Wheel and Tire Discussions - Page 6 - JeepForum.com
 79Likes
post #76 of 2763 Old 06-16-2011, 01:03 PM
mchassler
2011 WK
Originally Posted by 2011Hemi View Post
They are 275/65R18 stock was 265/60R18, went from a 30.5" tire to 32".
Originally Posted by getoutandplay View Post
Guys,
Each of you have installed a 32" x 10.83" tire on your factory wheels. One a 275/65r18 and the other a 275/55r20.
2011Hemi, I am not sure if you have QL. I know that getoutandplay has QL.
Since the time of your original posts have either of you experienced any problems with the 32" tire in your stock setup? More curious about when turning in a circle and things like that.
My reason for asking...
I installed the Rocky Road 2.5" Spacer Lift (you may have seen my post) and I am baffled on what size tires I can truly fit.
Rocky Road's website insists that a 275/55r20 (32" x 10.83") is the largest tire that will fit even with the lift. Obviously, there is plenty of room in there for a taller tire if one were to drive in only straight lines. But, I am unable to determine the amount of room for turning.
I would like to put a 275/60r20 (32.99" x 10.83") tire in there and I do not want to use spacers. I am not adverse to trimming the inner felt fender if needed.
Could either of you, or anyone else with a 32" tire and stock rim, take some photos inside your fender showing the amount of room with your 32s?
I'd really appreciate it.
2014 JKU Rubicon X
mchassler is offline
post #77 of 2763 Old 06-16-2011, 04:21 PM
rolexjake
2011 WK
285 60 18 terra grapplers
18x9 xd addicts
2011 black grand cherokee + kmc black addict rims = a beast = my jeep
rolexjake is offline
post #78 of 2763 Old 06-16-2011, 04:23 PM
rolexjake
2011 WK
285 60 18 nitto terra grapplers
18x9 addicts
i am getting a 1.75 inch leveling kit in 3 days put on
post #79 of 2763 Old 06-16-2011, 07:10 PM
kkuntz01
18x9 addicts
Now what is the off set you're running on those? Do they stick out much if at all beyond the wheel wells/flares?
Sure my rig has seen the trail, but I wheel it like a soccer mom looking for a parking spot at Nordstroms.
kkuntz01 is offline
post #80 of 2763 Old 06-17-2011, 12:05 AM
rolexjake
2011 WK
i have +18 i think....
post #81 of 2763 Old 06-17-2011, 04:40 PM
rolexjake
2011 WK
heres one
post #82 of 2763 Old 06-17-2011, 04:41 PM
rolexjake
2011 WK
heres another
post #83 of 2763 Old 06-17-2011, 04:42 PM
rolexjake
2011 WK
last one
post #84 of 2763 Old 06-18-2011, 09:05 AM
Richard338
2013 WK
Was in my local Jeep place and found a set of 18" Sahara wheels and tires for $500. So now, whats the current opinion on tire sizes for JGC Overland. I'm thinking 265/65-18 or staying with the 255/70-18. Whats the difference in offset-setback from the stock wheels and what sizes are being run?
Richard338 is offline
post #85 of 2763 Old 06-19-2011, 06:22 PM
webspoke
Originally Posted by swankster988 View Post
Webspoke, I don't have quadra lift, would your setup fit my jeep or would I have to get a smaller size tire? I really like the wide stance. It looks more aggressive which is what I want.
Rolexjake has the same size tire and similar wheel on his non QL and it fits without issues. You can see pics in the wheel and tire thread here. I think the non QL jeeps acutally ride a bit higher in the front, so you will be fine.
webspoke is offline
post #86 of 2763 Old 06-19-2011, 09:00 PM
webspoke
Originally Posted by Aquaforest View Post
Anyone know what the offset is on the stock 20" Overland wheels?
56mm
webspoke is offline
post #87 of 2763 Old 06-19-2011, 10:50 PM
rolexjake
2011 WK
18x9 addicts
post #88 of 2763 Old 06-20-2011, 08:50 AM
swankster988
So when I put the 285 60 18 nittos on will this change my speedo
swankster988 is offline
post #89 of 2763 Old 06-20-2011, 12:55 PM
webspoke
Yes, your speedo will read low by 3%. It is about 2mph at 70mph (reads 70, actually running 72). I've checked mine against a GPS and that is pretty accurate.
webspoke is offline
post #90 of 2763 Old 06-28-2011, 07:20 PM
boostedboxer
2010 JK Wrangler
Anyone tried 275/65R18 goodyear duratracs on the stock wheels? Discoverer stt's are another option
boostedboxer is offline
conversion , headlight , oneighty , vinyl , wrap
WK2 Picture Thread Texas WJ WK2 Grand Cherokee Forum 2590 06-19-2017 05:24 PM
Overland Wood Steering Wheel? Stephen5242 WK2 Grand Cherokee Forum 32 03-22-2011 01:17 PM
What is the Wheel Bolt Pattern getoutandplay WK2 Grand Cherokee Forum 3 11-27-2010 08:18 PM
