Wheel Encyclopedia - JeepForum.com
post #1 of 43 Old 05-23-2012, 09:36 AM Thread Starter
Ben
Wheel Encyclopedia
This thread lists all wheels that came on WK2 Grand Cherokees and some aftermarket as well.
Fitment and tire discussion is in the Wheel and Tire Discussion thread:
http://www.jeepforum.com/forum/f309/...sions-1141422/
A database of fitment results is in the Tire-Wheel Fitment Reports thread:
http://www.jeepforum.com/forum/f309/...mmary-2798314/
Try to stick to the following format:
Name/Style/Description
OEM WK2, WK, or JK, or Aftermarket
Heigth x Width (in inches) and Offset(mm) or Backspacing(inches)
Link to pic on WK2
Picture of wheel
Please correct anything that isn't right, and post up offsets and backspacking if you have the wheels. (It should be stamped somewhere in the back of the wheel ET##)
Notes:
OEM center bore is 71.5.
Please limit this thread to wheel information only, not tire info. This is not a what size tire thread, how much trimming, or what size lift to clear X thread. There's plenty of other threads for that, knowing the exact size and wheel fitment is the first step in that process. Offset is crucial.
This is for information only, please do your homework before buying anything for your Jeep, while I've tried to be as accurate as possible, I'm not liable for anything you buy or do.
If I used your picture, thanks. If you didn't want me to use it, PM me and I'll take it down.
HD brakes are bigger than standard duty. If you have HD brakes, take that into consideration when determining wheel selection.
Helpful Links:
Wheel Collision - lists all jeep wheels throughout the years
Roadkill Customs cross reference - what else might fit?
Morris 4x4 - explains bolt pattern, offset, centerbore, backspacing...
WK2 Jeeps This started as WJJeeps, and the owner(s) have been providing info for many years, thankfully it looks like they will be supporting WK2s
Ben is offline
post #2 of 43 Old 05-23-2012, 09:37 AM Thread Starter
Ben
WK2 Stock 16"
nope. too small.
Ben is offline
post #3 of 43 Old 05-23-2012, 09:38 AM Thread Starter
Ben
WK2 Stock 17"
Raised edge 5 spoke
OEM WK2 Laredo
17x8
+56 offset / 6-1/4" backspacing
Will not clear HD brakes.
Ben is offline
post #4 of 43 Old 05-23-2012, 09:39 AM Thread Starter
Ben
WK2 Stock 18"
Contoured 5 spoke
OEM WK2 Limited
18x8
measured on an 8" wheel, 56mm offset from the centerline is approximately 6-1/4" of backspacing, user posts on forums is the only data I've found on stock WK2 offset, and, allegedly applies to all 18x8" oem wheels. As I verify info, I will remove these type notes...
Raised Contoured 5 spoke
18x8
Flared Contoured 5 spoke
18x8
Mopar Black & Machined
18x8
Spare (steel wheel)
18x8
Pictures on WK2 thanks to jared57
Ben is offline
post #5 of 43 Old 05-23-2012, 09:41 AM Thread Starter
Ben
WK2 Stock 20"
Contoured 5 spoke
OEM WK2 Overland
20x8
+56.4 offset - verified
measured on an 8" wheel, 56.4mm offset from the centerline is approximately 6-1/4" of backspacing.
V Spoke
OEM WK2 70th Anniversary / Durango R/T
20x8
2012 SRT8
Ben is offline
post #6 of 43 Old 05-23-2012, 10:13 AM Thread Starter
Ben
JK Stock 17"
17" JK Rubicon
17x7.5
44.45mm offset
6" BS
thanks kkuntz01
Ben is offline
post #7 of 43 Old 05-23-2012, 10:14 AM Thread Starter
Ben
JK Stock 18"
5 spoke
JK Sahara
18x7.5"
+44.45mm offset - verified
Pictures on WK2 thanks to JayB
18" jk limited
still need size info & offset/backspacing
Ben is offline
post #8 of 43 Old 05-23-2012, 10:20 AM
Justal13
2012 WK
You might note the difference between painted and polished/clearcoated (sometimes called "chrome", but they are actually just polished) in the descriptions, to help differentiate. Thanks.
Justal13 is offline
post #9 of 43 Old 05-23-2012, 02:56 PM Thread Starter
Ben
XK Stock 17"
Hulk
XK Commander
17x7.5
50.8mm / 6.25 backspacing <-- PLEASE VERIFY or do the math and you'll realize one of those numbers HAS to be wrong.
Wrench
XK Commander
17x7.5
Chrome
XK Commander
17x7.5
Ben is offline
post #10 of 43 Old 05-28-2012, 08:18 AM
padgett
2012 WK
For differences see codes:
BRY Anti-Lock 4-Wheel Disc Brakes (17")
BR1 Anti-Lock 4-Wheel Disc Brakes (18")
BR6 Anti-Lock 4-Wheel Disc HD Brakes
BUX other than US, Canada, or Mexico
One of these is a turbo diesel.
We take in orphans. Notary Sojac y'all.
padgett is offline
post #11 of 43 Old 07-18-2012, 11:43 AM
kkuntz01
Originally Posted by WKdeuce View Post
17" JK Rubicon
still hunting size info & offset/backspacing
Here you go.
17x7.5
44.45mm offset
6" BS
Sure my rig has seen the trail, but I wheel it like a soccer mom looking for a parking spot at Nordstroms.
kkuntz01 is offline
post #12 of 43 Old 08-06-2012, 08:40 PM
arfmmf
2012 WK
Surprised no one has added the 2012 SRT 20" wheels.
arfmmf is offline
post #13 of 43 Old 09-01-2012, 03:07 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
I noticed this site seem to have been updated with more WK2 relevant info:
http://www.rimsntires.com/packages.j...earch&sized=18
Bolt pattern: 5x127 (5x5). Offset: 18 to 45 mm. Tires up to 800x275mm. Rims up to 26x9.5".
The site lets you select stock or lifted.
You can compare rim and tire sizes here:
http://www.rimsntires.com/specs.jsp?item=Wheel-Tire
They say the OEM 18 and 20 inch wheels have a 173 mm BackSpace, 45 mm offset, and 9 inch width
My OEMs are stamped with a 56.4 offset, however.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #14 of 43 Old 09-02-2012, 07:23 AM Thread Starter
Ben
ColdCase, I'm struggling with this everytime I worth through it on our Jeeps. I'm almost at the point where I don't believe the number stamped in the wheel, but that's absurd.
Backspace is measured with the wheel laying flat on the ground face up, from the ground to the mounting face of the wheel.
Offset, I'm sure you know, is a measurement from the center line.
The problem is, when we say 9" wheel, that's the internal bead mounting surface, not a true cross sectional width, which may be as much as 10" in our case.
Without calculating the mounting width and overall width delta, you cannot correlate backspacking and offset.
For example, using your numbers above:
OEM 20"
6.81" (173mm) backspace
9" (228.6mm) width
1.77" (45mm) offset
half the width, plus the offset, does not equal backspacing:
4.5" (114.3) + 1.77" (45mm) = 6.27" (159.3mm) does not equal 6.81" (173mm), UNLESS, the rim's lip is 0.54" (13.7mm)
try that again with the stamped digits from Mopar
4.5" (114.3) + 2.22" (56.4) = 6.72" (159.3mm) does not equal 6.81" (173mm), UNLESS, the rim's lip is 0.09" (2.3mm)
So, That leaves us with 2 numbers for the width of the wheels lip, one being a half inch, one being 2mm.
The half inch is believeable, the calculated 2mm is based off the numbers from Chrysler.
Maybe JeepCares can come in here and shed some light on this?
Ben is offline
post #15 of 43 Old 09-04-2012, 11:44 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
I don't think I'm going to shed any light on this at all. FEEL FREE TO CORRECT ME
This is what I always thought (remember, I'm not very technical):
The wheel width is the measurement measure from the inside of each flange (lip), rather than from the outer edges of the wheel.
Offset tells you how far off center the mounting part of the wheel is.
So if you have a 56.4 mm offset – that means the tire is mounted on a “plate” 56.4 millimeters out past the center of the wheel. This actually brings the wheel /tire more under the vehicle. The mounting plate is farther away from the back of the wheel (back of the wheel being the side that faces towards the center of the vehicle – the side you can’t see) than a vehicle with a 45 mm offset.
The offset in cast into the back side of all Chrysler wheels.
Backspacing is the measurement between that mounting surface of the wheel to the back (inside lip) of the wheel - (back of the wheel being the side that faces towards the center of the vehicle as opposed to the front which faces out from the vehicle.)
Backspacing is half the width of the wheel (inside lip) plus the offset.
Some people add spacers to “space” the rim off the hub to get more backspace.
JeepCares is online now
Is the 2011 Quadra Drive 2 a 3 wheel or 4 wheel drive system? MRK WK2 Grand Cherokee Forum 45 11-03-2015 11:22 AM
Wheel spacers eburge2011 WK2 Grand Cherokee Forum 0 04-16-2012 03:26 PM
2011 Jeep Grand Cherokee Wheel Locks? 2011JGCL WK2 Grand Cherokee Forum 3 06-11-2011 11:53 AM
Purple steering wheel? bluevw03 WK2 Grand Cherokee Forum 15 05-13-2011 02:28 PM
WK2 wheel specs? Bzwth WK2 Grand Cherokee Forum 12 02-18-2011 10:13 PM
