Wheel Encyclopedia - Page 2 - JeepForum.com
post #16 of 48 Old 09-04-2012, 12:02 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
This diagram shows wheel width from inside of bead to inside of bead. It shows offset as the distance from the wheel center line to mounting pad. It shows back space as the distance from the mounting pad to the inside wheel edge.
These are suppose to be 20 inch wheels with 265/50-20 tires, the drawing on the left has a 56mm offset, the one on the right has a 45mm offset. The one on the right would stick out 11mm (0.4 inches) more than the one on the left.
It looks like the backspacing includes the width of the wheel bead but the wheel with does not.
Thats about all I know about wheels... well except that the OEMs are heavy.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #17 of 48 Old 09-04-2012, 12:19 PM
ColdCase
ColdCase's Avatar
2011 WK
So if I run through your math, backspace is 1/2 wheel width +offset +bead
Lets say x= bead, so in the wheel on the left 4.5 inch +2.2 inch +x = 7.2 inch. so x= 7.2 -4.5 -2.2 = 0.5 inch
for the wheel on the right 4.5 inch +1.8 inch +x = 6.8 inch. so x = 6.8 -4.5 -1.8 = 0.5 inch
The bead is 0.5 in both cases.
If the wheel offset is 56mm, the backspace must be 184mm, if the wheel offset is 45mm, the backspace must be 173mm, everything else being equal.
I never measured the Jeep wheel, so I dunno how the actual measurements compare. And the OEM wheels are 8 inch width, so the 9 inch examples above are not exactly the same, sorry about that. Below would be an 8 inch width 18 inch example closer to the OEM wheels. Oh and notice that the example tire hangs over the bead, roughly 1 inch.
ColdCase is offline
post #18 of 48 Old 09-04-2012, 12:47 PM Thread Starter
Ben
I could be wrong, but I think backspacing is from the outside lip of the wheel, and offset is from the "inside lip" (advertised width) of the wheel.
I'll edit that post later to reflect 8" width.
Ben is offline
post #19 of 48 Old 09-04-2012, 12:56 PM
ColdCase
ColdCase's Avatar
2011 WK
I think we are saying the same thing but just from different perspectives. I always have to draw a picture.
ColdCase is offline
post #20 of 48 Old 03-26-2013, 08:47 AM
shekshishekki
2013 WK
http://www.ebay.com/itm/20-Inch-Hype...item4171a5fe25
Found these on ebay...is it true that the offset and rim width are different between the front and back wheels? For SRT8 I mean...
Front: 20x9 5x127 offset 34
Rear: 20x10 5x127 offset 50
would those fit on a 2013 overland using stock tires of 265/50R20?
shekshishekki is offline
post #21 of 48 Old 04-16-2013, 12:14 PM
ColdCase
ColdCase's Avatar
2011 WK
The backspacing is stamped/molded on the back of the wheel. You will need to take a wheel off to see it. Probably a 56.4 offset.
ColdCase is offline
post #22 of 48 Old 05-10-2013, 08:47 PM Thread Starter
Ben
2013 JK Wrangler Sahara Wheels
18x7.5
44.45 offset
Now if I hold a tape measure across this, it reads 8-5/8" and the backspacing measured from the wheel mounting face to a straight edge held across the outer edge of the wheel is 6"
Math says that "should" be 5.5" (offset + half the width --- 44.45mm or 1.75" + 3.75" = 5.5")
So ColdCase it looks like our musings last year about the width of the rim bead were spot on.
Ben is offline
post #23 of 48 Old 01-24-2014, 08:20 AM
2kg4u
2014 WK
18x7.5
44.45 offset
Backspace is not offset plus half the width. The width is measured inside the beads, and offset is measure from the outside of the rear bead to the plane of the mounting surface. I find this site to be extremely helpful:
http://www.rimsntires.com/specspro.jsp
If you input the offset it will calculate and display the backspace. If you know the backspace and not the offset, change the offset in the input area until you get the backspace you want.
Roy
2014 Overland, 3.6 L
Fumoto Qwikvalve, Ionic CXV running boards, Michelin X-Ice Xi2 snow tires
2kg4u is offline
post #24 of 48 Old 01-27-2014, 09:50 AM Thread Starter
Ben
That's what I was saying. Offset and Backspacing will never add up unless you know the dimension of the rim bead. Width and Offset are measured inside the bead, Backspacing is measured outside the bead.
Ben is offline
post #25 of 48 Old 07-16-2014, 02:01 PM Thread Starter
Ben
Most 18s will work. I've had 2 different sets of 18" Sahara wheels on my Overland with the big brakes.
Nice CJ.
Ben is offline
post #26 of 48 Old 08-01-2014, 11:37 AM
falconst
2011 WK
Found this info on another site.
Stock 18" Sahara Wheel = 27 Lbs
Stock Deuler P255 70 R18 = 44 Lbs
Wheel and Tire total = 71 Lbs
Now to find info on the 20" WK2 Overland wheels.
2011 WK2 Overland, 5.7L Hemi, QDII, QL, Volant Intake... more to come.
falconst is offline
post #27 of 48 Old 08-02-2014, 08:29 AM Thread Starter
Ben
Originally Posted by falconst View Post
Of those that have already swapped out their OEM WK2 tires for the larger JK Sahara tires, what differences have you seen in MPG?
I've had the stock 20s with 265/50r20 goodyears (30.5x10.5),
JK 18s with 275/65R18 MTRs (32x11),
and now last model year's SRT8 wheels, 20x9 with 275/55r20 Coopers (32x11.5)
I don't have MPG numbers, but I can tell you I have a project in Winchester VA, 414 miles away, with the stock rubber, I could make it down & back in 1 tank. Stock rubber + roof rack cross bars, I'd have to stop for gas. Coopers/MTRs & NO roof rack, I can make it down & back, and lastly fat tires & roof rack, not a chance. Sorry I can't quantify it, but you will see a difference.
Hope that helps.
edit. huh. funny how white it looks until it's got the snow behind it.
Ben is offline
post #28 of 48 Old 08-05-2014, 09:20 AM
jimb0JP
Originally Posted by canistel View Post
I've been looking for a while, but can't seem to find anything; does anyone have any tips on a wheel that is 9" wide (instead of the usual 8") and 17" or 18" diameter, while still looking very close in the front appearance to original 17/18 inch rims? So basically, I like the looks of the factory rims but just want a wider rim.
I ran these on my 2006 Limited in the 20" size, but these are 18" x 8.5".
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
2012 Jeep Grand Cherokee Altitude 5.7
2002 Pontiac Trans Am Firehawk
1991 Pontiac Formula Firehawk
jimb0JP is offline
post #29 of 48 Old 02-02-2015, 04:13 AM
RiflemanX
2015 WK
18" OEM rims, 2015 WK2, Off-Road Adventure II, black powder coat.
RiflemanX is offline
post #30 of 48 Old 02-13-2015, 12:23 PM
ColdCase
ColdCase's Avatar
2011 WK
Look at the rear rotors, if they are solid you have SD brakes, if they are vented (venting sandwiched between two solid rotors) they are HD.
You can also look for BR6 in your build sheet
All diesels are suppose to have HD brakes.
ColdCase is offline
Is the 2011 Quadra Drive 2 a 3 wheel or 4 wheel drive system? MRK WK2 Grand Cherokee Forum 45 11-03-2015 11:22 AM
Wheel spacers eburge2011 WK2 Grand Cherokee Forum 0 04-16-2012 03:26 PM
2011 Jeep Grand Cherokee Wheel Locks? 2011JGCL WK2 Grand Cherokee Forum 3 06-11-2011 11:53 AM
Purple steering wheel? bluevw03 WK2 Grand Cherokee Forum 15 05-13-2011 02:28 PM
WK2 wheel specs? Bzwth WK2 Grand Cherokee Forum 12 02-18-2011 10:13 PM
