined with a trans cooler.
Any negatives to just tossing an aftermarket trans cooler and bypass the factory cooler?
Unread 02-15-2015, 02:35 PM   #4
2k2wranglerx
rockauto had it for 85 bucks shipped. So i just ordered a whole new condensor. it sucks that i have to charge the AC and then take the jeep to the dealer so they can top off the fluid. But what can you do...
Unread 02-21-2015, 03:06 PM   #5
2k2wranglerx
So I went to change it today. What a pain. I ended up tossing an aftermarket cooler in it. It wasn't worth ripping the entire front end off the jeep to do it
