Wheel and Tire Thread - Page 8 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Wheel and Tire Thread
IRON CROSS Jeep JK Front and Rear STUBBY BUMPERS IN STOCK Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Jeep speedometer gears at rockridge4wd
Unread 10-17-2012, 02:00 PM   #106
staskaya
20 inch oem wheels recommend good tires on WK2
I've not had any luck with the tires Good Years with my 2013 Grand Cherokee Limited, looking for a replacement tire's. Any one here who has 20 inch oem wheels, and has had good luck with the tires they drive daily.
My vehicle currently has vibration on the steering and front seats after 70mph. I've had dealership re-balance, I've put more air in the tires 39psi and had the wheel nuts tightened to 100lb/ft torched.
Thanks,
staskaya is offline   Reply With Quote Quick reply to this message
Unread 10-17-2012, 05:11 PM   #107
srtdodge05
2011 MK Patriot
Will 265/65/R17 Fit on a stock 2011 grand cherokee?
2011 Grand Cherokee
srtdodge05 is offline   Reply With Quote Quick reply to this message
Unread 10-18-2012, 06:51 PM   #108
WJMex
Is anyone running 18" XD Addicts, +18 offset with 285/60/18 cooper zeon ltz wheels?
Originally Posted by JasonJasoff View Post
18" XD Addicts, +18 offset, machined. BFG All-Terrain 275/65/18. No spacers. 2.5" RRO lift kit. Slight rubbing on front tires when wheel turned to the max, nothing to worry about really.
Jason has a sweet setup..
I have the Overand with 20s but want to move to 18s..
Is anyone running 18" XD Addicts, +18 offset with 285/60/18 cooper zeon ltz wheels? This would be a sweet setup!
The Cooper are 31.48 diam
11.43 section width and 9.46 tread....
Would this set rub?
WJMex is offline   Reply With Quote Quick reply to this message
Unread 10-19-2012, 01:23 PM   #109
webspoke
Would this set rub?
I have 18" wheels with +25 offset and 285/60 Nitto TG's. They fit ok on my old overland and current limited (without QL). Just a slight kiss on the front outer fender on really big bumps (at normal height) and it gets close to the felt inner liner on the front at full lock. With +18 you should be ok for normal driving, and no issues off road at the off-road ride heights. Here is my old overland at OR1 with this combo and my current non QL limited.
2013 White V8 Limited, 285/60/18 Terra Grapplers, 25000 miles problem free
2011 Black V8 Overland, retired at 46000 miles with QL problems
webspoke is offline   Reply With Quote Quick reply to this message
Unread 10-19-2012, 03:31 PM   #110
WJMex
+18 versus +25 offset
Webspoke, Will the +18 sffset stick the wheels out further than the +25 offset you run?
Unread 10-19-2012, 04:07 PM   #111
webspoke
Yes, 7mm more, so just over 1/4".
Unread 10-19-2012, 07:47 PM   #112
WJMex
Ok, thanks for the info, maybe I should go with 275/65/18s or 275/60/18s, so as not to stick out so far.. thoughts?
Unread 10-27-2012, 12:04 AM   #113
WJMex
Would the Addicts plus 275/65/18 rub with no lift installed? I have QudraLift on the Overland.
Unread 10-28-2012, 08:42 PM   #114
JasonJasoff
2012 WK
Absolutely.
JasonJasoff is offline   Reply With Quote Quick reply to this message
Unread 11-08-2012, 08:14 AM   #115
UNCjeepWK2
2011 WK
Anyone tried (or bought) the Michelin LTX A/T tires?
UNCjeepWK2 is offline   Reply With Quote Quick reply to this message
Unread 11-11-2012, 06:18 PM   #116
rlj
Just put 275/55/20's on last week. What a difference from the stock Forterra's. Jeep sits up a tad higher and the beefier tire look great. Handling is night and day difference. Up in the mountains last week they handled fantastic on the twisties. Ride is very smooth on the interstate and fairly quite.
"The problem with socialism is that eventually, you run out of other people's money."
2011 Jeep Grand Cherokee Overland
2007 Jeep Wrangler Sahara Unlimited
3.25" Rough Country lift
Nitto Trail grapplers 35-12.50R 17
AEV Pintler 17x9 Silver Wheels
AirAid CAI
Superchips @ 93 Tune
and a bunch of other stuff......
rlj is offline   Reply With Quote Quick reply to this message
Unread 11-12-2012, 01:17 PM   #117
gfviperman
2013 WK
Yokohamas
Just got a 2013 Overland.
Came with Goodyears.
Traded in 2009 Overland which, also, had GYs.
Not good in rain!!
Want something better - checked out Tire Rack comparos.
Yokohama Parada Spec-Xs look good.
But real world info would help.
Thankx!!!
gfviperman is offline   Reply With Quote Quick reply to this message
Unread 11-13-2012, 02:26 PM   #118
PDX-TJ
I'm thinking about switching wheels to a set of 20" Overland Summit take-offs (polished) with a set of 285/50R20 -or- 31.3" all-season tires.
Here are the two tires I'm thinking of going with.
Nitto NT420s -or- Toyo Proxes ST II
The Toyos cost $200/set more than the Nittos. What do you all think? Any experience with either of them?
2012 Jeep Grand Cherokee Limited
Mineral Gray / Black
5.7L Hemi
ORA2
PDX-TJ is offline   Reply With Quote Quick reply to this message
Unread 11-20-2012, 08:56 PM   #119
Faulk
2011 WK
Performed the 275/55/20 upgrade. Awesome upgrade - it transformed the look of the truck. I went with the Scorpions by Pirelli. Only negative is that the truck is slightly slower off the line, which is definitely noticeable in daily driving. Truck feels heavier. But in the snow, its a beast now! This is the hyper silver color. FYI, 18 inch chromes are for sale - PM me
2011 WK2 Limited Hemi, Tow pkg
2007 S4 Avant 6MT
Faulk is offline   Reply With Quote Quick reply to this message
Unread 11-22-2012, 08:20 AM   #120
UNCjeepWK2
2011 WK
Just replaced the OEM Latitudes with these M/S2's. The difference is night and day.
