Wheel and Tire Discussions - Page 25 - JeepForum.com
 58Likes
post #361 of 2649 Old 04-11-2013, 10:17 AM
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Originally Posted by illflo View Post
Jackal,
Thanks! Wasn't sure if I had missed something. The best way to double check would be to use a dash-mounted GPS. Most will display your speed using the time it takes you to travel a certain distance based on your GPS coordinates, so it's not biased by wheel size. Set your cruise to 60, give the GPS a minute to catch up, and see if it reflects that you're traveling 60 mph. You want to stay at speed as long as possible to insure the GPS gets a good signal and read (They normally update every second or so). It's a quick and easy way to make sure your speedo is accurate. If you don't own a GPS see if you can borrow somebody's. 70 or 80 would be a better speed to use (because speedo inaccuracies will be exaggerated at higher speeds) but some folks don't have roads on which they can drive that fast.
I did that the day I did it. I even downloaded a couple speedo/GPS apps along with my GPS AND even drove by one of the automated speedo signs by LE on the side of the road. All the readings were 1 or 2 off the Jeep speedo.
2011 Billet JKUS
Jackal01 is offline
post #362 of 2649 Old 04-11-2013, 12:25 PM
Alaska-HWY JK
Originally Posted by Jackal01 View Post
Dealer can reprogram the computer. I did last year although I have no way to really tell if they did.
Sent from my underground lair.
This is the first I've read where any dealer can reprogram for differant sized tires on a GC.
Alaska-HWY JK is offline
post #363 of 2649 Old 04-11-2013, 08:05 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
That must have bee a recent change to their software. The tire factor menu item used to not even be presented for the WK2, as they wouldn't need to change it anyway (all the OEMs have the same tire diameter regardless of wheel size). Other chrysler vehicles can be programed by picking a tire factor from a menu, but the only factors presented to the tech are those for OEM sizes. Nothing aftermarket. On my 2006 RAM I just got used to adjusting 5%.
Running oversize tires on the WK2 is not an approved Jeep mod or an offered accessory.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #364 of 2649 Old 04-12-2013, 09:37 AM
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Although I do not trust the dealership with much when I asked them to reprogram the computer for my larger tires they said they could and did. Now, post larger tires and before the reprogram my speedo displayed speeds very rapidly ie: traveling 40 mph the EVIC would "flicker" 40-41-39 etc very quickly. After the reprogram the the EVIC/speedo worked as normal. Not sure what was really performed since the invoice only said "customer requested reprogram of computer for larger tires" and charged me $60. I think they did however I cannot know that 100% since I cannot see the computer specs obviously. And this was a year ago I did this.
2011 Billet JKUS
Jackal01 is offline
post #365 of 2649 Old 04-12-2013, 11:33 AM
jacko15
2014 WK
Did you try checking your speed against a GPS?
Hers: 2008 Jeep Compass Sport
Mine: 2014 Jeep Grand Cherokee Overland V/6 ORA II
Michelin LTX M/S 2's
jacko15 is offline
post #366 of 2649 Old 04-12-2013, 12:03 PM
Jackal01
Jackal01's Avatar
2011 JK Wrangler
yes.
http://www.jeepforum.com/forum/f309/...l#post15280893
2011 Billet JKUS
Jackal01 is offline
post #367 of 2649 Old 04-12-2013, 03:45 PM
jacko15
2014 WK
Sorry, I missed that.
jacko15 is offline
post #368 of 2649 Old 04-12-2013, 05:59 PM
Jackal01
Jackal01's Avatar
2011 JK Wrangler
No problem dude.
2011 Billet JKUS
Jackal01 is offline
post #369 of 2649 Old 04-15-2013, 03:39 PM
silve
2013 WK
Fuel Boost Wheels; which will fit? if any...
Anyone know which, if any of these wheels will fit our wk2's the best? wheel is fuel boost. just have a stock laredo with regular suspension. hope someone can help me out!
http://www.4wheelparts.com/Wheels/Wh...Style_PQ=Boost
silve is offline
post #370 of 2649 Old 04-15-2013, 03:40 PM
silve
2013 WK
to be more clear, which offset and backspacing combo would fit our wk2's, if any
silve is offline
post #371 of 2649 Old 04-15-2013, 05:30 PM
Jackal01
Jackal01's Avatar
2011 JK Wrangler
There are tire and wheel threads. Moved.
2011 Billet JKUS
Jackal01 is offline
post #372 of 2649 Old 04-16-2013, 09:10 AM
webspoke
Offset 20 would push the wheels out almost 1.4" from stock. Offset 14 will push them out 1.6". I would suggest the +20 offset. My wheels are +25 and I would not want them out any further, as at stock heights you can rub the fenders and liners with wider and taller tires on. If you lift you have a bit more freedom.
2013 White V8 Limited, 285/60/18 Terra Grapplers, 25000 miles problem free
2011 Black V8 Overland, retired at 46000 miles with QL problems
webspoke is offline
post #373 of 2649 Old 04-16-2013, 01:08 PM
silve
2013 WK
thanks! would the 5.75 backspacing work on our jeeps?
silve is offline
post #374 of 2649 Old 04-16-2013, 01:52 PM
ColdCase
ColdCase's Avatar
2011 WK
Depends, If that's an 8 inch wheel, a 5.75 backspace will push the tire 1 inch out. If a 10 inch wheel, 2 inches out.
ColdCase is offline
post #375 of 2649 Old 04-16-2013, 03:25 PM
brn2skifst
2012 WK
I have a 38 ET with a 9.5" wheel and the 275/60 18's sit about 1/4" outside the fender but it still have close to stock backspace so it gives it a very aggressive look. It also keeps a good geometry for going over obstacles by keeping the inside of the wheel closer to the diff.
brn2skifst is offline
conversion , headlight , oneighty , vinyl , wrap
GreenGreySS
WK2 Picture Thread Texas WJ WK2 Grand Cherokee Forum 2507 03-26-2017 02:58 PM
Overland Wood Steering Wheel? Stephen5242 WK2 Grand Cherokee Forum 32 03-22-2011 01:17 PM
What is the Wheel Bolt Pattern getoutandplay WK2 Grand Cherokee Forum 3 11-27-2010 08:18 PM
