Wheel Encyclopedia - Page 3 - JeepForum.com
post #31 of 43 Old 07-28-2015, 11:12 AM
it_felt_so_good
I just pulled the trigger on:
They are going on a stock 2015 Jeep Grand Cherokee Laredo.
255/70R17 is only a little under an inch wider and bigger than the stock 245/70R17 tire size so there shouldn't be any fitment issues. Pro Comp 98 Steelies have a -6mm offset, so combined with the spacers, this set should stick past the fender a little over ~ 1.5 inches. Will post pictures as soon as they are mounted.
2013 JKU
2015 WK2
it_felt_so_good is offline
post #32 of 43 Old 10-15-2015, 09:14 AM
MIQUEL
can anyone provide part number for this wheel?
MIQUEL is offline
post #33 of 43 Old 01-20-2016, 08:07 PM
dxpanther
2014 WK
how did this turn out? im doing something similar but with pro comp series 7069 17X9 wheels. grabber at2's as well
dxpanther is offline
post #34 of 43 Old 01-26-2016, 11:33 AM
caulk04
2008 WK
I reckon it's going to look rather Mexican with those spacers installed. It'll be effectively 3" backspacing...silly.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #35 of 43 Old 02-04-2016, 01:23 PM
diaz425
Originally Posted by Ben View Post
Raised edge 5 spoke
OEM WK2 Laredo
17x8
+56 offset / 6-1/4" backspacing
Will not clear HD brakes.
Am I doing something wrong? With the stock 17x8 +56 offset, I am getting a 6.7 backspace. I am looking at buying 17x9 steel with 4.25 backspace. I am trying to figure out the offset number, if I did the calculations right, I got a -19 mm offset which will stick out just over 3 inches. With the 17x9 4.25 backspace I am looking at putting on 265/65x17 tires which is about 3/4 in wider than the stock 245/70x17. I would like to get 1 in taller and 1 in wider tires with no lift if possible with no rubbing.
diaz425 is offline
post #36 of 43 Old 02-04-2016, 01:32 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
The calculator at http://www.rimsntires.com/specspro.jsp is a good way to compare wheel and tire sizes.
A 17x9 wheel with 4.7 inch backspace would have a -9mm offset, which would stick out about 64mm farther than the OEM, about 2.6 inches.
You may want to check the fitment and tire discussion stickies for something similar.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #37 of 43 Old 02-11-2016, 06:04 PM
diaz425
What is the stock 17 inch wheel load max cap? I know the stock goodyear says 2205 lbs. I am looking at the buying 17x9 steel and the max load on them says 2000 lbs. The tires I am looking at buying are p255/70r17 either the hankook dynapro atm (load max says 2337 lbs) or the general grabber (load max 2469 lbs).
Quadratec has steel wheel that fit my 2011 Grand Cherokee. http://www.quadratec.com/products/92600_0039_P5_07.htm
Would I have problems getting these wheel with the tire option I am looking at buying?
Thanks in advance
diaz425 is offline
post #38 of 43 Old 02-16-2016, 07:36 PM
Patri0tP0wer
Hey guys, sorry if this has been asked before i'm new to the forum. Does anyone know the weight of the stock 17" Aluminum wheels for the 2013 Laredo? I've seen elsewhere that the 17s on the Wrangler are about 27 lbs. Are they the same weight...is that even accurate?
Thanks
Patri0tP0wer is offline
post #39 of 43 Old 02-25-2016, 07:27 AM
gamma500
2015 WK
Won't clear calipers on WK2??
17" JK Rubicon
17x7.5
44.45mm offset
6" BS
thanks kkuntz01
M
My understanding is that these will fit WK (2005) brake calipers but will need caliper grinding to fit WK2's.. Anybody care to confirm?
THX
gamma500 is offline
post #40 of 43 Old 02-26-2016, 06:52 AM
gamma500
2015 WK
Hmmm..just tried these on my 2015 JGC and they cleared the front caliper (at least on Dr side I tried) by a hair. May be part of the "caliper hits rim on tight curve" group. Wouldn't take much heat induced metal expansion to get these REAL close and kissing...
gamma500 is offline
post #41 of 43 Old 02-22-2017, 10:32 AM
ColdCase
ColdCase's Avatar
2011 WK
These seem to be becoming available via the MOPAR accessory catalog:
ColdCase is offline
post #42 of 43 Old 04-08-2017, 02:57 AM
crashdavis
Happen to know where I can see picks of this wheel on a GC? Thanks.
crashdavis is offline
post #43 of 43 Old 04-08-2017, 06:29 AM
ColdCase
ColdCase's Avatar
2011 WK
Wheel and tire discussion sticky, page 174 post 2604
http://www.jeepforum.com/forum/f309/.../index174.html
ColdCase is offline
Is the 2011 Quadra Drive 2 a 3 wheel or 4 wheel drive system? MRK WK2 Grand Cherokee Forum 45 11-03-2015 11:22 AM
Wheel spacers eburge2011 WK2 Grand Cherokee Forum 0 04-16-2012 03:26 PM
2011 Jeep Grand Cherokee Wheel Locks? 2011JGCL WK2 Grand Cherokee Forum 3 06-11-2011 11:53 AM
Purple steering wheel? bluevw03 WK2 Grand Cherokee Forum 15 05-13-2011 02:28 PM
WK2 wheel specs? Bzwth WK2 Grand Cherokee Forum 12 02-18-2011 10:13 PM
