What's this vrum, vrum noise I'm hearing - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > What's this vrum, vrum noise I'm hearing
TJ BDS 2" suspension lift!! FINALLY a GREAT 2" lNitro Gear Packages Now Available at Rockridge 4wdFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 03-18-2015, 06:25 PM   #1
2003jeepkj
2012 GJ 3.3 w/ 28000 miles.
I'm hearing a rotating noise, something like a vrum, vrum, vrum when the vehicle is under a load such as climbing a hill. I can also feel the noise at the left side of the floorboard. It will happen even when the cruise control is on.
When driving at any speed w/o a load the car is quite.
I was passing the Jeep dealer today so I pulled in and told them, the service manger thinks it's the Transmission. It think it's more like a hub bearing.
They made an appointment from me this next M<Monday.
Let me know what you all think before the take me on a Trans job.
PS- There is no warranty on the vehicle
2003jeepkj is offline   Reply With Quote Quick reply to this message
Unread 03-19-2015, 06:12 AM   #2
2003jeepkj
Anybody?
Unread 03-19-2015, 07:02 AM   #3
2003jeepkj
I read a few threads here with similar concerns and the culprit was the factory tires, once changed the noise went away.
In my case I have 265/60r18 Michelin Latitude tires, so I'm still having a vibration or drone noise.
Unread 03-19-2015, 09:32 AM   #4
plasticgunz
Junior Member
I can't comment on the tranny or the hub bearing, but getting rid of the Michelin Latitudes certainly quieted my ride. Those things are crap.
plasticgunz is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 02:39 PM   #5
JeepCares
Hey 2003jeepki,
2012 Jeep Grand Cherokees came with a 5/100,000 powertrain warranty. Is the warranty you are referring to the 3 year/ 36,000 mile Basic Limited Warranty?
Andrea
Jeep Social Care Specialist
JeepCares is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 02:48 PM   #6
Tweezer19
2014 WK
Check to make sure you aren't in a Mazda.
2014 Overland Diesel w/ ORAII and Adv Tech Pkg
Tweezer19 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 03:03 PM   #7
2kg4u
2014 WK
That would be zoom zoom, not vrum vrum.
Roy
2014 Overland, 3.6 L
Fumoto Qwikvalve, Ionic CXV running boards, Michelin X-Ice Xi2 snow tires
2kg4u is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 03:10 PM   #8
2kg4u
2014 WK
A hub bearing will complain more when turning. For example, if the front left bearing is going it will make more noise when sharply turning to right due to the lateral load. The fact it only happens under load sounds like transmission, differential, or a U joint on a drive shaft. When you find conditions under which it happens, try duplicating those conditions using different gears. In other words, if at a particular speed going up a specific hill you hear the noise and the vehicle is in 3rd gear, try the same speed up the same hill in 2nd gear. If the noise is worse it could be transmission. If the noise stays the same it is likely something else in the drive train.
My response is generic to any vehicle. Someone with more specific JGC knowledge may have other ideas.
Roy
Unread 03-26-2015, 03:41 PM   #9
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
A bad UJoint or axle shaft will give you that kind of vibration. Often it just has to be the right kind of load and speed, too much or too little throttle and it disappears. There is usually a speed/throttle sweet spot.
Check your wheel lug nuts, make sure that are all tight.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
