Wheel and Tire Discussions - Page 11 - JeepForum.com
 84Likes
post #151 of 2807 Old 12-11-2011, 06:28 AM
82Renegade
1982 CJ7
Has anyone tried 255/70/18 ? At 32" overall diameter but .4" more narrow than stock it seems like a winner. Doesn't even seem to be on the table as an option in all these threads though, am I missing something?
82Renegade is offline
post #152 of 2807 Old 12-11-2011, 12:53 PM
Richard338
2013 WK
Yes, I have a set of 255/70/18's on Sahara wheels. Looks and works great but the tire selection is limited. See http://www.jeepforum.com/forum/f309/...tires-1263508/
Richard338 is offline
post #153 of 2807 Old 12-12-2011, 02:18 PM
zzkazu
Originally Posted by hutchison101 View Post
These are 265/65/18
Hutch, does the spare allow the spare tire hatch to sit flat.
Btw looks great..
zzkazu is offline
post #154 of 2807 Old 12-19-2011, 11:46 AM
webspoke
Originally Posted by Mojo51 View Post
Does anybody know will these tires fit on my non QL Laredo?
Search for rolexjake on this forum, he has this isze on some kmc addicts on a non QL with no issues. On stock wheels I am not sure, I think have seen one post on that combo working.
2013 White V8 Limited, 285/60/18 Terra Grapplers, 25000 miles problem free
2011 Black V8 Overland, retired at 46000 miles with QL problems
webspoke is offline
post #155 of 2807 Old 12-30-2011, 08:44 PM
Richard338
2013 WK
Originally Posted by JayB View Post
Guess I better check back in here with more info....
so I ended up buying a set of the JK Wrangler Sahara 18" stock wheels with 255/70/18 Bridgestone Dueler tires.
Tires are 32" dia. (815mm). The wheels are offset 46mm, 7.5" width instead of stock 18" WK2 at 56mm and 8" width. I'm giving up about 0.4" of tire width, but in my opinion the 32" tire size looks great on the WK2. I have no issues with clearance (have QL. checked on all settings). I don't think I'd have issues with a 275/65/18 either (don't quote me on that though....)
Have you tried the 275/65/18s yet? I have a set of these wheels and am thinking of trying the bigger tires.
post #156 of 2807 Old 01-05-2012, 08:25 AM
Richard338
2013 WK
265/70-18's on Sahara Wheels
Has anyone tried a 285/70-18 on Sahara 7.5x18 wheels, or any other wheel for that matter? I know the 255/70-18 will clear and these are only .5" taller and less than .5" wider but to much is still to much. What do you think?
post #157 of 2807 Old 01-26-2012, 10:05 AM
DJK555
2012 WK
Winter wheels & Tires
Hello all. First post for me. Looks like a great forum.
Just picked up a 2012 Grand Cherokee Limited in BC. As I travel through mountain passes on a regular basis and need 4 wheel drive to get up my 750 meter driveway for four months of the year, I would like to get a set of winter wheels and tires to replace the stock Michelin Latitude Tour. I'm finding that aftermarket wheels are hard to come by due to the new bolt patern/size and offset. Any suggestions? Has anyone had experience with the Latitude Tour in winter condidtions? Thanks in advance.
David
DJK555 is offline
post #158 of 2807 Old 01-26-2012, 11:35 AM
superserialMBP
2012 WK
I drove in a 8" snowstorm here in Denver with the Latitude Tours and they worked just fine, but I wasn't going up any extreme grades on hills. The snow mode really helps it seems. You might want to give them a shot and if they aren't cutting it, then change them out.
2012 Laredo X : QTII, 430N nav, true blue pearl
superserialMBP is offline
post #159 of 2807 Old 01-26-2012, 03:26 PM
fljeepleo
2011 WK
Tire rack, you put your vehicle in and it picks the wheels and tires that fit.
2011 Stone White Grand Cherokee Laredo E, ORA1, QT2, Factory Trailer Tow, 3m FX 15% Tint.
Retired Jeeps
1998 Wrangler Sahara 10inch skyjacker lift, 38x14.50 TSL
2005 Grand Cherokee Limited, 5.7, QD2
fljeepleo is offline
post #160 of 2807 Old 01-26-2012, 03:29 PM
Justal13
2012 WK
I see several sets of the 18" Laredo X painted version of the Limited Wheels on e-Bay and our local Craigslist. That is the direction I would go personally, and keep it looking nice and stock even in the winter. The factory wheels will hold up to salt and road chemicals better than any steel or aftermarket alloys, in my opinion. I would also spring for adding TPMS sensors if you are going to have a winter set and a summer set of wheels & tires. Otherwise, you will have to look at a TPMS error code on the EVIC all winter long. For tires, I always find the best prices at Discount Tire for all brands.
My Latitudes are working fine for Minnesota/Wisconsin ice and snow for me. Not planning to get a 2nd set for winter and not planning on off-roading. But your needs seem quite a bit more extreme. Best luck.
Justal13 is offline
post #161 of 2807 Old 01-26-2012, 04:05 PM
BioCRD
2012 WK
I travel mountain passes regularly, through long winters with heavy snow. Bridgestone Blizzaks have been terrific for me, have had 'em on two Subarus and a previous Jeep. I get them from Tire Rack, shipped to my door. For the Grand Cherokee, I ordered the package, of tires, wheels, and TPMS sensors all mounted and balanced, just had to put them on.
I would bet that any of the major brands' "studless" winter tires would be good. I'll keep the OEM Latitudes on the factory wheels for summer use.
BioCRD is offline
post #162 of 2807 Old 01-27-2012, 05:56 AM
MI_Limited
2011 WK
Originally Posted by DJK555 View Post
I'm finding that aftermarket wheels are hard to come by due to the new bolt patern/size and offset. David
The bolt pattern is the same as the previous WK's, it's just the width and offset you may have to consider. Has anyone tested the fitment of the 18" Wrangler wheels on the WK2's? Those would look pretty sharp for winter wheels and even have the JEEP center cap.
MI_Limited is offline
post #163 of 2807 Old 01-27-2012, 08:42 AM
Busina
2011 WK
I ordered a set of rims and winter tires from TireRack, didnt have any issues. When they were delivered, all i had to do was unwrap and bolt them on.
Busina is offline
post #164 of 2807 Old 02-12-2012, 09:55 AM
bobholthaus
2007 WK
How are the Duratracs wearing? Any regrets? Feedback after 8 months? Thinking of going with these on my 2007 GC CRD with 18" wheels. Im thinking 70 aspect ratio and may do a budget boost to fit them.
'14 GC Overland Diesel
bobholthaus is offline
post #165 of 2807 Old 02-12-2012, 09:57 AM
bobholthaus
2007 WK
Also, what brand of rock rails are those? Thanks.
conversion , headlight , oneighty , vinyl , wrap
WK2 Picture Thread Texas WJ WK2 Grand Cherokee Forum 2632 Yesterday 08:52 AM
Overland Wood Steering Wheel? Stephen5242 WK2 Grand Cherokee Forum 32 03-22-2011 01:17 PM
What is the Wheel Bolt Pattern getoutandplay WK2 Grand Cherokee Forum 3 11-27-2010 08:18 PM
