Wheel and Tire Thread - Page 19 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Wheel and Tire Thread
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineZONE 4.25" combo lift for TJ available at Rockridge4wTeraFlex Now at Rockridge 4WD! BEST DEALS around!
Unread 09-15-2013, 06:50 AM   #271
tmdonnelly
2011 WK
After doing a lot of research, I ordered Toyo Open Country AT2s in a 265/65/18 for my 2011 Laredo X. While my Jeep was at the tire shop I strolled down the road for a cold Oktoberfest. As I was enjoying my tall, frosty, fall beverage the shop called me and said there was a problem... I went back to the shop and they had the old Lattitudes standing up next to the Toyos, and told me there was no way they would fit w/o rubbing. I tried to convince them that they would fit and they came back with the "look we do this for a living, we see this all the time, etc..." I told them to slap them, and to stop giving me lip (kidding, I said please). Long story short, the tires are on and there is ZERO RUBBING - in fact, not even close. Mathilde loves her new sneakers, and she's happy that she looks much tougher w/o the junk Michelins. Thanks so much for the folks here on Jeepforum who gave me the confidence to go against the "professionals" and put on rubber that I knew would fit. Cheers!!
tmdonnelly is offline   Reply With Quote Quick reply to this message
Unread 09-15-2013, 10:25 AM   #272
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Any pics?
2011 Billet JKUS
Jackal01 is offline   Reply With Quote Quick reply to this message
Unread 09-15-2013, 10:50 AM   #273
tmdonnelly
2011 WK
Originally Posted by Jackal01 View Post
Any pics?
I tried to upload one, but I'm too dumb.
Unread 09-15-2013, 11:22 AM   #274
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Open a free image hosting site like photobucket (what I use). Drag the images you want into the uploader. After they have uploaded each photo will have a few links depending on where they are going to be posted. Choose "IMG", the link will be copied and post it directly into this box.
You can also upload directly from your computer from below "Attach Files>Upload Images' but you will have to crop the size down. The photobucket method is the easiest (for me).
2011 Billet JKUS
Unread 09-15-2013, 04:24 PM   #275
tmdonnelly
2011 WK
img_20130914_143324_180-1-.jpg   img_20130915_164743_120-1-.jpg   img_20130915_164756_618-1-.jpg
Unread 09-17-2013, 04:43 PM   #276
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Nitto NT 421Q*265/50R20XL 111V BSW
I picked up a nail too close to the sidewall to be reparable so I thought this would be an good opportunity to replace the OEM Forteras, not that there was anything wrong with them otherwise. I had over 30,000 miles on them with plenty of tread life left. My set was well balanced and well behaved within a narrow tire pressure range, no complaints.
I wanted a highway cruising tire as I have a set of dedicated snows. There seems to be a wide variety of 275/55R20 tires available, but I wanted to stay with the 265/50 stock size. Folks around here rave about the Nitto Terra Grapplers so I thought I’d give their recently released NT 421Q a try.
Initial impression is that, if anything, they are a tad noisier than the Goodyears. They seem to stick to dry pavement better and seem to be more responsive in turns. They have an XL 2403 lb load rating where the Goodyears had a SL 2150 lb rating so I was expecting some ride harshness. The Nittos seem to soak up small bumps better, however, larger bumps seem about the same. They seem to track very well where the Goodyears had a tendency to wander.
The Nittos look like a decent tire but they are more money than the Goodyears (and the older Nitto 420S) and harder to find. $780 vs $520 a set from Discount tire. They do have a made in America stamp on them. They are not directional but have outside/inside edges. They are also stamped M+S.
I’ll update when I get a few more miles.
Edit: After break in the tires are much quieter, less noise than the OEMs. These stick to dry roads without protest and inspire much confidence, much more than the Forteras. It is a heavy SUV, however. Worth the $240 difference, I dunno yet. By the way, you may notice a tire machine scratch on one of the photos. Tire shop replaced the wheel with a new one, no hassle.
Update: These seem to be the kind of tires that sometimes develop that minor "flat" spot thing after being parked overnight (I think due to rubber compound settling a bit affecting the balance). Takes 3-4 miles driving to smooth out. Very minor, unless thats the kind of thing that annoys you. A passenger would not notice.
Update 11/4: These tires stick to wet roads as well as they do to dry. They do "buzz" a bit between 40-60 mph on wet roads. Just a tad louder than the OEM Goodyears, which didn't have a buzz to them. Not nearly as noisy as the blizzacks or other all seasons tires I've used on other vehicles.
Update 12/13: Just drove in light snow and an icy driveway where others with snow tires had some issue. This tires stick very well to ice and snow, impressed. No tire spin, but I do also have QD.
Update 2/1: Traction does drop off as the snow gets over 3-4 inches and the temperatures plummet bellow 10 degrees. Much better than the OEM Forteras, but no contest for the Blizzaks.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
Unread 09-25-2013, 02:02 PM   #277
snwbrdr
2012 WK
WK2 with JK Sahara Wheels - which Lug Nuts?
Hello everybody from good old Europe
I've just bought a 2012 WK2 with the diesel engine, and would like to use the JK Sahara wheels as winter tires.
But I couldn't find any information about which lug nuts to use. Currently I'm running the factory 20 inch rims, will those nuts fit the Sahara wheels?
Thanks!
Adrian
Last edited by Jackal01; 09-25-2013 at 02:13 PM.. Reason: Yet another wheel question. Moved to one of the wheel and tire threads. Searching is a valuable tool.
snwbrdr is offline   Reply With Quote Quick reply to this message
Unread 09-25-2013, 02:33 PM   #278
snwbrdr
2012 WK
that was fast, thanks dave!
Unread 09-25-2013, 02:43 PM   #279
XJ2WK2
2011 WK
Originally Posted by Dave2002ti View Post
The lug nuts from the Sahara wheels.
Isn't the JK still an imperial thread?? The WK2 is metric. I used my stock lugs from my 17's for my Sahara Wheels.
XJ2WK2 is offline   Reply With Quote Quick reply to this message
Unread 09-25-2013, 05:16 PM   #280
ColdCase
ColdCase's Avatar
2011 WK
The WK2 lugs are longer than JKs too, dunno if it makes enough of a difference to bottom out.
Unread 10-04-2013, 08:36 PM   #281
1quick1
2014 WK
255/75/17's stock Laredo WK2 wheels pics
I decided to make a thread instead of post in the 40 pages of stickies that do not answer this question for those who are wondering.
I had a very difficult time finding if a Wrangler Rubicon JK 255/75/17 BFG KM1 would fit a 2014 Jeep Grand Cherokee Laredo on stock wheels. After searching for 2 days I didn't find a clear answer but what I did find is limited/summit guys have no problem running a 265/65/18 which is the same diameter but .4" wider. My theory was if that fits the Rubi tires will. The tire is .4" wider than stock and 1.6" taller.
So I found a brand new set on Craigslist for $500 and took them to Discount Tire. I told the guy they "wouldn't fit" according to his computer but I wanted them to try anyways. They quoted me 45 minutes so I went next door to the bar and had a beer. They called me and said they fit perfectly.
Went and picked it up and did some testing. Now understand I haven't articulated these at all but I did take them full turn left and right with no rub. I put it on a curb full turn and no rub.
I took it on the highway to do a speedo test and at 60mph on the GPS I'm reading 58-59mph so you will be slightly low. So without further dealt...the pics.
BTW Mods I searched the internet far and wide and it'll probably serve well to leave this thread as it WILL show up on GOOGLE when people search.
Base 2014 Grand Cherokee Laredo v6 no QL and QT1.
Before
After
2006 Jeep Liberty - sold
2009 Jeep Liberty Limited - sold
2012 JK Rubicon - sold
2014 Jeep Grand Cherokee Laredo (current vehicle)
32'' BFG KM's 255/75/17's on stock Laredo wheels
1quick1 is offline   Reply With Quote Quick reply to this message
Unread 10-04-2013, 09:25 PM   #282
ColdCase
ColdCase's Avatar
2011 WK
Nice tires/wheels, good info. I've seen 265/70/17s fit but don't think anyone tried them on your wheels.
Unread 10-04-2013, 09:31 PM   #283
1quick1
2014 WK
Thanks! I'm ecstatic they fit.
The Rubicon's use a 17x7.5" wheel so that's why I figured there wouldn't be an issue with a 17x8.0 Laredo wheel. 265x70x17 is actually .5" taller so I imagine that's a really tight fit.
This should help a lot of people because Rubicon tires are readily available on Craigslist as a lot of owners immediately go bigger.
Just remember though if you pick up the wheels AND tires that changes the game as the Rubi mohab wheel will rub the front rotors and has a different backspace. People have done it though with spacers. (according to this thread)
Unread 10-17-2013, 09:14 PM   #284
warrick
2014 WK
hi new to the forum. heres my 2014 limited on 18x9 mayhem chaos on 275 Kelly safaris
2014 grand Cherokee limited bright white 3.6 275 Kelly safaris 18x9 mayhem chaos black wheels
warrick is offline   Reply With Quote Quick reply to this message
Unread 10-17-2013, 09:31 PM   #285
Jcrame00
I wanted a highway cruising tire as I have a set of dedicated snows. There seems to be a wide variety of 275/55R20 tires available, but I wanted to stay with the 265/50 stock size. Folks around here rave about the Nitto Terra Grapplers so I thought Iíd give their recently released NT 421Q a try.
Iíll update when I get a few more miles.
Edit: After break in the tires are much quieter, less noise than the OEMs. These stick to dry and wet roads without protest. They are much more confidence inspiring than the Forteras. It is a heavy SUV, however. Worth the $240 difference, I dunno yet. By the way, you may notice a tire machine scratch on one of the photos. Tire shop replaced the wheel with a new one, no hassle.
ColdCase - I am shopping for replacement tires with same rim set-up as you. I was glad to came across your post regarding Nitto 421Q. Do you have any updates regarding your experience (in addition to recent updates posted)? Did you consider any other choices. My issue is NTB has sale on in-stock OEMs buy 3 get 1 free ($394). I really want to try Nitto but this price is approx. 50% of Nitto. Are the "pros" enought to make the switch? Thx
Jcrame00 is offline   Reply With Quote Quick reply to this message
