When to change diff fluids? - JeepForum.com
 1Likes
  • 1 Post By kryogen
post #1 of 10 Old 05-18-2016, 11:16 AM Thread Starter
jnlasvegas
2014 WK
I have a 2014 gc with a hemisphere and 32000 miles. Dealership recommended I change both front and rear for 180 each.
I don't have manual but I'd thought it wouldn't have been this soon.
Any thoughts on price and if this is just dealership being a stealership?
Thanks!
jnlasvegas is offline
post #2 of 10 Old 05-18-2016, 11:17 AM Thread Starter
jnlasvegas
2014 WK
Hemi not hemisphere. Lol damn autocorrect
post #3 of 10 Old 05-18-2016, 11:33 AM
GPSBob
2015 WK
You can download your manual for free at this site:
http://www.jeep.com/en/owners/manuals/
GPSBob is offline
post #4 of 10 Old 05-18-2016, 11:56 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Its synthetic gear lube.
For 2014 models, every 20,000 miles, inspect the front and rear axle fluid, change if using your vehicle for police, taxi, fleet, off-road or frequent trailer towing. Inspect means to check for leaks. Towing heavy creates a lot of heat that could break down the fluid early, off road there is a chance of water or dust contamination. Otherwise there is no change interval suggested.
Transfer case fluid should be changed at 120,000 miles.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #5 of 10 Old 05-18-2016, 05:08 PM
norge2000
Agreed. Around or just over 100,000 miles is manic number to change all fluids. Coolant, transmission, differentials, brakes and power steering.
norge2000 is offline
post #6 of 10 Old 05-19-2016, 05:48 AM
bittner72
I changed my FR/RR axle, transmission fluids around 60-70k. The only fluid that by seemed "dirty" was the rear-end. And I mean it came out black and the new is like a light gold color. This is the quadra drive system so I'm not sure if you have the same. The dealer whom I ordered the fluid from did not have it and seemed like they had never ordered it before.
bittner72 is offline
post #7 of 10 Old 05-20-2016, 03:02 PM
Limited9627
2014 WK
Dealers will try and sell you anything. Personally I would just crack the fill hole and check your fluid before spending money on that. I had a dealer try and tell me it should be changed at 15k lol. I went home and checked it an it looked brand new. I don't have QD.
2014 WK2 Limited V6 w/ Icon Coilovers revalved and OME HD springs and shocks on rear.
Limited9627 is offline
post #8 of 10 Old 05-21-2016, 04:15 AM
kryogen
2011 WK
dealer tried to sell me a fluid change for 400$ also. I said no.
But then I said you know I have QD right, you need a special fluid? He looked dumb and said, oh its going to cost more....
Jesus.
Monarchco likes this.
2011 Grand Cherokee Overland V8, QD, QL
Nokian Hakkapelita 8 SUV Studded winter tires
kryogen is offline
post #9 of 10 Old 05-29-2016, 01:02 PM
Turbozcs2003
well do you intend to keep a long time or not give a crap?
I dumped the fluids in the t-case and diffs after a few thousand to get the metals out, smartest thing you can do to extend the life of them is change them a few times during early ownership.
Go buy a outboard lower unit gear oil pump at walmart for 10$ and buy some gear lube. Will also need a set of allen sockets to get the plugs out, very easy maintnenance. no need to spend 180$ per diff when you can change the fluid for the cost of 2 qts of gear oil.
A freind of mine never changed his gear oil in his ram and at 120K got to spend 1200 $ rebuilding it, yet I guess he saved 100$ in gear lube over the years.
Turbozcs2003 is offline
post #10 of 10 Old 05-29-2016, 01:45 PM
ColdCase
ColdCase's Avatar
2011 WK
Thats pretty much old school, not applicable to modern manufacturing methods.
I have a few buddies that never change diff or transfer case fluids and have 250,000+ miles without an issue. They don't tow or ford water either.
If you abuse your diffs, they won't last regardless of how often you change oil.
ColdCase is offline
