Wheel and Tire Discussions - Page 9 - JeepForum.com
 90Likes
post #121 of 2844 Old 09-22-2011, 01:45 AM
table
table's Avatar
2015 JK Wrangler
Looks very nice. How did you get the lights wired up?
2015 Anvil JKU | Sahara | Manual | 3.73
RIP: 2000 WJ | Initiated Destruct Sequence One | Code: 11A
table is offline
post #122 of 2844 Old 09-22-2011, 12:48 PM
wahoo
2011 WK
I still need to get them wired, I'm going to leave that up to the professionals. I'll let you know how it comes out.
wahoo is offline
post #123 of 2844 Old 09-27-2011, 06:52 PM
KJlimit
2006 KJ Liberty
Looks nice...are you planing on leaving the spare with the floor sticking up?
KJlimit is offline
post #124 of 2844 Old 09-28-2011, 12:36 AM
wahoo
2011 WK
Thank you. I found a spare tire mount that attaches to the receiver. I'll post some pics after I install it this weekend.
wahoo is offline
post #125 of 2844 Old 10-05-2011, 09:21 PM
dedoman
2011 WK
Also interested in the costs with the tires and rims? Can you give a ball park idea? Would like to do the same! Any thoughts on level kit or the ONLY lift avail. Right now from Rocky Road?
dedoman is offline
post #126 of 2844 Old 10-06-2011, 10:32 AM
wahoo
2011 WK
For all five tires and wheels it was about $2500 out the door. I'm not sure on the lift, I have the Quadra Lift system so there are no options for that I dont believe, but the set up I have doesnt need one.
wahoo is offline
post #127 of 2844 Old 10-10-2011, 06:47 PM
RJG57
No one has mentioned the Mickey Thompson Baja STZ tires, has anyone tried or know anything about these new tires??
RJG57 is offline
post #128 of 2844 Old 10-13-2011, 06:12 AM
thecegla
2011 WK
Hi guys I'm newbie on this forum and in off-road at all.
I just got a first Jeep and had couple of trips with it to the desert - as this is most common in the place I live.
I got stuck few times, mostly due to lack of experience , however I believe changing a tire/rim combination might improve sand/desert capability of the car.
Although I like above presented solutions, I was thinking about fixing smaller rims -16'' (presently stock 18''), so i get even greater footprint on the send when deflated. Also was considering if installing steel rims would not be a good idea as I believe it is harder to loose tire.
For that planning to buy 275/70/R16 (maybe 275/75/R16 but those seem to be too high).
I'm really curious about your opinion ... any serious cons ??
thecegla is offline
post #129 of 2844 Old 10-13-2011, 07:54 AM
fljeepleo
2011 WK
Well first thing is what is your engine? If you have the Hemi the smallest wheel that will clear the brakes is the 18 inch. If you have the pentastar I believe the smallest you can do is a 17 inch. I maybe mistaken on the 17 inch but if you have the hemi due to the HD brakes anything under 18 will not fit.
2011 Stone White Grand Cherokee Laredo E, ORA1, QT2, Factory Trailer Tow, 3m FX 15% Tint.
Retired Jeeps
1998 Wrangler Sahara 10inch skyjacker lift, 38x14.50 TSL
2005 Grand Cherokee Limited, 5.7, QD2
fljeepleo is offline
post #130 of 2844 Old 10-13-2011, 08:31 AM
Terminator2
Originally Posted by thecegla View Post
It is V6 Pentastar ...
16s will likely not clear the calipers as 17s are the smallest that supposedly fit the v6 and 18s the smallest that fit the v8 so unless you want to grind down your stock calipers the 16s will not fit.
Terminator2 is offline
post #131 of 2844 Old 10-13-2011, 08:56 AM
thecegla
2011 WK
cheers guys,
so I have to check what is available with size 275/70/17 (or maybe even 275/65/17), (after all I read here I guess 275/75 /17 will not fit)..
If you could only comment also is steel rims are good idea or not ?
thecegla is offline
post #132 of 2844 Old 10-13-2011, 11:14 AM
Terminator2
cheers guys,
275/70/17 (~32.2" tall) might fit but it might rub depending on the tires actual specs. 275/65/17 (~31.1" tall) should fit easily with no rub unless you are trying to run a 17x10 wheel with it.
post #133 of 2844 Old 10-13-2011, 12:26 PM
thecegla
2011 WK
thank you very much for all comments - really appreciate it
Now need to check what is available here in terms of rims and tire in this size.
Maybe I'll have to order in states ...
Also was wondering if any of you guys had experience inner bead locks like those for example: http://www.innerairlock.com/beadlocks/
they seem to be a good solution (not cheap though) as it would allow to deflate down to 10 PSI even - this is very helpfull on very loose sands, which can happen really out of the sudden here (learned it hard way )
thecegla is offline
post #134 of 2844 Old 10-13-2011, 12:46 PM
Terminator2
Yeah I have some sand but nothing like you have. My Jeep has no issues crawling the sandy (and some nasty slick clay) trails behind my house with the tires fully aired up to 36 psi and I have 265/50/20s so I have 1" less sidwall on each par of my tires. I will be running 275/55/20 tires eventually or I might go down to 18s and run 275/65/18s. I have not seen inner beadlocks but if that works than it would be a good mod to have.
post #135 of 2844 Old 10-17-2011, 08:28 PM
EVILUTION
This is not my picture but I think the 275/55/20's look great on the stock wheels!
2011 JEEP GRAND CHEROKEE OVERLAND 4X4 HEMI
2002 JEEP GRAND CHEROKEE LIMITED QD
EVILUTION is offline
conversion , headlight , oneighty , vinyl , wrap
Bulls_Fan , vasculopath
WK2 Picture Thread Texas WJ WK2 Grand Cherokee Forum 2667 10-10-2017 10:48 AM
Overland Wood Steering Wheel? Stephen5242 WK2 Grand Cherokee Forum 32 03-22-2011 01:17 PM
What is the Wheel Bolt Pattern getoutandplay WK2 Grand Cherokee Forum 3 11-27-2010 08:18 PM
