Wheel and Tire Discussions - Page 14 - JeepForum.com
 90Likes
post #196 of 2852 Old 04-29-2012, 07:44 AM
the1jake
Originally Posted by wahoo View Post
Your Jeep looks great! I got an external spare tire holder from tiregate.com, it cost $995 so if you can build it for $250, thats awesome. Here are some pics of it and a rack I got from Garvin.
Great pics. I really like what you've done. Now the only thing you need is a bully bar for the front of the Jeep!
Couple questions... How does the roof rack affect the panoramic view from the interior? (I know, it's trivial)
Also, with the tire mounted on back, how does the rear camera and sensor react when backing up? Did you disable the parking assist system?
the1jake is offline
post #197 of 2852 Old 04-29-2012, 07:53 AM
Chrazy-Chris
2012 WK
Wow, that is one tricked out Jeep. Is that the Rocky Road roof rack? What's the wind noise like at highway speeds?
Does that tire carrier only connect to the receiver hitch, or are there other points of contact as well?
Very cool setup. I'm also looking forward to seeing what you do to the front end!
2012 Laredo V6, 26X, QTII ...coming Oct 2012
Chrazy-Chris is offline
post #198 of 2852 Old 04-29-2012, 08:05 AM
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Bully bars are junk! Expensive hollow metal that will crunch under barely any pressure. It wouldnt work with his rig since he actually has some nice upgrades for off road. Quoting the pictures is also annoying. Makes the thread too long.
2011 Billet JKUS
Jackal01 is offline
post #199 of 2852 Old 04-29-2012, 08:54 AM
1slo_CR
2011 WK
So has anybody found a way to recalibrate the speedo for the tire size change??? I just added 285/45r22's and the speedo reads almost 3 mph off. 72-73 at 70. Can the dealer change it or is a programmer/downloader needed??
1slo_CR is offline
post #200 of 2852 Old 04-30-2012, 11:10 PM
bmackin
2012 WK
Originally Posted by hur1ey02 View Post
I actually love my Terra Grapplers. They will give you a quiet ride. I'm running 275/65/18s, so I can't help you size wise, but mine have never rubbed (on or off road). You could do some calculations and compare sizes.
Sounds great! Love the photos you posted earlier. Can I ask? How aggressively have you used these off road? Have you hit the bump stops at speed? I plan to use mine in situations I know will fully compress the suspension from time-to-time, (i.e. driving on sand at high speed). I thought I had better double and triple check before I make my purchase. The prices over here in Australia are pretty steep, they are asking $550 per tire for a BF Goodrich AT in that size!!
bmackin is offline
post #201 of 2852 Old 05-01-2012, 04:36 PM
wahoo
2011 WK
thanks man. When the rack is unloaded it doesnt block the view too much, but fully loaded it obviously does.
I have to disable the parking assist. Without the gas cans I can still use the camera, the tire does block some of the view. With the cans, its useless.
wahoo is offline
post #202 of 2852 Old 05-01-2012, 04:40 PM
wahoo
2011 WK
Thanks man. Its a Garvin Rack, here is a link to their website. Not much wind noise, but there is some.
http://www.wildernessracks.com/
The tire carrier just connects only to the hitch, its amazing stable for just having that one point.
Rocky Road is working on a set up for the front, I'm waiting to see what they come up with.
wahoo is offline
post #203 of 2852 Old 05-01-2012, 04:45 PM
wahoo
2011 WK
Agreed! I'm waiting to see what Rocky Road comes up with, they are working on a winch set up. There really isnt anything out there right now that I know of for the front of the WK2.
wahoo is offline
post #204 of 2852 Old 05-01-2012, 11:28 PM
Chrazy-Chris
2012 WK
What lift QL setting were you at in this picture?
http://i445.photobucket.com/albums/q...p/Jeep3001.jpg
post #205 of 2852 Old 05-02-2012, 10:04 AM
wahoo
2011 WK
Normal
wahoo is offline
post #206 of 2852 Old 05-02-2012, 10:30 AM
Chrazy-Chris
2012 WK
Thanks! That seals the deal- I'm getting 275/65/18s for my stock wheeled non-QL Laredo!
post #207 of 2852 Old 05-03-2012, 05:01 AM
JABEACHFANZ
2012 WK
Hey everyone, We should come up with a sticky of tire sizes that have been installed. With the difference in tread pattern and actual outer diameter it would also be a good idea to list the tire manufacturer and model of the tire. Along with the tire size we should list if we have a lift, tire spacers, rim info (backspacing, width, and diameter).
Anyhow, I'm trying to figure out if a a 265/70/17 Guard Dog M/T will fit. Specs are 80 PSI max, 10.5'' wide, 32.25'' diameter. Rim range 7 - 8''. For $125 each they arn't a bad deal at all. Lots of reviews from the trailblazer market. Here's the website. www.treadwright.com
JABEACHFANZ is offline
post #208 of 2852 Old 05-10-2012, 06:06 PM
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Thread stickied!
I thought I posted in here. I guess not.
I put Nitto Terra Grappler 265-70-17 on MB TKO 17x8.5. Both fit before lift with no rubbing at any point. However, I am unaware if the size of tires would fit with factory offset.
Before lift
After lift
2011 Billet JKUS
Jackal01 is offline
post #209 of 2852 Old 05-14-2012, 08:21 AM
Molson
265-60-18 w/xd monsters
Molson is offline
post #210 of 2852 Old 05-16-2012, 02:59 PM
Cederbaum
Has anyone tried these tires??
Nitto Terra Grappler All-Terrain Tire - 265/50R20 111SR
I have the overland with 20s?
Would this work and whats you opinion of the tires?
Cederbaum is offline
conversion , headlight , oneighty , vinyl , wrap
WK2 Picture Thread Texas WJ WK2 Grand Cherokee Forum 2671 Today 05:51 PM
Overland Wood Steering Wheel? Stephen5242 WK2 Grand Cherokee Forum 32 03-22-2011 01:17 PM
What is the Wheel Bolt Pattern getoutandplay WK2 Grand Cherokee Forum 3 11-27-2010 08:18 PM
