wheel corrosion - JeepForum.com
post #1 of 19 Old 12-05-2013, 10:16 AM Thread Starter
peckmv
wheel corrosion
I noticed corrosion of all my wheels at the center around the "jeep" center cover. Took it to the dealer and they got approval to replace all 4 wheels under warranty. Thought it was going to be a battle but they OK'ed it with no pushback. I guess its a known problem.
peckmv is offline
post #2 of 19 Old 12-05-2013, 12:49 PM
jacko15
2014 WK
What year Jeep, and which wheels?
Mine: 2014 Jeep Grand Cherokee Overland V/6
ORA II
Hers: 2017 Jeep Compass Latitude 4x4
jacko15 is offline
post #3 of 19 Old 12-06-2013, 07:49 AM
kkreit01
I'd be interested in more details as well. I'm guessing they are either polished or chrome? One you get the new wheels, clean and apply a sealant to them regularly.
kkreit01 is offline
post #4 of 19 Old 12-06-2013, 03:56 PM
classyjeeper
Yes
What wheels, model and year ?
classyjeeper is offline
post #5 of 19 Old 12-06-2013, 03:57 PM
classyjeeper
I've noticed a little blemish on my new 2014 20" wheels and wandered if that's the way they are supposed to look.
post #6 of 19 Old 12-06-2013, 06:44 PM Thread Starter
peckmv
Originally Posted by classyjeeper View Post
Yes
Its the 18'' wheels on a 2012 Overland. The center has a cavity that has no way for water to get out. I plan on removing all the new replaced wheels and grinding a grove on the back so the water can drain. The dealer told me that this was a $1100 warranty hit that Jeep took. You would think that they would have redesigned the wheels by now, but I guess its cheaper to just take the warranty hit.
peckmv is offline
post #7 of 19 Old 06-12-2014, 12:07 PM
nubby105
2011 WK
2011 Limited I have corrosion around the center caps as well
nubby105 is offline
post #8 of 19 Old 06-15-2014, 10:02 AM Thread Starter
peckmv
That's what mine looked like. Since your out of warranty, you could have your wheels repaired and grind grooves in the back to let the water out that causes the corrosion. That would be your cheapest option.
peckmv is offline
post #9 of 19 Old 06-15-2014, 10:24 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
I think you will find replacement wheels the same or less money than repair.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #10 of 19 Old 06-17-2014, 12:29 PM
nubby105
2011 WK
Just got off the phone with the dealer, there is no warranty on the wheels. I did buy the lifetime extended warranty through Mopar and I will be checking my paperwork when I get home.
nubby105 is offline
post #11 of 19 Old 06-17-2014, 12:50 PM
shudog
2012 WK
I have the same thing on my 2012 but not quite as bad. My Jeep has 40k miles on it though, prob not a warranty claim anymore?
Previously owned jeeps:
'06 Grand Cherokee Limited w/4.7L V8 & QD2
'98 Grand Cherokee Limited w/5.2L V8 & Quadra Trac - sold at 230k miles
shudog is offline
post #12 of 19 Old 06-17-2014, 01:08 PM
nubby105
2011 WK
Extended warranty
That is the worst of them. I hope that I can find something in the extended warranty paperwork that will cover me.
nubby105 is offline
post #13 of 19 Old 06-17-2014, 02:30 PM
shudog
2012 WK
I bought my 2012 this winter, back in Dec of 2013. 3 of the 4 wheels looked clean, a tiny bit of corrosion on 1 at the center. I cleaned & waxed the wheels religiously this winter thinking it would keep them from getting in the same condition. Wrong
shudog is offline
post #14 of 19 Old 06-18-2014, 08:45 AM
nubby105
2011 WK
No luck with the warranty paperwork. Contacting Jeep customer service now. Can't understand how a cap that holds water in the wheels is not a manufacturer defect...
nubby105 is offline
post #15 of 19 Old 06-18-2014, 01:46 PM
David1
2014 WK
That is not what the corrosion is from initially. When tire shops put the wheel on the balancer that uses a cone seat that goes in the center bore, they usually just slam the thing in the whole or crank it down so tight that it cracks the finish around the lip and then with the centercap in place covers the damage, then the environment starts to attack the bare aluminum and creaps under the paint and spreads out as you can see. The really good balance machines have a motorized lift the raise the wheel so the tech does not drag and damage the finish around the whole. Then the really good machines, at my BMW dealer anyways, the balancer has a hubcentric adapter and the wheel is held in place by the lug holes just as it is when on the car so nothing touches and painted surface.
David1 is offline
