Wheels on my truck go round and round... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Wheels on my truck go round and round...
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits ZONE 4.25" combo lift for TJ available at Rockridge4wG2 Disc Brake Conversion Kit for Jeep Wrangler YJ TJ LJ Ch
Unread 12-13-2014, 06:11 PM   #1
boyvan
2012 WK
Recently I noticed that tires on my GC were going round and round every time I pressed accelerator. It's generally not an issue but is annoying when I see my wheels circling.
I took it to the dealer and my dealer couldn't figure it out. The advisor said that he has seen it before and they are working on a solution. But at this point in time there is not much they can do. So I am not happy with my dealer.
I searched but nothing came up. Has it happened to any of you guys? What was the outcome? :-) :-) :-) :-) :-)
_______________________________
2012 JGC Overland - Max Steel
boyvan is offline   Reply With Quote Quick reply to this message
Unread 12-14-2014, 08:33 AM   #2
Berk483
2013 WK
Try the brake pedal. It should stop the wheels from going round and round...
Berk483 is offline   Reply With Quote Quick reply to this message
Unread 12-14-2014, 09:39 AM   #3
hemispin
2014 WK
Sounds like you should have the water tested where you live.
hemispin is offline   Reply With Quote Quick reply to this message
Unread 12-14-2014, 09:47 AM   #4
XJ2WK2
2011 WK
Which dealer? I'll be sure to avoid them
XJ2WK2 is online now   Reply With Quote Quick reply to this message
Unread 12-14-2014, 12:30 PM   #5
BigNunz6
2015 WK
Don't hit the accelerator; problem solved.
If you like it, buy it!!!!
BigNunz6 is offline   Reply With Quote Quick reply to this message
Unread 12-14-2014, 12:55 PM   #6
14summithemi
2014 WK
C'mon, it's obviously a polar magnetic shift scenario. Water problems would most likely create a random meandering steering wheel. Jeeezz!
14summithemi is online now   Reply With Quote Quick reply to this message
Unread 12-14-2014, 05:06 PM   #7
mx71
2013 WK
It's your fault. The vehicle wasn't intended to be removed from the driveway.
mx71 is offline   Reply With Quote Quick reply to this message
Unread 12-14-2014, 06:09 PM   #8
SouthDakota
Jeep Owner Since 2006
SouthDakota's Avatar
2014 WK
It only happens when my wife drives it. The solution is to not let your wife or girlfriend drive.
-Jason
2014 Jeep Grand Cherokee Limited 4x4
5.7L Hemi V8, Luxury Group II, Navigation
SouthDakota is offline   Reply With Quote Quick reply to this message
Unread 12-14-2014, 08:20 PM   #9
it_felt_so_good
You guys must have some good stuff in Vancouver.
2013 JKU
2015 WK2
it_felt_so_good is offline   Reply With Quote Quick reply to this message
Unread 12-14-2014, 08:47 PM   #10
Morax
One Life. Live it!
Morax's Avatar
2014 WK
Man I luv Canada!
2014 Overland Tech - ECO
2011 Overland - HEMi - Sold!
Morax is online now   Reply With Quote Quick reply to this message
Unread 12-14-2014, 11:27 PM   #11
Kablemodem
2014 WK
Does the spare turn too?
Kablemodem is offline   Reply With Quote Quick reply to this message
