Wheel and Tire Thread - Page 14 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Wheel and Tire Thread
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Jeep speedometer gears at rockridge4wdHey Guys - Extreme Terrain Jeep Outfitters - ExtremeTerrai
Unread 08-08-2013, 11:49 PM   #196
2014LAREDO
Here's mine.....................
BEFORE.....................
After........................
2014LAREDO is offline   Reply With Quote Quick reply to this message
Unread 08-09-2013, 11:26 AM   #197
Shub45
Sweet! thanks. How's the quality seem to you and did you reuse your tps sensors?
Shub45 is offline   Reply With Quote Quick reply to this message
Unread 08-09-2013, 11:44 AM   #198
2014LAREDO
Quality and service is great. Got the wheel and tire package from OE Wheels through Ebay. Paid $1525 for everything........tires, wheels, tpms sensors, center caps and shipping.
http://www.ebay.com/itm/20-Black-Chr...90422283170%26
Unread 08-10-2013, 11:28 AM   #199
bsdubois00
2012 WK
2014 GC Laredo Wheel Upgrade Questions
I'm the new owner of a 2014 GC Laredo and looking to upgrade to some of the aftermarket SRT Replica wheels. All of the ads I am seeing say that they fit up to 2012 or 2013 - will these still fit the 2014s?
5x5" / 5x127mm bolt pattern
Also 9" width or 10" width - which is the best way to go?
Last question - can I have the tire pressure sensor removed from my current tires and put in the new ones?
Thanks!
Brandon
bsdubois00 is offline   Reply With Quote Quick reply to this message
Unread 08-11-2013, 07:41 PM   #200
Trespasser
JK Takeoffs - 15k Mi Review
Just wanted to share my experiences running JK Sahara wheels and tires for over a year now.... Awesome!
I've had no rubbing or steering issues, no noticable decrease in MPG or power, and I've gotten more than a few comments along the lines of "big rubber on that Jeep!"
If you find a good deal on Wrangler JK take-offs (I got all 5 for $400) don't hesitate to make your WK2 a little different than the masses!
Last edited by Jackal01; 08-11-2013 at 08:58 PM.. Reason: Merged with the dedicated tire and wheel thread.
Trespasser is offline   Reply With Quote Quick reply to this message
Unread 08-11-2013, 10:39 PM   #201
Saltriverfolk
2013 WK
My GC came with Michelin Latitude tours. P265 60r 18s. I have been reading about folks going up to a P275 for the wider look. Does anyone have any experience with upping the tire width on stock rims? Will it adversely affect safety and handling?
Last edited by Jackal01; 08-12-2013 at 08:35 AM.. Reason: Merged with the dedicated tire and wheel thread.
Saltriverfolk is offline   Reply With Quote Quick reply to this message
Unread 08-12-2013, 01:32 AM   #202
loveracing1988
Thanks!
Brandon
The lug pattern is still the same, I am not sure on the width, but that depends on what tire size you are looking at. The sensors can be removed from yours and put in the new ones, they are attached to the valve stems I believe.
loveracing1988 is offline   Reply With Quote Quick reply to this message
Unread 08-12-2013, 08:13 AM   #203
WKdeuce
They're also available from NAPA for like $30 each.
2011 5.7L WK2 | 5.3L TJ work in progress
Rust in Pieces Blue
JEEP FIEND CLUB
WKdeuce is offline   Reply With Quote Quick reply to this message
Unread 08-12-2013, 08:39 AM   #204
2k2wranglerx
need some wheel alternatives... jk wheels?
I tried searching but i'm failing....
my wife has a '11 wk2 with the 70th anniversary package and 20" wheels. her tires are going to be about 50-60% in the back and 60-70% up front this winter... i'm not all that crazy about letting her run in the snow/ice with them that thin but i'm having trouble replacing them when they have that much life left in them.
i'm contemplating buying dedicated snow tires for it but was debating on having them put on the 20" wheels or grabbing another set of wheels for snows. I didn't know if JK wheels fit. They're plentiful and relatively cheap. and the 16" steel ones are super cheap (if not free).
just looking for input. thanks guys!
93 yj. 355 chevy, heads, cam, intake, etc. 35's, bumpers, winch, lights, and a killer stereo.
2k2wranglerx is offline   Reply With Quote Quick reply to this message
Unread 08-12-2013, 06:56 PM   #205
flexmerc
2014 WK
Robby Gordon Wheels on a 2014 WK2
Has anyone seen a 2014 on Robby Gordon Signature Series Wheel, would they actually fit?
Thanks
flexmerc is offline   Reply With Quote Quick reply to this message
Unread 08-13-2013, 06:32 AM   #206
2k2wranglerx
so I found some wheels/tires off a '13 jk sahara (which is a nice looking wheel). will they fit without quadralift? I have a regular 70th anniversary with the standard suspension.
thanks!
Unread 08-13-2013, 03:31 PM   #207
jim_in_PA
2012 WK
Two words: Brake Clearance. If you have the "regular" brakes on your JGC, you can run 17" wheels, but if you have the "heavy duty" brakes your minimum is 18" wheels.
2012 Grand Cherokee Overland Summit 5.7L V8 - Winter Chill with New Saddle Interior - Nitto NT421Q
jim_in_PA is offline   Reply With Quote Quick reply to this message
Unread 08-13-2013, 05:33 PM   #208
loveracing1988
How do you know which you have?
V6's only have standard brakes. V8's have HD brakes in limited and above trims for the 11 to 13's.
Unread 08-21-2013, 10:22 PM   #209
JKashat
Bump.
I picked up a 2014 GC Summit HEMI. Anyone know if the wheels I mentioned will work or not? They are 20x9, 5 on 5 bolt pattern. 4.5" bs. Hub centric for wrangler Jk. Also, can I reuse the 20" tires off the Summit?
Originally Posted by JKashat
I'm seriously considering getting (on Monday) a 2014 GC, either Overland or Summit. I have a set of wheels I'd like to use.
The specs are as follows:
20x9 -12mm offset (4.5" backspacing) wheel
Would these fit or stick out TOO much?
Thanks in advance!
Jeff
JKashat is offline   Reply With Quote Quick reply to this message
Unread 08-23-2013, 11:26 PM   #210
Saltriverfolk
2013 WK
After much deliberation over all terrain TIRES, both the friendly Sears folks and I agreed today the Michelin LTX ATs were the right choice!
