What size is the brake caliper hex bolt? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > What size is the brake caliper hex bolt?
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits ZONE 4.25" combo lift for TJ available at Rockridge4wG2 Disc Brake Conversion Kit for Jeep Wrangler YJ TJ LJ Ch
Unread 10-26-2014, 09:45 AM   #1
kryogen
2011 WK
What size is the brake caliper hex bolt? I have a full set of hex sockets, and somehow, the size is either 11mm, or 7/16, and those are the 2 I do not have.
10mm will do, but it turns and grabs so I would rather not damage the hex.
Are the bolts metric or imperial? 11mm or 7/16?
Thanks
kryogen is offline   Reply With Quote Quick reply to this message
Unread 10-26-2014, 03:18 PM   #2
therebelmc
bolt size
Definitely 11mm
therebelmc is offline   Reply With Quote Quick reply to this message
