Wheel and Tire Thread - Page 26 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Wheel and Tire Thread
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 02-08-2014, 04:10 PM   #376
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Originally Posted by HiRez View Post
Greetings,
Contemplating the purchase of a diesel GC limited.
Does it come with a spare tire (full size/collapsable)? If not, is there place to put one in?
Thanks in advance.
Depends on the option package and trim. The largest you can get, however, is a road tire that has the same diameter and load rating as the others (so called full size). Its narrower to fit in the spare wheel well. A spare the size of the other four tire sticks up a bit and will raise the cover. They don't use collapsible tires.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
Unread 02-08-2014, 04:37 PM   #377
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Greetings,
Thanks in advance.
According to Jeep.com it is a "compact spare tire".
2011 Billet JKUS
Jackal01 is offline   Reply With Quote Quick reply to this message
Unread 02-09-2014, 03:53 PM   #378
E-rok
I looked over every page but could have easily overlooked it, but whats a safe size for stock height non QL? 265/65/18? Or am I better of just running stock size? not looking to lift this one or do any trimming.
2011 WK2 Laredo X Hemi
2013 Ram 2500 Cummins
E-rok is offline   Reply With Quote Quick reply to this message
Unread 02-13-2014, 07:36 AM   #379
Wraab
2014 WK
Anyone had any luck finding a single stock 18" rim for the 2014 JGC?
Part # is 1VH40DD5AB
I don't need a set of 4, but I'd like one for a full size spare.
Wraab is offline   Reply With Quote Quick reply to this message
Unread 02-13-2014, 10:55 AM   #380
Aquaforest
Did you look on ebay?
Aquaforest is offline   Reply With Quote Quick reply to this message
Unread 02-14-2014, 05:56 PM   #381
alkoiv24
Need help with fitment
I've looked through the wheel and tire threads and I thought I was good. I want to put BFG All Terrains 275/65R18 with 18" Moto Metal 951 wheels. The wheels have a +18 offset which seems like it should work. The guy at America's Tire tells me they won't fit that they will rub and that I need at least a +26 offset. Can anyone please help with this?
alkoiv24 is offline   Reply With Quote Quick reply to this message
Unread 02-15-2014, 12:56 AM   #382
goonbash
BFGs might have slightly different measurements than my Duratracs and you may not have the same suspension but my 275/65r18s fit fine with a stock offset. It is tight in the rear wheel wells but no rub, they guy installing them at Americas tire called me into the shop while he was installing them and told me he thought they were going to rub. They didn't rub. If your offset is anything further outside than stock you should be ok. My GC is a 2014 with quadralift suspension.
goonbash is offline   Reply With Quote Quick reply to this message
Unread 02-15-2014, 01:02 AM   #383
goonbash
Wraab, as far as a full size spare goes, you can fit a full height spare but a 265 wide tire doesn't fit under my spare tire cover. The stock spare is not full width either, it is a 245. I squeezed a 255/70r18 all terrain spare under the cover to match the height of my 275/65r18 Duratracs, didn't look like any wider than 255 would fit.
Unread 02-15-2014, 09:09 AM   #384
ColdCase
ColdCase's Avatar
2011 WK
Have you asked forum sponsor http://moparonlineparts.com ?
Unread 02-15-2014, 10:56 AM   #385
jm020
2006 WK
Has anyone put 265/70 18 on their rig? I am looking at the general grabber's and from what i've read, 32's fit, but it looks like the 265/70 18 is about 32.65. They're for my girl's wk2 so I don't want any rubbing or anything...
06 WK 5.7 HEMI. 3" Magnaflow exhaust, K&N CAI, Superchips flashpaq, 20% tint
jm020 is offline   Reply With Quote Quick reply to this message
Unread 02-15-2014, 11:48 AM   #386
rbevans
I've done quite a bit searching and having a hard time finding an answer. I'm running P245/70R17 all stock and was wondering if I could run P265/70R17 without any rubbing? I don't have a lift or a leveling kit currently, but I'm considering the RRO level Kit.
rbevans is offline   Reply With Quote Quick reply to this message
Unread 02-15-2014, 02:53 PM   #387
Jackal01
Jackal01's Avatar
2011 JK Wrangler
http://www.jeepforum.com/forum/f309/.../#post13105594
2011 Billet JKUS
Unread 02-15-2014, 04:38 PM   #388
rbevans
Originally Posted by Jackal01 View Post
First I love your Jeep. Mine is actually the same color and hope to make some modifications similar to your. The photo you linked to of your Jeep is prior to your lift? Did you have any ride changes and I take it no rubbing? Suggestions? Thanks for your help!
Black 2012 WK2 Laredo
Unread 02-15-2014, 05:39 PM   #389
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Thanks man!
The thread goes into detail on when things happened. I suggest starting on page one and see the index for what you wanna do. I have it all sorted out. I only drove it for a day or two going on the highway and country roads I did not experience any issues. I factory ordered mine just so I could get the color. Nobody in southern Texas had it. if you have specific questions ask it in my thread in case other readers need the same answer, if ya don't mind.
2011 Billet JKUS
Unread 02-16-2014, 05:23 PM   #390
gremlinsteve
I have a tire question
I have read on this forum that the 275/65/18 tires will or should fit with quadra lift
Our jeep is a trailhawk edition using the hemi so I have the big brakes and the 18 inch wheel
I am wanting the mt series tire, and the wife wants to keep this stock wheel if possible so I searched and with what everyone is saying a ktr Kevlar in a 275/65/18 is going to fit with possible issues in the lowest setting that we do not use when parking.
I am going to make this purchase but wanted one last confirmation. Unless it is easier to move up to a 20 inch wheel.
Can someone steer us the right way?
gremlinsteve is offline   Reply With Quote Quick reply to this message
