Wheel and Tire Discussions - Page 43 - JeepForum.com
 79Likes
post #631 of 2768 Old 11-12-2013, 06:49 PM
gabbagabba
2014 WK
Originally Posted by loveracing1988 View Post
Provided you have the V6 no. If you have the towing package and the hemi you have heavy duty brakes which require the 18" wheels. To double check look to see if the rear disks are vented. If they are then you have the heavy duty brakes.
Loveracing, you are incorrect I'm sorry to say. 18" rims for that WK2. ORA2 incl towing package and unless he wants to get out a grinder 17" wheels are listed as a no go for a 2014 ltd (I have one)
gabbagabba is offline
post #632 of 2768 Old 11-12-2013, 06:52 PM
gabbagabba
2014 WK
Whatever it says on the door sticker. Anywhere from 35 to 40 should be fine. The tires are the same size and I'm sure still a standard load rating so the pressure on the door jam still works.
Door sticker is 33# as noted. That seemed fine with stock tires, at 255 70 18 I find it rides harsh at anything over 31#. 35 to 40 would be brutal me thinks even in stock (35 maybe, 40 no way)
post #633 of 2768 Old 11-12-2013, 06:55 PM
lope2919
2013 WK2 Overland
275/60R/18-10 Big HORNS
lope2919 is offline
post #634 of 2768 Old 11-12-2013, 07:02 PM
loveracing1988
The towing package only includes heavy duty brakes if you have the hemi or the diesel unless they changed things for 2014. That is why I told him to double check. I still haven't seen it confirmed if the high trimmed v6's with the towing package come with the heavy duty brakes.
loveracing1988 is offline
post #635 of 2768 Old 11-12-2013, 07:03 PM
loveracing1988
Ours only has the 17's but I have ran 40 pounds of air in them since we bought it and it still rides really good. I will be backing it down to 35 for the winter though.
post #636 of 2768 Old 11-12-2013, 08:20 PM
TruBluJeep
2014 Jeep GC Limited Wheel Choices
So I just purchased a 2014 JGC Limited in white. I love it just want to change the wheels not feeling the stock 18's. How do you think black 20' altitudes will look with the white? or should I just upgrade to the overland 20's?
TruBluJeep is offline
post #637 of 2768 Old 11-12-2013, 11:42 PM
lope2919
2013 WK2 Overland
IN PARK MODE
lope2919 is offline
post #638 of 2768 Old 11-12-2013, 11:45 PM
lope2919
2013 WK2 Overland
IN 1" MODE
lope2919 is offline
post #639 of 2768 Old 11-12-2013, 11:49 PM
lope2919
2013 WK2 Overland
In the 2.5" lift mode
lope2919 is offline
post #640 of 2768 Old 11-13-2013, 08:08 AM
nagafs
Hey do you guys know if 18" 2012 Wrangler rims wil fit on my 2011 Grand Cherokee Overland for winter use, currently I am running 20" on the Overland
nagafs is offline
post #641 of 2768 Old 11-13-2013, 11:23 AM
gabbagabba
2014 WK
Originally Posted by kkreit01 View Post
17" is the smallest on V6. 18" is the smallest on Hemi.
See other tread this is not necess the case. My '14 WK2 with towing package and V6 has the big brakes so no 17"
post #642 of 2768 Old 11-13-2013, 11:55 AM
gregory30
on the other side i have 20' in summit 2014 but looking for 18' for it(for winter). which one would you prefer?
for example justforjeeps have only 20' OEM rimms http://www.justforjeeps.com/jegrchwh...s_per_page=100
gregory30 is offline
post #643 of 2768 Old 11-13-2013, 02:33 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
justforjeeps is pricey. You can get OEM accessory 18s from forum sponsor moparonlineparts.
For example: http://moparonlineparts.com/jeep-gra...27_52_357.html
You can also check their repair parts page for OEM. Code WPR are the 18s I think.
There is also OEM wheels on ebay.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #644 of 2768 Old 11-14-2013, 02:28 AM
gregory30
i have contacted them, i send my VIN, no rimms available.
that http://moparonlineparts.com/jeep-gra...lic-p-841.html will not fit summit 2014.
post #645 of 2768 Old 11-14-2013, 02:44 AM
loveracing1988
If they fit the lower trims they fit a summit. It says right on there that they fit 2014's... any wheel will fit from model year 2011 to 2014 provided they will clear the brakes.
conversion , headlight , oneighty , vinyl , wrap
CG27519
WK2 Picture Thread Texas WJ WK2 Grand Cherokee Forum 2590 06-19-2017 05:24 PM
Overland Wood Steering Wheel? Stephen5242 WK2 Grand Cherokee Forum 32 03-22-2011 01:17 PM
What is the Wheel Bolt Pattern getoutandplay WK2 Grand Cherokee Forum 3 11-27-2010 08:18 PM
