Wheel and Tire Thread - Page 9 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Wheel and Tire Thread
End of Summer Sale, 20% OFF!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 01-06-2013, 01:46 PM   #121
NYWk266
Sorry my bad. Just looking for anyone who may have a similar setup or more are more familiar with wheels that work.
Sent from my iPhone using AutoGuide.com App
NYWk266 is offline   Reply With Quote
Unread 01-07-2013, 06:57 AM   #122
JDLalama
17" factory wheels & tires 245/70r17 seem to open up many more options for aggressive tires or choices in general. 20" factory wheels & tires 265/50r20 although I like the way the wheels look don't seem to have many tire options in the stock 265/50r20 tire size.
JDLalama is offline   Reply With Quote
Unread 01-07-2013, 07:56 AM   #123
NYWk266
I have factory 18s. I guess I could go down to 17s if that makes it easier. Haven't seen many rims in the chrome off road variety.
Unread 01-09-2013, 03:46 PM   #124
JordanD07
2007 WK
Anyone thought of putting 17" AEV pintlers with 265/70/17's on their lifted wk2? Would there be any problems with that?
'07 3.7 4x4 QT1 ll Red WK Club #27 ll OME ll Monroe LL ll Rusty's ll ProComp ll BFG ll 4xGuard ll S4XC ll VLEDS ll Infinity ll Thrush ll Riddler ll 6K HID
JordanD07 is offline   Reply With Quote
Unread 01-10-2013, 07:35 AM   #125
NYWk266
I think I narrowed my choice to the MB TKO in chrome. The specs are.
18x9
Back spacing: 5.98 in
Offset: +25
How would these fit on the WK2. I'd prefer to keep things as tucked under the fender as possible.
Thanks!
Unread 01-14-2013, 08:38 PM   #126
webspoke
18x9
Offset: +25
Thanks!
I have that offset in 18x8.5 with 285's. Sits just a bit outside the fenders.
2013 White V8 Limited, 285/60/18 Terra Grapplers, 25000 miles problem free
2011 Black V8 Overland, retired at 46000 miles with QL problems
webspoke is offline   Reply With Quote
Unread 01-14-2013, 10:27 PM   #127
NYWk266
So the 9 inch wide rim would stick out a tiny bit more?
That setup looks perfect. I plan on swapping on the stock tires till they wear then replacing them with something that size.
Unread 01-15-2013, 11:19 AM   #128
webspoke
The 9" wide rim will still sit in the same location, as the offset is measured to the center of the wheel. You will have less sidewall bulge with the wider rim though. What size tire are you looking at? With my 285's (31.5" tall) I get some rub on the drivers wheel well on big road dips with the stock suspension. If you use a lift or leveling kit, you will have no problems.
Unread 01-24-2013, 06:57 PM   #129
Jeepfreak86
Originally Posted by XJ2WK2 View Post
Procomp 7036, 0 offset, 275 65 18 Duratracs (Big50s setup)
Would this setup work well with the stock height/suspension? Or would you need a lift kit to have these fit without any rubbing issues?
Jeepfreak86 is offline   Reply With Quote
Unread 01-24-2013, 07:30 PM   #130
alpine24
2006 WK
I believe some have reported this setup having minor rubbing in the front even with the lift. At stock height I would imagine these tires would definitely rub.
alpine24 is offline   Reply With Quote
Unread 01-31-2013, 01:44 PM   #131
grandcherokee13
Hi guys, maybe someone knows? can I place on 4x4 laredo 2013, 295/45/20 size tires all set?
grandcherokee13 is offline   Reply With Quote
Unread 01-31-2013, 06:09 PM   #132
Rneum
Originally Posted by UNCjeepWK2 View Post
Anyone tried (or bought) the Michelin LTX A/T tires?
Yes. I have used them for the last 3 sets on a suburban. Can't beat them. Quiet and 60-70k miles and they are good in snow.
Rneum is offline   Reply With Quote
Unread 02-03-2013, 09:03 AM   #133
Mostoyzwinz
American Racing Fuel 321 with Goodyear Duratracs 245x70x17. This setup gives the stock tire circumference and increases the tire to control arm clearance (backspacing) to allow more room for tire chains up front. Couldn't use std chains with stock setup in front so bought expensive Thule XG-12 chains...which are still too close for comfort.
2011-jeeep-wheels-chains-feb13-009.jpg   2011-jeeep-wheels-chains-feb13-012.jpg   2011-jeeep-wheels-chains-feb13-010.jpg   2011-jeeep-wheels-chains-feb13-002.jpg   2011-jeeep-wheels-chains-feb13-003.jpg
Mostoyzwinz is offline   Reply With Quote
Unread 02-03-2013, 08:43 PM   #134
gremlinsteve
tire size question
any one running a 275/65/18 tire of some thing that is of the same diameter and width?
im looking at some of these in a m/t and i see the width is the same as the 265/60/18 a/t that i currently have on the trailhawk...
any ideas on if this combo will rub or not. close to the same outer diameter as the jk 255 wheel/tire combo
steve
gremlinsteve is offline   Reply With Quote
Unread 02-03-2013, 09:41 PM   #135
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Seems to work. See the discussion starting about post 22 of this thread:
http://www.jeepforum.com/forum/f309/...22/index2.html
You could also try searching for 275/65/18
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote
