Wheel and Tire Discussions - Page 21 - JeepForum.com
 79Likes
post #301 of 2769 Old 01-10-2013, 07:35 AM
NYWk266
I think I narrowed my choice to the MB TKO in chrome. The specs are.
18x9
Back spacing: 5.98 in
Offset: +25
How would these fit on the WK2. I'd prefer to keep things as tucked under the fender as possible.
Thanks!
Sent from my iPhone using AutoGuide.com App
NYWk266 is offline
post #302 of 2769 Old 01-14-2013, 08:38 PM
webspoke
18x9
Offset: +25
Thanks!
I have that offset in 18x8.5 with 285's. Sits just a bit outside the fenders.
2013 White V8 Limited, 285/60/18 Terra Grapplers, 25000 miles problem free
2011 Black V8 Overland, retired at 46000 miles with QL problems
webspoke is offline
post #303 of 2769 Old 01-14-2013, 10:27 PM
NYWk266
So the 9 inch wide rim would stick out a tiny bit more?
That setup looks perfect. I plan on swapping on the stock tires till they wear then replacing them with something that size.
NYWk266 is offline
post #304 of 2769 Old 01-15-2013, 11:19 AM
webspoke
The 9" wide rim will still sit in the same location, as the offset is measured to the center of the wheel. You will have less sidewall bulge with the wider rim though. What size tire are you looking at? With my 285's (31.5" tall) I get some rub on the drivers wheel well on big road dips with the stock suspension. If you use a lift or leveling kit, you will have no problems.
webspoke is offline
post #305 of 2769 Old 01-24-2013, 06:57 PM
Jeepfreak86
2015 WK
Originally Posted by XJ2WK2 View Post
Procomp 7036, 0 offset, 275 65 18 Duratracs (Big50s setup)
Would this setup work well with the stock height/suspension? Or would you need a lift kit to have these fit without any rubbing issues?
Jeepfreak86 is offline
post #306 of 2769 Old 01-24-2013, 07:30 PM
alpine24
2006 WK
I believe some have reported this setup having minor rubbing in the front even with the lift. At stock height I would imagine these tires would definitely rub.
alpine24 is offline
post #307 of 2769 Old 01-31-2013, 01:44 PM
grandcherokee13
Hi guys, maybe someone knows? can I place on 4x4 laredo 2013, 295/45/20 size tires all set?
grandcherokee13 is offline
post #308 of 2769 Old 01-31-2013, 06:09 PM
Rneum
Originally Posted by UNCjeepWK2 View Post
Anyone tried (or bought) the Michelin LTX A/T tires?
Yes. I have used them for the last 3 sets on a suburban. Can't beat them. Quiet and 60-70k miles and they are good in snow.
Rneum is offline
post #309 of 2769 Old 02-03-2013, 09:03 AM
Mostoyzwinz
American Racing Fuel 321 with Goodyear Duratracs 245x70x17. This setup gives the stock tire circumference and increases the tire to control arm clearance (backspacing) to allow more room for tire chains up front. Couldn't use std chains with stock setup in front so bought expensive Thule XG-12 chains...which are still too close for comfort.
2011 Jeeep wheels chains Feb13 009.JPG   2011 Jeeep wheels chains Feb13 012.JPG   2011 Jeeep wheels chains Feb13 010.JPG   2011 Jeeep wheels chains Feb13 002.JPG   2011 Jeeep wheels chains Feb13 003.JPG
Mostoyzwinz is offline
post #310 of 2769 Old 02-03-2013, 08:43 PM
gremlinsteve
tire size question
any one running a 275/65/18 tire of some thing that is of the same diameter and width?
im looking at some of these in a m/t and i see the width is the same as the 265/60/18 a/t that i currently have on the trailhawk...
any ideas on if this combo will rub or not. close to the same outer diameter as the jk 255 wheel/tire combo
steve
gremlinsteve is offline
post #311 of 2769 Old 02-03-2013, 09:41 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Seems to work. See the discussion starting about post 22 of this thread:
http://www.jeepforum.com/forum/f309/...22/index2.html
You could also try searching for 275/65/18
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #312 of 2769 Old 02-06-2013, 08:57 PM
plum4457
2013 WK
New Jeep - Aftermarket Wheels/Tires
Hi all, great site this is my first post. I am planning on picking up a 2013 5.7 Laredo X tomorrow and have a question. I would like to get new wheels (20's) and tires right away but am unsure the best way to do that. What would one do with the stock ones? Would a tire shop or someone buy them? Is this something that is best handled at the dealer as they may have better use for the stock stuff? Any advice appreciated.
plum4457 is offline
post #313 of 2769 Old 02-06-2013, 09:20 PM
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Welcome. Depends on the shop. Discount tire should give at most $50 per brand new tire, that was their offer to me. So $200. Nothing for the wheels. I sold, locally, each tire for $100 and each wheel for $100. I am sure I could have gone higher but I wanted a fast sell. I dont think the dealer would be any better. Some owners even keep the stockers to use as winter setups or other setups for different terrains or seasons. I don't go that route so I wanted to sell them. I would try and sell locally if you have a large enough market otherwise it may be difficult.
2011 Billet JKUS
Last edited by Jackal01; 02-06-2013 at 09:21 PM. Reason: Please read the rules and guidelines. There are stickies dedicated to wheels and and tires thus I merged your thread with thi
Jackal01 is offline
post #314 of 2769 Old 02-09-2013, 07:12 PM
Cknight199
WK2 Tire and Wheel Sizes
Has anyone ran 20" rims with street tires or 22" rims? I want a sporty street look and just gathering info
Sent from AutoGuide.com App
Cknight199 is offline
post #315 of 2769 Old 02-09-2013, 09:03 PM
ColdCase
ColdCase's Avatar
2011 WK
20 inch is Std size for Overlands and optional on most other models. There have been a couple here run 22 inch rims, but I haven't.
ColdCase is offline
conversion , headlight , oneighty , vinyl , wrap
WK2 Picture Thread Texas WJ WK2 Grand Cherokee Forum 2598 Today 01:47 PM
Overland Wood Steering Wheel? Stephen5242 WK2 Grand Cherokee Forum 32 03-22-2011 01:17 PM
What is the Wheel Bolt Pattern getoutandplay WK2 Grand Cherokee Forum 3 11-27-2010 08:18 PM
